  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Audio, Video and Security Systems
Cadillac Audio, Video and Security Systems Section for discussions in relation to stereo, navigation, DVDs, alarms, etcetera.
Cadillac Forums: Deville glove box CD changer install
Old 04-19-07, 05:36 PM
Cadillac(s): Cadillac
View pa_realtor's Photo Album
Casino Cash: $250
Newbie here -
Almost ready to install a factory 6 disc changer into an 05 Deville. Before I go hacking into the glove box like cave man is there anything online to aid the install, like instructions?
I have changer, main bracket, secondary bracket, bag of screws and a minty Deville.
Any help appreciated.
  #2 (permalink)
Old 04-23-07, 06:59 PM
Casino Cash: $250
Cool Re: Deville glove box CD changer install
OK Guys here's how it's done, should work on 01 - 05 non bose:
1. Remove trim section below glove box.
2. Remove 8 screws from glove box with #15 torx. 4 face, 2 rear, 2 upper.
3. Slide out glove box partially - unhook Valet bypass switch and remove glove box light.
5. Remove glove box. - GM has thoughtfully installed the connector for you mounted it to the rear of the glove box. It will free itself as you pull the glove box out.
6. With a box cutter or similar remove the molded filler section from rear of glove box. (I used a emory board to file down any excess edges)
7. Install cd changer rear mounting bracket to glove box using the pre-drilled holes. The bracket will only line up one way.
8. Install glove box fishing the cd changer pigtail through the new opening hook up the valet switch and light as you go, leave the 2 upper screws out.
9. Now the hard part - Plug cd changer in, it's tough to get but it can be done! whirring and clicking sound is good, mount with the 2 upper screws.
10. Re-install lower trim.
  #3 (permalink)
Old 08-16-09, 01:44 AM
godsdiablo's Avatar
Cadillac(s): 2001 Cadillac Deville
View godsdiablo's Photo Album
Casino Cash: $775
where can i get the wire for it?
Tags: , , , , ,
box, changer, deville, glove, install
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
