2004 SRX - Replaced Factory Nav
Results 1 to 4 of 4
Cadillac Audio, Video and Security Systems Discussion, 2004 SRX - Replaced Factory Nav in Item Specific Cadillac Discussion; Thanks to help from members of this list, my project is complete! I didn't like the function of the stock ...
    djvirus's Avatar
    djvirus is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    Newport, OR
    33
    I didn't like the function of the stock nav system, so I replaced it! Of course, no one makes a harness kit for this conversion (in fact, many stereo places said I couldn't do it at all), but hey - when has that ever stopped someone from trying, right?
    The only thing I don't currently have is the DIC, but I am working on a way to get that back into the car (V2 of this install)
    Parts used:
    Head unit: Kenwood DNX7100 DVD Navigation Receiver
    Adapter 1: PAC OS-2CTS Radio Replace Adapter (cut harnesses)
    Adapter 2: PAC SWI-JACK Steering Wheel Radio Control Interface
    Dashkit: Metra SRX Dashkit / Black
    Antenna adapter: VW/Cadillac antenna adapter
    Headrest system: Vizualogic A-1150 replacement headrests
    Once I figured out the wiring of the stock unit, I basically just cut, soldered, and plugged everything in. The OEM GPS antenna was the same as the Kenwood one, so I just plugged in the stock one, and everything works great!
    I am looking to have a custom wood(esque) piece made to finish the look of the dash, but that is minor for now
    The Garmin developed nav system in the Kenwood is AMAZING - the best I have used.
    So - here are pics - if you have any questions or are going to do it yourself, just let me know!
    Enjoy!
    GMBOUND's Avatar
    GMBOUND is offline Cadillac Owners Connoisseur
    Jan 2007
    Detroit, Michigan, United Stat
    37
    1,661
    Re: 2004 SRX - Replaced Factory Nav
    Can the Headrest monitors control the Kenwood DVD player?
    Did you buy all your components from Crutchfield?
    Did you use your factory XM tuner.
    Ollie8974 is offline Cadillac Owners Member
    Jun 2007
    21
    GMBOUND,
    Reveived your PM, Howerver I do not have 20 poste I can not send a PM.
    To answer Your question, I installed the Kenwood in a 2002 Escalade,
    The factory changer does not work with the DNX 7100, the Kenwood does have a single disc changer, however I had MX installed so I dont realy use the changer.
    The stearing wheel contrls work. I also have hands free phone interface.
    I too like like the Garmin GPS
    Car Toys installed the unit, so I know nothing about the Installation
    moneymatt is offline Cadillac Owners Member
    Apr 2007
    1
    I have been searching for days for a similar thread, anyways I'm about to install a Pioneer z2 in place of the factory nav and I was hoping you had a wiring diagram for the gm 32 pin harness thats in there. I am also installing new speakers and a 4ch amp so all i really need is the wire colors for the vss, reverse, constant, accessory, and ground. Thanks
  7. Remove Advertisements
