help..Avic D3 install into 02 dts with stock nav - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 83
Cadillac Audio, Video and Security Systems Discussion, help..Avic D3 install into 02 dts with stock nav in Item Specific Cadillac Discussion; well the onstar prompt and voice comes on while the system is reinitializing....i can hear that. all other sound like ...
  1. #61
    mrgoodbar67's Avatar
    mrgoodbar67 is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 Cadillac DTS Deville on Vogues and DTS Blades
    Jul 2007
    Bell, CA
    32
    605
    Re: help..Avic D3 install into 02 dts with stock nav
    well the onstar prompt and voice comes on while the system is reinitializing....i can hear that. all other sound like music is muted to allow the onstar sounds.
  2. #62
    Jul 2007
    Bell, CA
    32
    605
    No Idea How To Help Huh............anyone?
  3. #63
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    sry been away my lap top is still virused up at Best Buy
    anywho
    my GUESS would be that you have to run your own constant wire from the batt to the yellow hu wire
    this will allow a bypass of the interrupt assuming it cuts the radio out via the constant not the ignition
  5. #64
    pentavolvo is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    its prly on the switched ignition side, if it were cutting out on the constant side all his setting on the radio would reset everytime this happened.
    I have an 02 DTS with the regular radio and bose. What dash kit do I need for the dbl din.
  6. #65
    Jul 2007
    Bell, CA
    32
    605
    Its Most Likely The Same Kit.
    I Think The Only Diff B/w Mine And Yours Might Be The Depth And The Radio Itself.
    The Depth In Mine Might Be Deeper From Factory B/c I Had A Factory Nav.
  7. #66
    Jul 2007
    Bell, CA
    32
    605
    Hay pentavolvo, any idea on how i can fix the problem
  8. #67
    Oct 2005
    15,987
    oh i see how it is
    ask him for help now lol
    guess im worthless
  9. #68
    Jul 2007
    Bell, CA
    32
    605
    Hahahahahaha
    No Not Worthless. You Helped Alot.
    Just Thought He Might Have Some Ideas.
    So Youll Hit Me Up As Soon As Youre Ready?
  10. #69
    Oct 2005
    15,987
    imho if it is an ignition thing you can only bypass it by connecting a constant to it in which your gonna have to run a switch or else your radio is on
    or find an ignition power which is UN affected by onstar, like the cluster power, but then you will lose your 10 min accessoy retained power...
  11. #70
    Jul 2007
    Bell, CA
    32
    605
    Well, Thanks Fellas..............i Figure That Since Im Not Going To Have Onstar Activated Soon. It Wont Be A Problem For Me Until I Decide To Re Activate It, Then Ill Attempt To Fix It.
  12. #71
    Oct 2005
    15,987
    actually
    when you have your cars VICM reprogramed for the onstar update have them set it up for your got NOT having Nav
    im betting that the fact your car is set up for nav that when you press the button the 1st time its expecting a voice command which normally mutes the radio via shutting off the amp
    ill bet beyond a doubt THATS your problem
  13. #72
    Jul 2007
    Bell, CA
    32
    605
    makes sense. i hope that fixes the sceen retarting and stuff.
    thanks
  14. #73
    Nov 2007
    i gotta agree that does make senes. how much modding do you have to do to the dash kit to get the dbl din in it
  15. #74
    Jul 2007
    Bell, CA
    32
    605
    youll have to cut the pocket out to make room for the dd i did it using a hot typ of tool then sanded everything down
  16. #75
    Oct 2005
    15,987
    so any pics of the install?
  17. Remove Advertisements
