Auxiliary Input on Seville/Deville/Catera: DIRECT connection - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Cadillac Audio, Video and Security Systems Discussion, Auxiliary Input on Seville/Deville/Catera: DIRECT connection in Item Specific Cadillac Discussion; Please take a picture with a fairly good camera (make sure the focus is ok). I don't care about colors ...
  1. #31
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Auxiliary Input on Seville/Deville/Catera: DIRECT connection
    Please take a picture with a fairly good camera (make sure the focus is ok). I don't care about colors and such so thus the best picture is the clearest picture.
    Post the picture here (only the area of the audio processor, not the whole thing).
    I believe you (should) have the same layout as in the '98+ Catera/Eldorado/Deville (base) but let’s see. Although Catera is not compatible with the other two the layout is the same.
  2. #32
    millerp is offline Cadillac Owners Member
    Automobile(s): 99 deville
    Oct 2011
    34
    3
    Quote Originally Posted by N*Caddy View Post
    http://imageshack.us/photo/my-images/80/dsc01532oe.jpg/
    thanks so much for helping me out with this.
    [IMG] By aweschitt5978 at 2011-10-07[/IMG]
    my email is millerp@umail.iu.edu if you want to email me and I can send you a better image that isn't downsized due to internet and website restrictions.
  3. #33
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The picture is PERFECT, and yes is the layout I was expecting to see. Give me until tonight and I will reply with where to solder and cut (I need to run soon).
  5. #34
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Here is EXACTLY what you need to do:
    LEFT CHANNEL:
    Notice how between pin 15 and 16 there is a connection on the PCB. You need to break that connection (use a needle and lots of patience, scratch dead in the middle where that red X. Use a Ohmmeter to make sure the connection is broken. Then solder 24 AWG wires between the pin 15 and LIN on the jack connector (follow the gray line). Do the same between pin 16 and LOUT.
    RIGHT CHANNEL
    Notice how I draw a line between pin 2 and pin 3 (I marked with a C). The two pins are connected in the same way as 15 and 16 only that the PCB connection is underneath the chip (so you can’t see it unless you remove it). VERY IMPORTANT, since you can’t cut it you need to desolder pin 2 OFF the plate and lift it a bit (not too much because it brakes easy, I am talking about less than 1 mm). Solder 24 AWG wires between pin 2 and ROUT and pin 3 and RIN (follow the red lines).
    If you wonder how it works bellow is a diagram of the chip. This chip is 2 chips in one, one part is AUDIO MIXER, or better called selector (mixing 3 stereo inputs, RADIO/TAPE/CD CHANGER) and the other side is an sound processor (EQ and volume control). The output of this chip is 2 channels (L/R) mirroring what ever the audio mixer selects (radio, tape or CD changer). The MIXER part of the chip toggles between the 3 inputs when the SOURCE button is pressed (involves the HU microprocessor and such but let’s not complicate it).
    A) Is the diagram of the chip as is from factory. Notice how the output of the sound MIXER (left channel) goes out of the chip on pin 16 and the input of the EQ/Volume control side of the chip is pin 15. Notice on the PCB how pin 15 and 16 are connected together. So basically what ever comes out on pin 16 is sent back to pin 15. The same happens for the right channel the output of the MIXER pin 3 is connected to the input of the EQ/Volume control side on pin 2.
    Remember this signal is out of the mixer and about to enter in the EQ/Volume control module, so the signal at this stage is constant, the EQ/Volume controls will modify the sound level and frequency based on the steering wheel controls/Volume knob and the EQ buttons.
    B) Is the circuit after you add the auxiliary connector. Notice how the In L pin is connected inside the AUX input connector to Out L, see the arrow where it makes contact (right channel similar). So in this situation what ever comes out of the MIXER on the left channel (pin 16) is connected to In L on the AUX connector. Inside the AUX connector L In is connected to L Out then L Out is connected to pin 15 completing the circuit (Right channel similar). So B) is not different from A) except that you have the AUX connector closing the circuit on B) rather than directly on the PCB as in A).
    C) Now you insert the AUX in male connector and observe on C) what’s going on. Inside the AUX connector the tab from Out L is pushed away from the arrow from In L so the contact between the two pins is discontinued. But if you look carefully you see that the tab from Out L is actually in contact with the AUX in male connector (left channel) so now your Out L pin of the AUX connector has the signal from the AUX male connector Left channel. This signal is sent to pin 15 and eventually is what you hear in your speakers while the MIXER output (pin 16 only goes as far as In L on the AUX connector but it stops there. (right channel similar). So basically that AUX in connector is a SWITCH.
