cadillac ats forums cadillac ats forums
Results 1 to 12 of 12
Thread: Confused: HID and LEDs installs
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    920
    Confused: HID and LEDs installs/Worth the money?
    EDIT: Got the answers and would like you to respond to my last post...Post #3-Worth the Money?
    Well, as I'll be into my ATS for several years, why wait to install HIDs and LEDs into my '13 Lux? I probably could do them myself, but most likely will have some mechanic do it, but I need some help before I start the project.
    Although there is an excellent DIY and a lot of comment on these installs, I'm still somewhat confused about several issues.
    1. I'd like to have DRL, but do they work with the HIDs or with the LEDs installed in the brake duct?
    2. I've seen where some have flickering DRL. Of course I don't want that and which parts should I get to make sure that this won't happen?
    3. I don't mind spending a little extra, so regardless of cost, which brands HIDs and LEDs would be the most reliable and longest lasting?
    4. As I would like to have "daylight" brightness, am I right in assuming that the bulbs for the HID ad LED both should be at 6000K?
    5. Assuming that an indy mechanic will do both installs, what would be a fair price...figuring it would take around 2 hours?
    Ancient Mariner's Avatar
    Ancient Mariner is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS4 3.6 Performance
    Jul 2013
    NL, Canada
    346
    Re: Confused: HID and LEDs installs
    Re question 1, my DRL's work with the LED's (Canadian model if that makes a difference). Sorry can't help with the rest.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    920
    Worth the money?
    Quote Originally Posted by Ancient Mariner View Post
    Thanks, AM. Been checking around some more and now see that the DRLs work through the LEDs in brake duct, and that the HID are for high/low beam. Now to get some good product recommendations. Want this stuff to last as I'm into the car for 7 years, which I don't really mind as I had my '02 325i (with sport package) for 11 years. When I like a car, I love it...
    I've contacted a custom shop to do the work. They say it will take 2 hours labor for the install of the DRL LEDs and HIDs. The HIDs they use are the HID 9012 6K Bixenons from Race Sport (http://racesportinc.com/main/page_pr...sion_kits.html). Anyone hear of them?
    As for the LEDs, they use Eurolite TF-1060 (clear lens)/TF-1065 (smoke lens)... (http://www.sherco-auto.com/eurolite.html...which would be better, clear lens or smoke lens?
    In costing the job out, it seems pretty fair: HID kit @$200, labor @ $50, LEDs @$88, labor at $112 , for a total of $450. The shop has been around for 20 years and was recommended by a very trusted bodyshop guy. They will have the LEDs looking flush and all labor and parts is guaranteed by them. I know if I wasn't so old and lazy I could shop around and probably find a better price on the HIDs and LEDs and do the job myself. But I figure that for a few extra bucks I won't have to sweat it...
  5. #4
    Kalibr's Avatar
    Kalibr is offline Cadillac Owners Member
    Automobile(s): 2016 Cadillac CTS 2.0T Luxury
    Sep 2006
    West Palm Beach, FL
    72
    Re: Worth the money?
    Quote Originally Posted by flycaster View Post
    Hey flycaster, I see you're in Boynton - I'm in Lake Worth. Would you mind sharing the shop you were recommended?
  6. #5
    Renovatis is offline Cadillac Owners Member
    Automobile(s): 2016 ATS
    Jul 2013
    Ann Arbor, MI
    30
    27
    I think that is a very reasonable price for labor. It sounds like the shop knows that they are doing. If they are supplying and installing everything, they should stand behind the products and their work should anything go wrong. Most problems people run into with HID/LED's are caused by the install. As long as all the connections are solid, equipment secured and tucked away from the elements, you shouldn't have much to worry about. Should any problems occur, always start with a power/volt probe. I found that some of the connectors in these kits aren't always the most secure.
    If you like the look and functionality of them, I would say it's definitely worth it.
  7. #6
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    920
    Quote Originally Posted by Kalibr View Post
    No problem:
    Custom Car Works
    321 N.Congress, Delray
    279-0045
    BTW, I may hold off on the HIDs, but go with the LEDs first. Only questionon the LED DRLs is how they handle the switch from my present headlight DRL to the LED DRL. My SA said he really didn't know how that would be handled, but did caution that the different voltage required by the LED may screw things up a bit??? Will have to check more carefully about this aspect. Although, it is my naive assumption that all one had to do was unprogram the present headlight DRL.
  8. #7
    pissedoffwookiee's Avatar
    pissedoffwookiee is online now Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    4,145
    No problem:
    Custom Car Works
    279-0045
    there is no switch or transition, the DRL in cars without the advanced headlight cluster is the same as the hi/low beam, and a light intensity lower than the low beam for DRL use is achieved by the BCM sending a modulated pulsed power to the low beam, this is why some hid systems have problems. in the past the DRL was handled by a set of fuses and relays in GM cars and you could disable by just pulling a fuse, in our cars this is handled by the BCM, and would require reprogramming to disable.
    My BCM was reprogrammed, in order to add remote start, and the process for reprogramming went as follows:
    -remote start kit includes authorization code
    -tech calls gm and gives auth code and my VIN
    -gm creates new custom program and saves on file
    -tech inputs my vin in scan tool and updates it from gm
    -scan tool downloads my program
    -scan tool plugged into car and car updated
    -voila!!!! i have remote start
    gm does it this way in case for some unforeseen reason my bcm dies a replacement is installed and reprogrammed with what gm has on file exactly as it should be remote start and all.
    so to disable your DRL you would need a willing dealer,and a willing GM, and its doubtful either would be willing to kill a safety feature on request.
    so after your custom shop is done you will have 2 drls operating, if you decide you want the original one off just twist the left stalk to turn off automatic headlights, but you will have to do this at every vehicle start.
  9. #8
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    920
    Quote Originally Posted by pissedoffwookiee View Post
    Ugh! Thanks, POW, for the detailed explanation. Interestingly, when I got the car, I think-but not 100% sure, that I requested that the DRL function be turned on. But, I guess I should check whether or not the ATS Luxury was factory programmed for DRL??? And if it wasn't, then I can make the case to have the DRL deprogrammed. In other words, if DRL are not factory programmed, then it isn't a safety issue.
    The reason that I'd like to have the headlight DRLs off is that as my headlights are stock and not xenon, I don't think it would look nice with LED DRL and halogen DRL on at the same time. But, then again, at night I would have the two non-complimentary lights on... Of course, I could easily solve this and have xenon HIDs installed with the LED DRL???
  10. #9
    Mar 2013
    Carlsbad, CA
    4,145
    If that dealer told you they turned on the DRL they lied to you because we all have DRL in some form (led or halogen) and they are automatically on at every start
  11. #10
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    920
    I stand corrected as I probably misunderstood the dealer and also I had a BMW mindset: I know that when I got these cars, I had the dealer program DRLs into the car. So, I naturally thought that the same thing was happening with the ATS.
  12. #11
    Mar 2013
    Carlsbad, CA
    4,145
    no worries, just trying to look out for a fellow ATS owner, i'm still surprised when you said that to them they let you still believe they did something for you that didn't need doing.
  13. #12
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    920
    This all could have been fabrication on my part. I'm not really sure that they had actually said that they would program the DRLs...once again, it could have been my assumption colored by my previous BMW experience. I've got a good SA and I don't want to place a negative comment when it isn't deserved.
  • You may not post replies
