Cleaning fingerprints from the NAV screen
Results 1 to 9 of 9
Cadillac Audio, Video and Security Systems Discussion, Cleaning fingerprints from the NAV screen in Item Specific Cadillac Discussion; BION, I can't find any specific reference in the OM or NAV Manual as to what solution to use to ...
    doncapecod's Avatar
    doncapecod is offline Cadillac Owners Fanatic
    Feb 2004
    Cape Cod & Naples
    107
    Red faceCleaning fingerprints from the NAV screen
    BION, I can't find any specific reference in the OM or NAV Manual as to what solution to use to clean the screen. Any suggestions?
    beers is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Sedan (gray/black), previous 2004 CTS-V
    Jan 2004
    CA (SF Bay Area)
    49
    150
    Re: Cleaning fingerprints from the NAV screen
    A microfiber (fibre?) cloth, you can get them at most auto parts stores, Walmart or Costco. Works great.
    doncapecod's Avatar
    Feb 2004
    Cape Cod & Naples
    107
    No liquid to remove the oil from fingertips???
    riff is offline Cadillac Owners Fanatic
    Mar 2004
    159
    I remember reading that they suggest using rubber alcohol. Check one of the manuals - it's there. I'll double check tomorrow to make sure that I got things correctly so hold off for now.
    doncapecod's Avatar
    Feb 2004
    Cape Cod & Naples
    107
    Thanks, I couldn't find anything in the manuals. Closest was glass. Will also check with dealer
    Jan 2004
    CA (SF Bay Area)
    49
    150
    the microfiber cloth with no liquid added seems to take off any fingerprints just fine...
    ThomasO's Avatar
    ThomasO is offline Cadillac Owners Fanatic
    Mar 2004
    188
    I'd head for Walmart and get some of that stuff for computer screens (flat screens). It's cheap and safe
    http://www.ciao.co.uk/3M_Screen_Cleaner_675__5396285
    Mar 2004
    159
    Manual suggests using ipropyl or rubbing alcohol applied to a clean cloth. It also warns not to spray anything directly at the screen, which is really just common sense.
    Most of those 3M cleaners are exactly that - towelettes moistened with rubbing alcohol.
    MortnCyn's Avatar
    MortnCyn is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 N* Thunder Gray/Ebony AWD/NAV/MRC
    Mar 2004
    Illinois
    81
    875
    Quote Originally Posted by riff
    Agree with you even though we do not have the NAV screen. Do have computer with LCD screen and they recommend the same. Did find that I need to be sure the cloth is wet enough to clean properly. If the screen is anything like the LCD it is probably best to avoid touching the screen. Difficult to do when one has been accustomed to touching the CRT screens.
  12. Remove Advertisements
