Burnouts/ traction control
cadillac ats forums cadillac ats forums
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Like Tree3Likes
Cadillac ATS Technical Discussion Forum Discussion, Burnouts/ traction control in Cadillac ATS Discussion Forums; Does everyone else have an issue with getting the car to sit still for a smokey burnout? I turned off ...
    n2o-3.6-ATS's Avatar
    n2o-3.6-ATS is online now Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 3.6L
    Jun 2014
    Largo, FL
    33
    128
    Does everyone else have an issue with getting the car to sit still for a smokey burnout? I turned off traction control and stabilitrac and shortly after it started to really spin it shut down. I know hitting the gas then brake shuts it down. But from what I read hitting the brake first then the gas should work. Either the rear brakes over power the engine or there is something else shutting it down but I'm not sure what. Anyone have a fix for it? Other than letting off the brake for a rolling burnout. Once it started to spin I let off the break and it was almost instant redline so I shifted and did a descent second gear burnout. But I was looking for a stationary smokey burnout for a video.
    Bryce2.0T is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0T Standard
    Mar 2013
    26
    309
    Re: Burnouts/ traction control
    Ive spun in the snow for hundred of feet trying to rock the car, bouncing the tach off the rev limiter with no issues. You're holding the TC off button for 5 seconds right?
    Jun 2014
    Largo, FL
    33
    128
    Quote Originally Posted by Bryce2.0T
    Yes till stabilitrac is off too. In the rain with no issues I've slid all over the road 1st,2nd 3rd gear no problem. Even dry roads around corners slide ways. But trying to power break the car for a burnout not moving forward it wouldn't do it. Couldn't find anything in the HpTuner that would shut that off. So I'm just wondering if it's really strong back breaks which I doubt or another safety feature that I'm missing
  5. #4
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    65
    4,421
    Where are the Cadillac Customer Service reps when we need them the most?
    ben.gators, donavo and Bryce2.0T like this.
  6. #5
    Maxplot's Avatar
    Maxplot is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Premium ATS 3.6 - Crystal Red, 2013 SRX Platinum Ice
    Jul 2013
    Kansas
    286
    Quote Originally Posted by Hoosier Daddy
    +1. Has anyone shopped for new tires for their ATS? There is no way I would be talking burn out at the price of these tires.
  7. #6
    sqkid89 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0L Performance RWD
    Oct 2012
    Lowell, MA
    373
    Quote Originally Posted by Maxplot View Post
    Just got 2 new ones because I kissed a curb with one (ugly, but structurally sound) and one had a bubble in part of the sidewall and tread. The tire shop was surprised how much tread was still left on everything with 20k.
  8. #7
    Jun 2014
    Largo, FL
    33
    128
    Found it. Torque Managment- brake torque limit
  9. #8
    smurfkiller is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0t luxury
    May 2014
    Woodlands (houston) TX
    33
    231
    i have no prob melting the tires in mine. 14 2.0t auto trans.
    put it in sport mode T/C off shift over to manual mode keep it in 1st hold the brake , floor it and it will make storm clouds. im trying to kill these stupid run flats. new wheels n tires should be here next week.
    what it wont do is donuts.
  10. #9
    donavo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0T MANUAL
    Feb 2011
    Los Angeles, California, Unite
    24
    1,293
    Quote Originally Posted by smurfkiller View Post
    no LSD?
  11. #10
    Jun 2014
    Largo, FL
    33
    128
    I found the car has a brake torque limit from the factory set at about 2250 rpm. So when it was spinning with the brake on and hit 2250rpm the computer shut it down. Once I raised that it's good to go. Big smokey Burnouts now. I know it will go sideways around corners with no problem but haven't tried donuts yet
  12. #11
    May 2014
    33
    231
    Quote Originally Posted by donavo View Post
    no LSD?
    ok i only tried once so far and not very hard , maybe later n get it on video. right now im in th emiddle of eibach install.
  13. #12
    ILoveJuicySteak's Avatar
    ILoveJuicySteak is offline Cadillac Owners Member
    Automobile(s): Ats 2.0t
    Apr 2014
    44
    I hope you are not driving an automatic and thinking you can do a mad burn out.
    If it's a manual, you should have no problems spinning those tires.
  14. #13
    Jun 2014
    Largo, FL
    33
    128
    Some of the opinions on this forum are just funny. You are right my automatic didn't do a first and second gear burn out with no problem. I should probably get a manual
  15. #14
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,348
    lol Automatics are a pain for burnouts (unless you have a high Tq V8), I had a manual and could roast the tires all day (in theory) just rev the bish up to like 3.5-4K, dump the clutch and modulate the brakes
    Also, you better have the limited slip diff or it'll just be sad
  16. #15
    May 2014
    33
    231
    i did a killer smokey burnout after i finshed installing the lowering springs. car takes no time at all to start spinning the rears. rpm is not limited to 2250 i saw atleast 4500rpm left a nice set of marks in front of the shop. looked just like tmenees marks just a lil more sideways
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
