Results 1 to 5 of 5
Thread: Removing radio from '01 sts
    Intheknow is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Aug 2005
    149
    I want to install my Sirius direct FM antenna and to do so I have to get to the back of the radio where the antenna plugs in. So, how do I remove the radio? Does anyone have a "how to" link?
    Murphyg's Avatar
    Murphyg is offline Cadillac Owners Connoisseur
    Oct 2003
    Ontario
    1,575
    Re: Removing radio from '01 sts
    This is something Id read a while back from Dadillac. It is for an 01 STS......But it was a reply he gave to someone to try to find a rattling sound.
    I think it does apply though seein as it ends with removing the stereo.
    Quote Originally Posted by Dadillac View Post
    Open the center arm rest, and remove the two screws that hold the lid latch. Then press in the cup holder, and slide the cup holder trim plate upward to remove it. Gently using a hooked tool (I use a vinyl siding panel tool) pry up on the right rear corner of the shifter wood trim plate. The trim plate has four press type clips that will release when the plate is pried upward. Put the shifter in a low gear, slide the trim plate backward, disconnect the electrical wiring, and remove the shifter trim plate. Pry off the sterreo trim plate that is above the stereo. There are two clips that will release when the trim plate is pried rearward. The stereo and climate control is removed and installed as a single unit. You will find two screws at the bottom, and one at the top. Remove those, disconnect the wiring, remove the unit. .........................................
    Don
    dirtyguido is offline Cadillac Owners Member
    Automobile(s): 2000 Seville SLS
    Feb 2008
    91
    Here you go:
    http://www.pro-fit-intl.com/Adobe/CD-55-98.pdf
    It's instructions on how to add on a phone mount to the car that this company makes, but it gives you step by step how to get the radio out....
    Hope this helps,
    George
  5. #4
    Aug 2005
    149
    Hey, this info worked! I have the direct FM plugged into the back of the radio and it is now static-free!
    Thanks for the help!
  6. #5
    Feb 2008
    91
    Quote Originally Posted by Intheknow View Post
    Glad to hear that it all worked out!
    Take care,
    George
  • You may not post replies
