Do I really have to remove the dash?
Results 1 to 5 of 5
Cadillac Audio, Video and Security Systems Discussion, Do I really have to remove the dash? in Item Specific Cadillac Discussion; I'm the newbie who wants to know if anyone knows how to get at the front speakers in an '85 ...
    mind_stone is offline Cadillac Owners Member
    Apr 2004
    Cayce, SC
    3
    QuestionDo I really have to remove the dash?
    I'm the newbie who wants to know if anyone knows how to get at the front speakers in an '85 Couple DeVille. Do i need to take the dash off, and if i do, how do i do that? Also, if there are any little "hidden" speakers, where are they?
    JJhomer83's Avatar
    JJhomer83 is offline Cadillac Owners Connoisseur
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Re: Do I really have to remove the dash?
    well the speakers are either in the door or in the dash if they are in the dash you need to remove it and get the speakers out.
    carstereohelp.com
    that is a good website
    75pimpdeville is offline Cadillac Owners Member
    Feb 2004
    Rochester NY
    48
    Good Luck man
    If the speakers are in the dash, you do have to take the dash apart. Last Summer, I instaled a stereo, new wires cd/mp3, and front and back speakers and subs in a 75 deville. It took 4-5 weekends of work. I tried to take it to a custom place, but they said 80's and older caddies are "nightmares".
    So, its a big job and takes a lot of arm strain and work, but the result is well worth it.
    Adam
    SoundAdvantage's Avatar
    SoundAdvantage is offline Cadillac Owners Enthusiast
    Automobile(s): 87 Deville
    May 2003
    Louisville, Kentucky
    41
    630
    Quote Originally Posted by mind_stone
    Your 85' should have 4x6" speakers in the dash and yes the top section of your dash board has to be remove to do the install. The scews to remove it are behind the air vents>The air vents can be removed by pulling them straight out, then you will see the screws that remove your dash. I would replace your Factory speakers with some high quality ones. I had to do some cutting on the fiberglass inner structure on my car so the Speaker Magnets would fit. While I had the top section of my dash off I went ahead and ran new 12 guage speaker wire back to the trunk along with 3 sets of RCA jacks, a Remote wire and a 4 ga. Power wire>ONLY because i am using After Market Amplifiers> The only thing you will need to do is cut your Factory plugs off your front speaker wires and crimp 4 female connectors to the 4 wires that will go to your new set of dash speakers.
    ChiMick's Avatar
    ChiMick is offline Cadillac Owners Fanatic
    Jan 2004
    Windy Chicago
    63
    204
    I recently replaced the front speakers on my 1990 Sedan Deville and it really wasn't too tough taking the dash apart. While I was at it I re-glued a section of the padding above the speedo that had come apart. I think that the job all told took less than two hours from start to finish (and I did a lot of extra things such as cleaning the metal part of the dash, removing the fittings from the old speakers and soldering them on the aftermarket adaptors, etc.) The worst part of taking the dash pad off was that some of the screws were stubborn but a squirt of liquid wrench helped free them. Don't forget that there are two bolts (at least in mine) inside the glove box.
    I put in Kenwood 2-way speakers and they made a huge difference. As you might expect, the OEM speakers were brittle and the cone was white having been sun bleached. The 2-ways have better definition and I think reproduce the highs better. I have noticed that at higher volumes the dash pad rattles a bit but there's not much that can be done about that since the area above the speakers basically "floats".
    Just pick a nice day and dive in- good luck with your install.
  8. Remove Advertisements
