cadillac ats forums cadillac ats forums
Results 1 to 14 of 14
Thread: Sport Pedal Install
    oemtech's Avatar
    oemtech is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T-Auto /Hemi Challenger R/T-6sp/Corvette LS3-Auto
    Jul 2014
    Jarrell, TX
    75
    1,739
    Sport Pedal Install
    I just have a base model ATS so I will add the parts I want as I go. The first upgrade is the Pedal Kit. You can get the kits for about $125 shipped either off eBay or from a GM dealer.
    So, what is in the kit?
    You get a new foot rest cover, new brake pedal cover, a accelerator pedal (with controller - drive by wire) and some crappy instructions.
    Before
    After
    Tools
    1) Small flat blade screw driver
    2) #4 metric allen wrench
    3) a curved tool to help put on the brake pedal cover.
    How To
    Foot Rest
    Using the small flat blade screw driver remove the retaining clip at the top of the foot rest. Once the clip is removed push down on the tab and remove the cover. The kit provides a new lower connection plate and retaining clip. But, they are the same parts as what is already installed.
    Next take the new foot rest cover slide on the lower connection plate, making sure the bottom is in the mounting slot.
    Now push it down until the catch at the top snaps in place. Replace the retaining clip and your done. It takes all of 5 mins to install.
    Brake Pedal
    Remove the old brake pedal cover... It just pulls off. Now the fun begins. It took me at least 30 mins to get this sucker on. Why? For one thing it is not as flexible as the one you took off. Secondly you have stretch the rubber over the brake pedal. I started with on the accelerator pedal side and worked my way around the bottom to the top. You will need some sort of small curved tool to assist in getting the rubber over the pedal.
    Accelerator Pedal
    With the small screw driver remove the rubber plug the covers the hold down bolt. Next use the #4 metric allen wrench to remove the hold down bolt. Now pull back on the pedal assembly to release it from the floor. Disconnect the cable from the control box by unlocking the red release clip on the plug.
    Swap pedal assemblies, install cable connection and slide the locking clip into position. Now slide the assembly back into the floor, install the retaining bolt and the rubber plug.
    Start the car and check out the new parts.
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    Re: Sport Pedal Install
    nice write up! can we get a sticky here?
    ben.gators is online now Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,243
    Sorry if this is a stupid question, but what is the point of sporty pedal? My performance comes with these so called sporty pedals, but I don't see what type of advantage they can give and why they are called sporty!
    By the way, box says Made in Korea, but there is a Made in China label on the brake pedal!
  5. #4
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    75
    1,739
    Quote Originally Posted by Stevo Supremo View Post
    I would rather see a new forum for things like this.... Knowledge Base
    Quote Originally Posted by ben.gators View Post
    Sport Pedals sounds better than Bling Pedals and I guess you need to be a "Real Sport" to get them. OBTW - IIRC they are $230 option from GM
    Yes sir... GM contracts with Korea and they contract with China.
  6. #5
    duneless's Avatar
    duneless is offline Cadillac Owners Connoisseur
    Automobile(s): Current 2014 red CTS Vsport/ Black Raven 2013 3.6 ATS4 gone
    Jul 2013
    Connecticut
    43
    2,879
    I like them. They look much better. Sporty you know!
  7. #6
    prozac26 is offline Cadillac Owners Member
    Automobile(s): 2015 ATS Luxury V6
    Jan 2016
    Oshawa, Ontario
    12
    Sorry to bump this thread, but does anyone know if this part number GM 22935043 will work on a 2015 ATS?
    Thanks.
  8. #7
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    75
    1,739
    The parts suppliers I check does not show this option for the 2015.
  9. #8
    Jan 2016
    Oshawa, Ontario
    12
    Quote Originally Posted by oemtech View Post
    Is there a kit for the 2015s?
  10. #9
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    75
    1,739
    I would suspect there is. Check with your dealer parts guy.
  11. #10
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    My 15 performance coupe has them so they have to be available. I believe the factory set on eBay says all years and models. I don't think it's unreasonable to think they would be the same. By the way, the ebay seller has them for almost half of factory price and they are the same GM part number.
  12. #11
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    75
    1,739
    $108 at Shop Chevy Parts.
  13. #12
    B0bcat79 is offline Cadillac Owners Member
    Automobile(s): ATS 2.0 turbo luxury
    Jan 2016
    4
    Just put these on. Brake pedal fit just like the original. Gas and footrest needed to be screwed on. Install took about 10 minutes. Got them off of eBay for $44. They from China.
  14. #13
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    75
    1,739
    Quote Originally Posted by B0bcat79 View Post
    [iurl="http://www.cadillacforums.com/forums/attachment.php?attachmentid=372345&d=1457564809"][/iurl]
    Yup... did the same thing to my 83 Monte Carlo SS.... $20 from China via Wal Mart. lmao
    The reason I did this originally was to get a factory look.
  15. #14
    CADILLACATS2013's Avatar
    CADILLACATS2013 is offline Cadillac Owners Fanatic
    Automobile(s): ATS
    Oct 2013
    383
    I bought the aftermarket knock offs from china on eBay. It took me about 10 min to install. I have aluminum trim interior with the etching on them that got discontinued and think the finish of the pedals works well with all that. I did not have a retaining clip holding the foot rest on...in fact it was held in place by some silicon (least it looked like silicon to me). I pushed down on the tab above and pulled hard and the glue gave. The stainless cover actually is better as it uses clips to hold it in place, not glue. The brake pedal came off in a minute and took a couple more to put on. As for the gas pedal, well its not as fancy as the Cadillac whole component replacement, it is just a slide-over cover so that took about 10 seconds to put on. I think it looks nice, it was like $40-$50 and the easiest install/mod yet. Required zero tools. Here are couple o pics.
  • You may not post replies
