Seville Sound Systems
Results 1 to 10 of 10
Cadillac Audio, Video and Security Systems Discussion, Seville Sound Systems in Item Specific Cadillac Discussion; Has anyone here used the existing stereo wiring to hook up to there own stereo. I'm thinking of throwing in ...
    Budabear's Avatar
    Budabear is offline Cadillac Owners Fanatic
    Automobile(s): 2009 3.6 DI AWD Performance Package, 2003 Seville STS
    Dec 2003
    Yonkers, NY
    128
    Has anyone here used the existing stereo wiring to hook up to there own stereo. I'm thinking of throwing in my Sony head unit and my JL Audio speakers but I hate the idea of having to try to run new wiring to my doors.
    Can anyone tell me where I can find a wiring diagram for the stereo / speaker wiring in the car. This would make the job much easier and cleaner.
    Budabear's Avatar
    Dec 2003
    Yonkers, NY
    128
    Re: Seville Sound Systems
    Wow! I can't believe no one here has a clue about the factory stereo wiring.
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Bose system? The biggeast obstacle is the fact that most likely the wires going to the speakers come from the BACK of the car. Usually the headunit connects to the module in the trunk, which connects to the speakers in the car.
    Budabear's Avatar
    Dec 2003
    Yonkers, NY
    128
    Quote Originally Posted by DaveSmed
    That's not much of an obstacle! My changer and amps would be in the trunk. So, the front speaker wires are all I would need to find. I'd use better cable for my 6x9's in the trunk.
    BMcNamara is offline Cadillac Owners Member
    Apr 2004
    1
    If your looking to upgrade your system its best to use all new wiring preferably 14au or so. At higher ampiers the thinner (higher guage) wire will not handle the response and make you think your spekers are blown. I am also looking for a wiring diagram for my 97 sls but I just joined the site and haven;t asked yet... did you ever end up getting a response?
    BMc
    Lawrence's Avatar
    Lawrence is offline Cadillac Owners Fanatic
    Oct 2003
    Ohio
    334
    Budabear,
    Be carefull here and make sure you bypass the OEM amp/s.
    This may help.
    http://www.metraonline.com/locator.a...del=617&type=7
    1994 Cadillac Seville Stereo Information
    Constant 12V+ Orange
    Switched 12V+ Yellow
    Ground Black
    Illumination Gray
    Dimmer Brown
    Antenna Trigger Pink
    Antenna Right Rear
    Front Speakers 5 1/4" Doors
    Left Front (+) Tan
    Left Front (-) Gray
    Right Front (+) Light Green
    Right Front (-) Dark Green
    Rear Speakers 6" x 9" Rear Deck
    Left Rear (+) Brown
    Left Rear (-) Yellow
    Right Rear (+) Dark Blue
    Right Rear (-) Light Blue
    2003 Metra Application Guide
    1992-1995 Cadillac Seville (console shift)
    Premium Kit N/A
    Budget Kit N/A
    Custom Kit 99-2002
    Harness Into Car 70-1856
    Harness Into Factory Radio N/A
    Speaker Adapter Harness 72-4568
    Speaker Accessory N/A
    Custom Antenna 44-GM935
    Universal Antenna UT-L
    Power Antenna 44-PW22
    Power Antenna Base N/R
    Antenna Adatper to Factory Antenna 40-GM10
    Antenna Adapter to Factory Radio 40-GM21
    Outside of this all I can add is to buy the OEM service manual, www.helminc.com
    Lawrence's Avatar
    Oct 2003
    Ohio
    334
    Quote Originally Posted by BMcNamara
    BMc
    Here's the same for your 97,
    1996-97 Cadillac Seville Stereo Information
    Ground Black
    Illumination Gray
    Dimmer Brown
    Left Front (+) Tan
    Left Front (-) Gray
    Left Rear (+) Brown
    1996-1999 Cadillac Seville
    Premium Kit N/A
    Budget Kit N/A
    Custom Kit N/A
    Harness Into Car N/A
    Harness Into Factory Radio 71-2001
    Speaker Adapter Harness N/A
    Custom Antenna 44-UL15
    Universal Antenna UT-S
    Power Antenna 44-PW64#
    swimmster is offline Cadillac Owners Fanatic
    Feb 2004
    132
    the actual radio module is in the trunk.. in my Eldorado, it's right next to the power antenna... your BEST bet is to put your own amps in the trunk with RCA cables going to your head unit.. in the trunk at the radio module, you will find ALL the speaker wiring in one connector. to find them, the radio module has the same info that is up above stamped into the module cover.. Just find your speaker wires and there you go.. run them over to your amps output and you're done.. I'm getting ready to do this to my car as my stock sound system sounds HORRIBLE.
    alexinvancouver is offline Cadillac Owners Member
    4
    Quote Originally Posted by Lawrence
    Ground Black
    Illumination Gray
    Dimmer Brown
    Antenna Right Rear
    Left Front (+) Tan
    Left Front (-) Gray
    Left Rear (+) Brown
    Not always the case.
    I've spent the whole day trying to find wiring diagramm for my STS - it has two connectors and wires completly different in colours than any on diven diagramms
    here's what i got -
    1
    Yellow
    gray
    purple/white
    black
    blk
    brn/wht
    grn
    blk/wht
    grn/wht
    orange/wht
    yellow
    blk
    i'm trying to install Delco stereo from 94 eldorado also with two connectors. they perfectly fit, but wires differ and of course it doesnt work =o(
    rlewis is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Seville SLS
    May 2012
    35
    1
    Is it possible that I can get a color wiring diagram for my 1999 Cadillac Seville SLS?
  13. Remove Advertisements
