c.d. player
Results 1 to 6 of 6
Cadillac Audio, Video and Security Systems Discussion, c.d. player in Item Specific Cadillac Discussion; Tried to find answer in "search" no luck,went to the store and c.d. player worked fine (stock 12 disc player ...
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    c.d. player
    Tried to find answer in "search" no luck,went to the store and c.d. player worked fine (stock 12 disc player in trunk,97 seville)when I started car again to go home,the display read "no disc" I opened access door on player and the c.d. holder did not come out as it should,the small bar light went off and on as I closed and opened the door,still wouldn't play,does anyone know what is wrong?. tnx.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: c.d. player
    unplug and plug the changer
    Nov 2005
    3,013
    Re: c.d. player
    Thanks,it worked.
    Oct 2005
    15,987
    Re: c.d. player
    np
    glad to help
    BigOLak is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac Sedan DeVille
    Feb 2008
    16
    Re: c.d. player
    CTS2003
    This is off topic but I've been trying to get a hold of you. Do you know where I can find a schematic for how the factory amp is wired in a 96-99 deville? I want to relocate my factory radio and was wondering if I could just use the exitsing wireing behind the rear seat coming from the factory amp? Thank you in advance for any help.
    mtt333 is offline Cadillac Owners Member
    Automobile(s): 99 Deville Concours
    Sep 2007
    Colorado
    46
    Re: c.d. player
    (99 Concours with typical aftermarket HU problems)
    I would also love to get that schematic talked about above by BigOLak. Also, would it make any diff if stock hu was relocated and amp removed all together?
  9. Remove Advertisements
