DO NOT buy the GMRC-03 interface, they don't solve the sleep mode problem!!!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Cadillac Audio, Video and Security Systems Discussion, DO NOT buy the GMRC-03 interface, they don't solve the sleep mode problem!!!! in Item Specific Cadillac Discussion; egarcia41 If you want to use the factory speakers you first have to make sure it's not factory amplified or ...
  1. #16
    BigOLak is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac Sedan DeVille
    Feb 2008
    16
    Re: DO NOT buy the GMRC-03 interface, they don't solve the sleep mode problem!!!!
    egarcia41
    If you want to use the factory speakers you first have to make sure it's not factory amplified or bose. I'm pretty sure if you don't have a factory CD player or CD changer that your system is not amplified and not bose. With that out of the way you need to scroll up this thread and find rcopp's post. Go to his homepage then to car maintenance and then to "cadillacradioandsoundinstallationnotes.html ". you'll find everything you need there including part numbers and retailers. Good luck, you can do it. I did and it worked great.
  2. #17
    K_cin_az is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ESC
    Apr 2008
    Phoenix, az
    208
    anyone who is looking to install aftermarket hu in 96-02 eldorado make sure to read this thread!!! I didn't come across it until after I had a new aftermarket installed with the grmc-03 and I got all the sleep mode problems. Luckily for me Timothyr from the board lives somewhat down the street from me and he is going to help me correct the problems by installing the factory hu in the trunk.
  3. #18
    brianroark's Avatar
    brianroark is offline Cadillac Owners Fanatic
    Automobile(s): 98 Devil, 93 Deville, 84 Cuttylac built 350 olds, Arctic Cat
    Nov 2003
    Milwaukee, WI
    35
    181
    what is all of this, i have a 98 deville base tape player, no amp no bose, should i have to do this, most of the time my car is fine, once or twice i had a problem with the alarm and trip gugage, etc resetting, also my constant power seems to not be so constant. i dont have dtcs, onstar or anything in my radio just stock radio with maybe a tech 2 function to light all leds. is this the problem everyones having? the problem didnt surface until two weeks later. the radio works fine car seemed fine then got a problem with my alarm. i ran a switched power wire to the radio and thinking about a ground now. it just seems like a big pain to do all that stuff unless you have your dtc and other functions ran through the radio. i know there is an antitheft function with the radio. talk to me.
  5. #19
    FirstString is offline Cadillac Owners Member
    Automobile(s): Deville
    Mar 2009
    38
    50
    I actually called the manufacture and explained to them what people were saying on here... you should call their tech support... if you dont install this right it will NOT work right...
  6. #20
    CadEElac's Avatar
    CadEElac is offline Cadillac Owners Member
    Automobile(s): 01 Seville STS
    Nov 2012
    Rockville, MD
    14
    i bought this damn harness for my pops' 97 eldorado and it does not hold memory and at times it won't come on at start up and at times it does not turn off either, can some body please tell me how to solve this problem!!!!
  7. #21
    Atomacelli407's Avatar
    Atomacelli407 is offline Cadillac Owners Member
    Automobile(s): 1999 Seville
    Apr 2013
    29
    39
    Hey I just got a 1999 seville sls everything run great electronics no leaks or headgasket issues, but I want to put an aftermarket headunit and 2 15s in it in it Ive done 10 systems in my 1994 seville was easy in other cars but it seems overwhelming in this car after all these stories you think its just safer to take it to best buy and let them do - thanks Alex Im in orlando fl
  8. Remove Advertisements