    I hope you understand how is the AUX input working, it is super simple.
    EDIT:
    Although the pin numbers are the same on the ‘96-’97 and in ‘98+ base units, the PCB layout is different, this layout applies to ‘98+ (Deville/Eldorado/Seville) with base sound system. For the ‘96-’97 layout see my posts on page 2.
  6. #35
    jimstoicovy is offline Cadillac Owners Member
    Automobile(s): 2000 Seville SLS
    Nov 2010
    23
    3
    Is there any way i can just wire directly into this plug. I do not need use of the cd changer. Im looking for an easy way to connect an aux jack.
    2000 SLS with bose
  7. #36
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    NO, you need to emulate the signal on the data wire (actually E&D wire) so the HU will give you the option to select the CD changer as a source.
    BUT you can easily use the HU to AMP audio wires in the same idea (yeah is that simple), see my diagrams for the BOSE setup (if you have BOSE), still don't get it then see this. If not BOSE then see the picture in post #34.
    What amazes me is EVERYBODY is looking at the CD changer connector (for I don’t get what reason) when they should look at the connector behind the HU (audio wires between HU and AMP).
    BTW in the picture above the pins are wrong, pin 3 is audio COM, pin 4 is shield and the E&D wire is the last pin (10 not 9 as pictured).
  8. #37
    conmetal is offline Cadillac Owners Member
    Automobile(s): '02 Bronze Mist DTS (SOLD)'00 Black DTS w/ NV & Nav
    Jan 2010
    Suburbia South of ATL
    28
    I'm finally getting around to attempting the auxillary input mod on my '00 DTS w/ Bose Navigation & CD Changer. My first attempt has ended in failure. My pin outs on the plug are labled C & D, not E & F. Connected two wires from C9 & C10 directly to the audio jack. D16 (bottom row) is already taken by a black wire. I spliced into it assuming it is the ground and also grounded to the chassis along with the ground from the audio jack.
    I went to my local radio shack for the audio jack. Asked for part # 274-249 1/8" Stereo Panel Mount Audio Jack, however realized when I got home that I had part # 274-0248 1/8" Mono Panel-Mount Audio Jack. I went ahead and attempted the install. I'm not sure if the mono/stereo is my issue, but right now I have no aux option and skipping through the sources doesn't pickup any additional audio (connected to my mp3 player via 3.5mm male/male cable).
    Any help will be highly appreciated.
    Thanks Cadillacforums!
  9. #38
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The AUX input source thing will ONLY work on the '02+ DVD based Nav units, yours is CD bases, is unlike ANY of the solutions I provided above.
    You have 3 configurations:
    1. BASE
    2. BOSE
    3. NAV with DVD
    Although the CD based NAV unit is very similar with BOSE, the pin numbers are different. You need a FSM to understand how it works and again only expect the source selection for 3!!!!, 1 and 2 have no firmware interaction, the source selection is done hardware by the switch in the AUX input. You really need to understand how it works, especially since you try using a mono connector (big nono).
  10. #39
    Jan 2010
    28
    Awe man, really didn't want to hear that although I feared so. The mono jacks were not intended and I planned to pick up the stereo jack tomorrow.
    I can follow any directions given but not so inclined to engineering my own solutions. Now I'm wishing I would of kept the setup I installed in my previous DTS. Oh boy, now I'm trying to remember if I had saw somewhere that it was not ideal to use an aftermarket head unit with this setup.
    Thanks for the clarification and cheers to anyone who has already tackled the auxillary add-on to this setup and can lead the way.
  11. #40
    GabeISN is offline Cadillac Owners Member
    Automobile(s): 95 Cadillac Sedan Deville
    Oct 2012
    23
    1
    Can I please get some pics on how to do this on a 95 sedan Deville without Bose
  12. #41
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    In a '95 Deville with BOSE try the BOSE link, this is for NON BOSE cars.
  13. #42
    Nishiki is offline Cadillac Owners Member
    Automobile(s): 05 Deville
    Oct 2015
    41
    Hi! Hope it's ok to post - the thread is three years old.
    I have a 05 Deville with the base HU. Can an AUX input be added using your instructions?
    Thanks!
    N
  14. Remove Advertisements
