GMRC-03 Harness
Results 1 to 11 of 11
Cadillac Audio, Video and Security Systems Discussion, GMRC-03 Harness in Item Specific Cadillac Discussion; (1) I have been reading all the posts about the GMRC-03 harness. I'm missing something. Eveyone is saying to keep ...
    sjr56 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    11
    GMRC-03 Harness
    (1) I have been reading all the posts about the GMRC-03 harness. I'm missing something. Eveyone is saying to keep the factory HU wired and just bury it in the trunk, how do iI wire the factory HU to the harness as well as the new HU. I would like to keep the wiring as uncut as posible.
    (2) I'm replacing all speakers, HU, adding a 5ch amp , and a sub. Is ther a way of hard wiring the new HU to avoid this problem?(don't care if I have a door chime at all)
    Thanks,
    Dave
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: GMRC-03 Harness
    year
    make
    model?!??!?!
    Dec 2007
    11
    Re: GMRC-03 Harness
    '97 Deville non-Bose.
    Dec 2007
    11
    Re: GMRC-03 Harness
    I would appreciate any help I could get...
    Oct 2005
    15,987
    Re: GMRC-03 Harness
    run new wires to the speaks
    bypass everything
    run hu into the trunk and attach the purple data class wires as well as a power ground and ignition wire to it
    best way to do it
    youll avoid all headaches later like a dead battery, a/c non functional, keyless problems, and alarm issues.
    import2slab is offline Cadillac Owners Member
    Automobile(s): 97 Cadillac Deville
    Dec 2007
    Texas
    34
    10
    Re: GMRC-03 Harness
    Ok sorry to hijack this thread and beat a dead horse but I've searched and searched and there's a different answer everytime I'm pretty much in the same boat as the OP I just bought a 97 Deville non-bose system and I have a kenwood dnx7100 on the way and I'm reading that some say get this gmrc-03 harness and then I read bypass everything from Cadillacsts2003 and reading most of your audio related posts I'm sure you know your stuff maybe I'm not connecting the dots I understand running new wiring from the speakers to a 4ch amp then running it to the outputs on the receiver but the factory deck if I'm reading correctly run it to the trunk is there a specific reason why it needs to be in the trunk or can I run it to my glove box? Also the purple data class wires can you please explain that I haven't purchased a wiring harness yet I've already taken a peek at the wiring harness but left it alone for the time being, thanks for any help.
    Oct 2005
    15,987
    Re: GMRC-03 Harness
    where are you located
    ill install if your local or bring it to me
    Dec 2007
    Texas
    34
    10
    Re: GMRC-03 Harness
    Quote Originally Posted by CadillacSTS2003 View Post
    That sounds good but I live in Texas, I mean I've done installs before no problem but obviously the Cadillac is a different beast
    Oct 2005
    15,987
    Re: GMRC-03 Harness
    on the stock harness there are two purple wires
    there are for the data class 2 signal
    this is how the car knows the radio exists and is connected
    you need keep those wires as well as the ground remote and 12v power wires connected to the hu
    were ever you choose to place your stock hu is your discretion
    from there tie into the ground remote and 12v power for your new hu and run all new wires from the hu to your speakers
    thats about it
    Dec 2007
    Texas
    34
    10
    Re: GMRC-03 Harness
    ok sounds simple enough I guess if I run into any issues I'll let you know thank you fr your help I really appreciate it I'm sure you had to answer this multiple times
    Dec 2007
    Texas
    34
    10
    Re: GMRC-03 Harness
    OK i gotta bump this up again I'm taking everything apart right now the Kenwood was on backorder so instead I got a Pioneer avh 5900 being delivered today but now I feel like an idiot or a noob to installs but I'm looking at the stock harness (now mind you I don't have my new one yet it's being delivered with the deck) but how am I supposed to run these two purple wires and a ground a power wire to my stock hu? Do I leave the harness connected? Man I feel stupid
  14. Remove Advertisements
