I'm trying to build a box out of my midgate in my 03 EXT and keep it functional. I have 2 Image Dynamic IDQ12 D4 V.2 run by a Zapco Studio 500. Specs can be found here:
http://www.imagedynamicsusa.com/pdf/IDQ12 D4 V2.pdf
Subthump.com used to have a nice looking box, but it's no longer on their site. It's a little too much airspace for my subs and not going to be available for a couple of months again.
it can be seen here:
http://www.subthump.com/avalanchemidgate.htm
It had 1.16 cu ft per sub. Looking at the spec sheet for the subs, the box is more airspace than I want for sealed (.85 normal, 1.0 large.) If you look at image tim4.jpg, you can see that the box has a cut out where the wires are that seems pretty unnecessary. It's actually for a flap so you don't have a gap when you put the wall down. I'll just remove that flap to avoid the extra cuts. I pretty sure I can get to the recommended 1.25 cu ft for a normal ported box.
I can figure out the dimensions for the most part myself, I really have no clue when it comes down to porting it though. I know the box won't be over 14.375" deep so making the port may cause a problem.
I was messing around with this box builder: http://www.bcae1.com/spboxnew2.htm (see the attachment for the figures it gave me - I used:
height=10" (really the depth)
width=46" (able to fit up to 47" wide)
depth1=12" (back of the box, needs to be angled so the midgate can fold down)
depth2=15" (front face of the box)
wood thickness = .75"
speaker displacement= .07
port frequency = 30
I think those are the dimensions I can get while keeping the midgate functional. I built a test box out of cardboard today and those specs work. I have a little room to play with with the depth and overall height (especially if I remove that flap
From the data sheet, I decided to go with the midsized ported box with a frequency of 30 hz. It seems like I got nearly the perfect volume if this comes out as planned. I tried using 3" ports, but the port length came out too long. I tried 4" but that was even worse. 2" port worked.
Before I go through the trouble of building this and it sounding like poop, can someone with some knowledge double check this. Again, I'm a newbie when it comes to ported box designs. I could easily figure out a sealed box (I would go with the Large - 1 cuft. per sub) but I want it LOUD!
I have a free weekend coming up and I hope to build this then. I'd REALLY appreciate it if someone can check those number out before I do so. Thanks again.
port frequency = 30
