Results 1 to 2 of 2
Thread: What amp?
    LS6TT's Avatar
    LS6TT is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac CTS
    May 2007
    Fort Worth, Texas
    34
    299
    What amp?
    I have a Audiobahn Flame Excursion 12" sub. Says the power handling is 550 RMS.
    I am only going to run one sub, can anyone tell me what amp I should go with? I want to spend under 150 for the amp.
    thewireman* is offline Cadillac Owners Fanatic
    Automobile(s): 99 Cadillac Deville
    Feb 2008
    Paw Paw, MI
    139
    Re: What amp?
    MTX Mono amps are very good. Check them on e-bay. I'm pretty sure its dual 2 ohms sub right? Make sure you match the wattage with your ohms. Like if it is dual two ohms, you can use the amp that is pushing one ohm or if it is dual 4 ohms, you can use the amp that is pushing 2 ohms....etc. It can be a messy math work but it'll be worth it!
  • You may not post replies
