http://i57.tinypic.com/692gyt.jpg
http://i57.tinypic.com/352n94x.jpg
http://i57.tinypic.com/zwzrix.jpg
http://i58.tinypic.com/r22988.jpg
images are attached above
TRIFECTA presents: Cadillac ATS 3.6 LFX MY2013/MY2014+ Supercharger Powerkit (TRIFECTA T50)
This release post is a presentation of the engineering capabilities of TRIFECTA Performance: TRIFECTA presents an integral supercharger powerkit (T50) for the MY2013/MY2014+ Cadillac ATS LFX. You're looking at the "fastest MY2014 Cadillac ATS LFX in North America" (as of June 20th 2014). The TRIFECTA Cadillac ATS LFX MY2013/MY2014+ Supercharger powerkit is complemented by a TRIFECTA powertrain power delivery profile software recalibration, providing specific power increases of +175 ft-lbs (Peak gains of +129 ft-lbs) and +168 WHP with a completely stock Cadillac ATS LFX/6L45 MY2014 AWD donar vehicle.
Design parameters (and specifications) of the TRIFECTA Cadillac ATS 3.6 MY2013/MY2014+ LFX supercharger powerkit and corresponding ECM software reprogramming:
-Gains of +175 ft-lbs and +168 WHP (on 91 octane, Peak gains of +129 ft-lbs and +168 WHP)
-Vortech V2 Si / (V2 Ti optional) supercharger head unit (Vortech V7 and V3 TBA)
-Supercharger bracket CNC machined from 7075-T6, FEA/CAD designed for optimum critical strength and weight effectiveness
-High efficiency bar and plate air to air intercooler
-Optimum belt wrap around the supercharger pulley, >190 degrees of belt wrap
-Belt routing reuses the OE accessories, retains use of OE harmonic balancer
-Does not interfere with Air Conditioning system performance
-Retains the OE catalytic converters and maintains emissions readiness
-No cutting or splicing of any OE wiring; adapter and extension harnesses are included
-Retains the OE PCV system; maintains emissions readiness
-Fits under the stock hood
-Retains the OE belt tensioner for extended belt lifespan and engine accessory lifespan
-Idler pulley design utilizes 76mm idler pulley diameter and severe duty rated ceramic ball bearings for increased belt life and idler pulley longevity
-Designed to be silent and reliable: without increased interior NVH during vehicle operation
-Includes an aFe Pro Dry S synthetic media high air filer (K&N filter optional)
-Utilizes a Turbosmart recirculating bypass valve for accuracy of metered air
-Powertrain calibration has been tested and validated for various environments, such as cold/heat and elevation
-Extended testing of 100,000 miles with 100 hrs of wide open throttle testing
Specifications of the corresponding TRIFECTA ECM software reprogramming for the TRIFECTA supercharged Cadillac ATS 3.6 MY2013/MY2014+ LFX :
-Proprietary TRIFECTA 3.5bar operating system maintains accuracy of the metered air and air pressure to 3.5bar
-Powertrain calibration has been tested and validated for various environments, such as cold/heat, elevation, and variations in fuel quality
-Power feels linear and immediately responsive
-Retains all GM OE diagnostics and ECM functionality
-Retains all OE error code reporting and functionality
-Emissions readiness checks are present; maintains emissions readiness
-Maintains functionality of ABS and TC systems
-Proprietary TRIFECTA OS maintains OE functionality of the Haldex AWD system, with rebalanced torque biasing
-Knock detection mechanisms and OE engine knock detection sensitivity is retained
-Cold start performance is flawless and vehicle start is immediate
-Return to stock functionality included with flash loader
Specifications of the TRIFECTA Performance MY2013/MY2014+ Cadillac ATS 3.6 Hydra-Matic 6L45 6-Speed automatic transmission TCM calibration software reprogramming:
-Supplementary 6L45 transmission TCM reprogramming compliments the ECM reprogramming and completes the TRIFECTA Powertrain Calibration: designed to work in unison with the ECM reprogramming for optimized performance
-Improved shift times in adverse shift patterns
-Improved shift logic
-Does not shorten transmission life or increase cooling requirements
-Retains all OE diagnostics and TCM functionality
-Improved fuel economy with improvements made to torque converter slip profiles
Installation Notes:
-Estimated installation time of ~6 hours
-Requires front bumper removal (intercooler installation)
-Does not require lift for installation
-No cutting, splicing, or soldering of OE wiring; adapter harnesses are included: OE plugs
-Premium fuel is recommended, but not required
Dyno sheet: TRIFECTA T50 Supercharger Powerkit LFX dyno graph (91 octane pump gas) (this vehicle is a 2014 Cadillac ATS Premium with a LFX 3.6 engine) - stock wheels/tires:
http://i59.tinypic.com/27zhoj6.jpg
Additional information and availability:
-Please contact TRIFECTA Performance: info@trifectaperformance.com or visit WOT-tuning: www.wot-tuning.com for more information
-This supercharger powerkit and corresponding powertrain calibration is available exclusively through TRIFECTA Performance and WOT-tuning; (as of June 20th 2014): wholesale inquiries are welcome though provided that you are an existing and active TRIFECTA reseller
-This supercharger powerkit includes a TRIFECTA powertrain calibration file specific to your vehicle and includes a flash loader device
-Powertrain calibrations currently exist for North American vehicles only, with more regions to follow
-Pricing TBA
