ATS-V wishlist?? - Page 17
Page 17 of 25 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 LastLast
Results 241 to 255 of 373
Like Tree51Likes
Cadillac ATS-V Series Forum Discussion, ATS-V wishlist?? in Cadillac V-Series Forums; Well reading between the lines and speaking to one of the drivers from the Indy series. The TTV6 that they ...
  1. #241
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Re: ATS-V wishlist??
    Well reading between the lines and speaking to one of the drivers from the Indy series. The TTV6 that they are using in INDY is VERY balanced. If we were to do a built V6, we can make just as much power as we could with a built V8. Although I would say a V8 would be a kick in the pants given this vehicles weight.
    Thanks,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by lunarx View Post
    If balance is the desired result, thats more reason to dump the TT V6 and go NA V8.
  2. #242
    blacaddy is offline Cadillac Owners Member
    Automobile(s): CTS4 Wagon
    Apr 2012
    83
    ATS-V= ~3300lbs vehicle weight....~450hp+ V-8, naturally aspirated with ~375+lb-ft torque>>trying for around 7 lbs. per hp....choice of manual or auto.....choice of rear or all-wheel drive (get the power to the pavement ala Porsche Carerra4)... ATS-V specific performance exhaust...ATS-V specific gauges with tachometer oriented design...How about some new colors such as a real red, a dark red, dark blue and maybe a non tint white.......Kiss principle in play here with the engine choice>>>current LSA V-8's have proven it, ask the bimmer/merc guys with their "On the tech edge" motors as they are watching the taillights of a CTS-V getting smaller(usually).....And as a final wish>>>Tinman are you with me?>>>ATS-V Shooting Brake
  3. #243
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Audi Does AWD 4 doors, they have for nearly 30 years. They loose to the M3. Every. Time.
    You know why the panamera turbo S does well? (I'm assuming you meant panamera, since the Carerra is a coupe)
    because it starts @ $175K.
  4. #244
    Apr 2012
    83
    Didn't mean to give the impression I am a big Porsche fan>>> just using carerra4 as an example of a 400+hp all-wheel drive system and not the body style>>>could have used Bentley or Bugatti as examples I suppose....... not sure the drive system is what makes the WhaleAmera cost $175K>>>maybe$75K for a name and a left hand key and $100K for the engineering/car?....
    Remember we are wishing so we can wish for a 4wheel drive system that provides the fastest off the line times coupled with handling in the rarified league dominated by the CTS-V ....Good statement with the "Hot Raw Nasty Speed" M5eater >>>I like that<<<It will be fun to see what Cadillac comes up with >>>CTS-V proves they are more than capable.
  5. #245
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Big power+AWD=lots of potential drivetrain problems. Porsche and Audi circumvent this with expensive hardware. Chrysler does it with oppressive torque management. Take your pick. Unless you will be happy with an $80k ATS-V.
  6. #246
    Jinx is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 CTS-V estate
    Mar 2003
    Oakland, CA
    47
    1,243
    3300 lbs? with AWD? and a V8? The RWD car is already over 3500lbs with the V6; Camaro tells us the V8 will add another 80lbs or so. What's AWD going to add? What other strengthening will we need? I see a 400lb chasm between reality and this wishlist.
  7. #247
    Dec 2006
    42
    37,302
    The base ATS is about 3300lbs. If they make even more extensive use of lightweight materials, they could feasibly offset the additional 300lbs or so that the V would add to that. At least some of it. I would say somewhere between 3400-3500 lbs if they throw some more magnesium and carbon fiber around.
    I am betting folks would line up to buy a 3400 lbs, 450 hp, $60k ATS-V.
  8. #248
    Dec 2006
    42
    37,302
  9. #249
    lunarx's Avatar
    lunarx is offline Cadillac Owners Connoisseur
    Automobile(s): 13 911S, 10 E63 AMG
    Aug 2006
    SoCal
    1,726
    AWD??
    I doubt that is under consideration.
    They said they were targeting the M3 not the RS4.
    Besides AWD completely squashes the lightweight intent.
    For the engine, they just need to decide if they want to beat the M3 on Gas Mileage or Acceleration.
    Yes, a 3400lb 450HP $60K V8 Manual ATS-V would get me in line.
  10. #250
    Dec 2006
    42
    37,302
    yeah, no way they put awd on the V.
  11. #251
    Apr 2012
    83
    Ok, I got carried away with 3300lbs.>>>>>would you go for 3825lbs.? Puts this weight car with 450hp at 8.5lbs per hp>>>> should allow ATS-V to run with the Audi's, the M3/M5 and the AMG's >>AWD would be nice to get the hp to the pavement but JimmyH is probably correct and Cadillac won't do an AWD Vcar
    Quote Originally Posted by Jinx View Post
  12. #252
    lunarx's Avatar
    Aug 2006
    SoCal
    1,726
    I would not accept 3800lb.
    That's V1 weight.
    Its reverse progress for a smaller newer car to weigh as much as a bigger older car.
    The ATS is a tiny sedan, its weight target should be a max of 3600lb.
    It should not weigh more than the V6.
    Imagine some nice weight saving items;
    Lightweight Racing Seats
    Lightened Rear Seat Back
    Titanium Exhaust
    Forged Wheels
    2 Piece Brake Rotors
    Carbon Fiber Driveshaft
    Those things could trim an easy 100lb and save us the trouble of having to buy them aftermarket.
    To take it down another notch,
    Sunroof Delete
  13. #253
    Dec 2006
    42
    37,302
    The biggest weight savings will be lightweight wheels, and replacing steel chassis parts with magnesium, aluminum, and carbon fiber. This will all mean a much higher price. My only point is that if they can make a 3400 lbs, 450 hp sedan, people WILL pay the higher sticker price. I don't think ATS buyers would, but ATS-V buyers will.
  14. #254
    lunarx's Avatar
    Aug 2006
    SoCal
    1,726
    I certianly would pay extra for the lightening.
    However, I would not want to see lightening used as an excuse for a substandard engine.
    Suposedly they already designed the car to be lightweignt, so I wasn't expecting any chassis or suspension components to need changing.
    I'm sure the V drivetrain will be heavier and add weight.
    Even so, that can (and should be) be offset, as you pointed out.
    I still think all they "need" to do (over the ATS) is put a V8, V2 Brembos, V2 LSD, Performance Suspension, offset some of the weight gain and they would have one hell of an ATS-V.
    Any less is pathetic.
    Any more is icing on the cake.
  15. #255
    Dec 2006
    42
    37,302
    If they can keep the weight down, they won't need the V2's heavy duty brakes, drivetrain, and suspension.
  16. Remove Advertisements
