cadillac ats forums cadillac ats forums
Page 1 of 4 1234 LastLast
Results 1 to 15 of 55
Thread: Regular vs. Premium Gas
    rblack77 is offline Cadillac Owners Member
    Automobile(s): ATS 3.6 Premium and SRX Luxury
    Jun 2013
    Lantana, TX
    5
    I'm wondering if there is any benefit to using premium gas in my ATS. I have a 3.6 V6. The dealer said premium is recommended, but I could use either. Can I expect any benefit from premium?
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    4,146
    Re: Regular vs. Premium Gas
    Quote Originally Posted by rblack77 View Post
    Nope, your dealer needs retraining, here are the recent cadillacs that use premium:
    ATS 2.0T (recommended for full power, but can use either)
    SRX turbo (required, had a recall for people who damaged the engine using regular)
    CTS-V all bodies (required)
    Escalade (premium or E-85 recommended for full power, but can use regular)
    STS-V (required)
    XLR-V (required can cause check engine light if not used)
    STS
    bottom line, one of the things Cadillac is proud of is that your 3.6 uses regular gasoline they mention this pretty often as a selling point vs the Germans.
    EDIT......GM puts a label on the Fuel door if the vehicle has special requirements, no label=regular just follow the fuel door and you'll be golden.
    What I will never understand are people who insist on using regular knowing full well they bought a car that asks for premium. At about $.20 a gallon more for premium, a weekly fill for my 16 gallon tank costs me $3.20 or $166.40 a year if that bothered me I would have bought a different car, instead I bought what makes me smile, and that's pretty cheap proper care and feeding for my ride.
    Enjoy that sweet V6 and smile bigger at the BMW next to you every time you buy the cheap gas
    GJB's Avatar
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,608
    Regular is recommended in the 3.6 and Premium is recommended in the 2.0. You can run either car on regular or premium. I stick to the recommendation and in the case of the 3.6 there should be no benifit running premium if your car has not been tuned or modified to where premium would be recommended.
  5. #4
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    you'd be pissing away dollars
  6. #5
    Jun 2013
    Lantana, TX
    5
    Thanks guys. Just checking to see if there was any benefit to the premium. I agree that I hate the idea of filling with premium when I don't have to.
  7. #6
    Mar 2013
    Carlsbad, CA
    4,146
    Total agreement here, if I have to, I don't care I chose the car......if I don't have to why the hell would I?.....the 2.0T is interesting, because the recommended rating doesn't mean I strictly have to, but i bought a car with 272 ponies not 260 or 250, why would i hamper myself like that, it'd be like buying the nicest running shoes but leaving the laces off because i could. it seems to me throwing your performance out the window like that (shoes or car) is a bigger waste of money than the pittance in extra gas money, it'd be wiser to buy the base engine or flip-flops.
  8. #7
    GJB's Avatar
    May 2013
    Northern VA
    1,608
    Quote Originally Posted by pissedoffwookiee View Post
    on target... Had I purchased the 2.0T premium is what I would use. Strictly from a fuel cost perspective the 3.6 with regular gas has lower MPG ratings than the 2.0T but regular vs premium does ofset some of the additional fuel cost associated with lower MPG.
  9. #8
    Mar 2013
    Carlsbad, CA
    4,146
    Quote Originally Posted by GJB View Post
    here's a wrinkle for you.....what you say is true, but to achieve that with the turbo requires the kind of discipline many if not most buyers of performance engines don't possess, so in the real world 3.6 buyers have an easier time and are therefore much more likely to achieve a higher average mpg. that big flat torque curve is more tempting to us than a room full of treats to a 6th grader, and costs us dearly vs your more progressively torqued v6 and a more powerful engine can achieve better fuel economy by virtue of doing the same work with less throttle.
  10. #9
    GJB's Avatar
    May 2013
    Northern VA
    1,608
    You definitely need to decide what kind of driver you want to be before making your trim/engine decision. Once I decided I did not want another MT due to DC traffic I decide the 3.6 was best for my situation and the regular gas was a bonus. Now if I could just get a 2.0T/MT for the weekends....
  11. #10
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Considering the 3.6 is D/I and most premium grade gas use more detergent than regular or mid-grade, I'd be using 93, if I planned on keeping the car. Carbon buildup is a nasty thing. If you absolutely can't be bothered with a $150 premium on gas every year, at least make sure you get top-tier grade gas.
    You need to lay off the giggles-pedal. I don't hypermill at all, drive through 15-20 of stop and go out of my 30-45 minute commute(one way) every day, go WOT several times, and I manage 24 mpg (the EPA rated) very easily. So do a lot of other 2.0T owners.
  12. #11
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    810
    I only use premium but the difference locally is 40-50 cents/gal. E85 is $0.20 less than regular/gal so I am setting my car up as a true flex fuel vehicle. Vtuner has a package for this with the GM fuel sensor, wiring, and tune.
  13. #12
    cdp is offline Cadillac Owners Member
    Automobile(s): ATS 3.6 Premium. Opulent Blue
    May 2012
    Texas
    70
    E85 will get you much worse mileage than traditional gasoline, so you may actually be worse off after the change.
  14. #13
    Apr 2012
    46
    Um, GM would allow you to own two ATS's ...
  15. #14
    Aug 2010
    S FL
    810
    Quote Originally Posted by cdp View Post
    If you do most of your driving around town and are retired (as I am) mpg is not a big factor. E85 will allow more hp as it cools the combustion chamber and allows more boost before timing gets pulled.
  16. #15
    GJB's Avatar
    May 2013
    Northern VA
    1,608
    Quote Originally Posted by M5eater View Post
    M5eater, when you say "plan on keeping he car" how long were you thinking? I agree that top tier premium has the detergents and additives you do not get in the "value brands". I've also been told to switch between the brands because they use different additives and there are negatives to using the same brand all the time because even the additives can have some negative qualities. Too much of a good thing scenario. Does anyone have any info on that?
  • You may not post replies
