ATS 2.0 willl not start after sitting overnight
cadillac ats forums cadillac ats forums
Results 1 to 13 of 13
Cadillac ATS Technical Discussion Forum Discussion, ATS 2.0 willl not start after sitting overnight in Cadillac ATS Discussion Forums; Yesterday I get out and try to start the car it will not start sounds like a dead battery I ...
    romanats is offline Cadillac Owners Fanatic
    Automobile(s): ats
    Apr 2013
    352
    Yesterday I get out and try to start the car it will not start sounds like a dead battery I kept trying and after like 6 times it started up. Thus morning same thing but this time it would not start I had to give it boost from my other car. The car is 5 months old can it really be bad battery or something draining it.
    ATSFL is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T base
    Jun 2013
    Zellwood, FL
    156
    Re: ATS 2.0 willl not start after sitting overnight
    when you jump it it starts right up? could be a loose connection somewhere on your car.
    Automobile(s): ats
    Apr 2013
    352
    yes it started right up
    I installed auto dimming mirror and connected it to one of the map lights could it be draining there ? also have HD s they were plug and play
    and the last thing I have is LED DRL lights which are connected to the side markers.
    I have had all these for a while no issues I went on vacation 2 weeks ago and the car was sitting for a week and after started right up.
  5. #4
    Jun 2013
    Zellwood, FL
    156
    ah, that sounds like it might be it. I think the map lights are always "hot," you have to find something that is "accessory only" power. something that only gets power when the key is in the "on" position, that is running, or when you press the button without your foot on the gas to go int accessory 2.
    sounds like the mirror is always on and it's draining the battery.
  6. #5
    Automobile(s): ats
    Apr 2013
    352
    the mirror has a green light when its on when I turn the car off the and lock it the light on the mirror turns off also. Today I unplugged the mirror lets see what happens tomorrow morning. I don't really want to bring it to the dealer if its my fault I need to do process of elimination first. Also if I disconnect the batter for over night and connect it back is that a good test also ?
  7. #6
    ddawson is online now Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS PREMIUM SEDAN 3.6 RWD
    Oct 2007
    1,000
    Sometimes, a little knowledge is dangerous. Be careful not to set your new car on fire.
  8. #7
    Automobile(s): ats
    Apr 2013
    352
    thanks for your advice i wish it did catch on fire and burn to hell with all the issues it has at 4k i will not be dessopointed if that happens.
  9. #8
    GJB's Avatar
    GJB
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,260
    Quote Originally Posted by romanats View Post
    As for the Battery it’s not that uncommon to have a cell go bad early so you may just want to go get the battery tested before you go any further in your troubleshooting. If you disconnect the battery you will most likely lose your CUE settings back to factory default but that may have happened already.
  10. #9
    Automobile(s): ats
    Apr 2013
    352
    any auto parts place like Auto Zone or Advance Auto should have the battery testing equipment ?
  11. #10
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,260
    yes or any auto shop near by, it may cost a couple of bucks but it give you an answer and if bad you go to the dealer and get a fresh replacment.
  12. #11
    Automobile(s): ats
    Apr 2013
    352
    thank you
  13. #12
    Cadillac Cust Svc's Avatar
    Automobile(s): All Cadillac vehicles!
    Mar 2010
    Michigan
    11,973
    Hello romanats,
    I apologize that you are experiencing this concern with your ATS not starting. I do see that you are attempting to diagnose the issue yourself and are planning on taking it to the dealership when you figure out what the issue is. Please private message Laura or I if you would like any assistance working with the dealership in regards to this concern. I look forward to seeing your updates regarding this issue. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
  14. #13
    Automobile(s): ats
    Apr 2013
    352
    Took the car to the dealership yesterday they called me back today saying they replaced a battery.
    I had couple of other issued with poor fm signal and also loud bang over road bumps. i will let you know what was fixed.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
