Antenna for Navigation
Results 1 to 11 of 11
Cadillac Audio, Video and Security Systems Discussion, Antenna for Navigation in Item Specific Cadillac Discussion; I have done the Navigation upgrade on my 2002 STS and the only problem I am having is getting a ...
    TheCadillacKid's Avatar
    TheCadillacKid is offline Cadillac Owners Member
    Automobile(s): 2009 STS4, 1979, Coupe deVille, 2000 Camaro Z28 M6
    Mar 2006
    Brooklyn, New York
    29
    I have done the Navigation upgrade on my 2002 STS and the only problem I am having is getting a satellite signal. The unit I got came with an antenna that was too short to do anything with except leave it under the dash. Does anybody know the part number for the longer antenna so I can put it in the rear deck where it belongs?
    Mar 2006
    Brooklyn, New York
    29
    Re: Antenna for Navigation
    Never mind... Thanks CadillacSTS2003!
    http://www.cadillacforums.com/forums...n-non-nav.html
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    lol
    np
    the one included is slightly longer allowing enough room to mount it up under the dash pad
    jjm01's Avatar
    jjm01 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac DeVille DTS
    Nov 2007
    Queens, NY
    51
    150
    If you're mounting the original GM antenna # 25731631 under the rear window package shelf, if I'm not mistaken you'll need either cable # 19115355 and # 25680475. You could fabricate your own if you can find RG-174 coax and the connectors.
    I think CadillacSTS2003 just mounts it under the defroster grille, and that way window tinting is not an issue - but check his instructions.
    Mar 2006
    Brooklyn, New York
    29
    The part number you gave for the Antenna is for a Deville. Why do you recommend using the Deville Antenna instead of the Seville Antenna? GM Parts House said it was back ordered and could not do an emergency order with out a Deville VIN. I was going to check the local dealers, but I first wanted to know why you recommend that part number -Thanks
    jjm01's Avatar
    Nov 2007
    Queens, NY
    51
    150
    GM #25731631 is the correct antenna for the Denso (not Bose) navigation radio, whether on the DeVille or Seville as well as a number of other GM vehicles that use the Denso nav.
    What number do have for the antenna? If the number you have is GM #12450683, that's for the OnStar "navigation antenna" (analog)... in the parts book "navigation antenna" refers to both OnStar and the navigation radio, so make sure you're getting the one for the navigation RADIO.
    Is this the Denso or Bose nav we're dealing with. I assume it's the Denso, in which case the antenna should be GM #25731631.
    Oct 2005
    15,987
    no such thing as a non bose nav radio in any Cadillac that ive ever herd of...
    less someone added a bose nav radio to a non bose system
    technically speaking however there is NO bose radio in any cadillac, all are delco radios, the speakers amps and enclosures are however bose
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    You can place it anywhere under the dash with the block side up, plate side down.
    Make sure to keep it away from the center speaker. All it has to do is plug in and receive sat signals.
    The Deville and Seville share the same GPS antenna connection on the radio.
    Oct 2005
    15,987
    yuh
    close to speaker
    the magnet will cause issues with the antenna
    jjm01's Avatar
    Nov 2007
    Queens, NY
    51
    150
    I realize both nav systems are Bose, but when I refer to the Bose nav, I am speaking of the first generation CD-based nav system - which for some reason I seem to recall was largely a Delco-Bose development while the later second generation DVD nav was largely a Denso development. I guess I was just digging a little deeper.
    And yes, you are correct they're ALL AC Delco... if there's any doubt warranty units come from AC Delco as do warranty returns.
    Mar 2006
    Brooklyn, New York
    29
    Quote Originally Posted by jjm01 View Post
    What do you know about this cable #19115355? I think this is all I really need!
  14. Remove Advertisements
