cadillac ats forums cadillac ats forums
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Limited Slip Differential
    CZ4 is offline Cadillac Owners Member
    Automobile(s): ATS 2.0 Turbo
    May 2013
    30
    Do I have one on my car?
    2013 2.0T RWD Luxury AUTOMATIC
    GJB's Avatar
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,608
    Re: Limited Slip Differential
    Cadilac site shows it as available but I would check your window sticker. If you have it it will be listed.
    http://www.cadillac.com/ats-luxury-s...equipment.html
    May 2013
    30
    Never got a window sticker with my car.
    Canadian site lists: http://www.gm.ca/gm/english/vehicles...ons#mechanical
    Differential – Rear, limited-slip (RWD only) Optional
    7 - Included with available 6-speed manual transmission with 2.0L turbo only.
    8 - Included with 3.6L engine.
    I've also read from numerous sources online stating all 2.0T RWD have the LSD, which contradicts the above.
    Dealership don't know anything, so I won't bother asking them.
  5. #4
    GJB's Avatar
    May 2013
    Northern VA
    1,608
    It is only standard on the Premium Trim RWD cars so the statment that all 2.0T RWD have LSD is not consistant with the Cadillac site. Now could that option be included on all/most Canadian models because of reigon like heated seats seem to be on most models sold in the northern states, sure but it would still be an option. If you can't get a conformation you will find out first time you drive in mud or snow.
  6. #5
    CTSCHICK Guest
    All you have to do is look on your Rpo code sticker in the trunk for G80 if it has it then you have limited slip if it doesn't have then you don't have it
  7. #6
    May 2013
    30
    Quote Originally Posted by GJB View Post
    That's what I want to avoid.
    Quote Originally Posted by CTSCHICK View Post
    Thanks, I'll take a look after work.
  8. #7
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    when I was ordering my car I was told the LSD only came with the Manual or it comes on the PREMIUM level automatic
  9. #8
    miguelius is offline Cadillac Owners Member
    Automobile(s): Silver ATS Performance 2.0T manual
    Dec 2012
    Denver
    68
    Steve S is correct. LSD (the pavement-altering kind, not the mind-altering kind--ha, ha) is available on all manual transmission cars, including the base turbo, but on automatics it is only on the Premium RWD.
  10. #9
    Feb 2013
    1,347
    ^ and if you have a look here...
    http://media.gm.ca/media/us/en/cadil.../ats/2013.html
    On all Fe3 suspension models, A.F.A.I.K thats the MRC, which, is only available on the premo level.
  11. #10
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by Stevo Supremo View Post
    Both the 2.0T and 3.6, open or mechanical LSD, automatic or manual, use the same 3.27 gearing.
    IE,
    if you really want to make your parts counter happy, i'm sure it's simply a matter of direct swapping the pumpkins. I might do a visual inspection to verify the flanges are the same, but otherwise...
  12. #11
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,085
    Quote Originally Posted by M5eater View Post
    IE,
    Simple unless they also needed different sized drive shafts for the same reason they needed a bigger, stronger diff. Fingers crossed.
  13. #12
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by Hoosier Daddy View Post
    stronger diff?
    I'm not aware of any differential differences.
    pun intended.
  14. #13
    xtheunknown is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.5L
    Dec 2012
    56
    OK, this question is going to make me look stupid, but I thought traction control and stability control WERE limited slip differential. Clearly this is not the case, so what is the difference (not mechanical, operational.)
  15. #14
    Feb 2013
    68
    6,085
    Quote Originally Posted by xtheunknown View Post
    You can simulate limited slip with electronics, namely applying the brake on a spinning (fastest rotating) wheel. But The ATS does not have that and of course that way has its own up and down sides.
    The LSD in the ATS is mechanical and I believe is a clutch pack type. Friction between the clutches has the effect of slowing down the faster spinning axle and speeding up the slower spinning axle.
  16. #15
    xxxxxxxxxxPasATS Guest
    What they call an electronic Limited Slip Differential (eLSD) is where the computer uses the rear brakes to simulate the function of a mechanical LSD. It uses the brakes to stop or slow the wheel with less traction, moving that torque to the other wheel through the open diff. This is what BMW uses in all cars that are not "M" series and I must say it works pretty well most of the time (I have done more than a dozen tracks days in my BMW but have not driven in snow or mud). However, if you utilize it a lot you will go through rear brakes faster than normal. Also, it's a "reactive" system, meaning that the wheel has to start slipping before the computer can start apply the brake to it. I have not seen a description of the type of mechanical LSD that Caddy uses in the ATS (e.g Torsen, clutch pack, ramp style, etc.).
  • You may not post replies
