Baffle in ATS Intake
cadillac ats forums cadillac ats forums
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Like Tree2Likes
Cadillac ATS Technical Discussion Forum Discussion, Baffle in ATS Intake in Cadillac ATS Discussion Forums; I removed this baffle out of the can that the air intake connects to right before the turbo. Wondered if ...
    General Lee 01's Avatar
    General Lee 01 is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T, MT, RWD, BNR TUNE, WHITE DIAMOND
    Jun 2013
    Northeast Ohio
    36
    I removed this baffle out of the can that the air intake connects to right before the turbo. Wondered if it was just a baffle to cut down the noises from the turbo, or had a performance purpose. Turns out it has no effect on turbo noises, and I could feel a real power loss in the pedal. After looking at the whole setup closer, this unit is more of a funnel into the turbo than it is a baffle. I put it back in and definitely felt the power return. Just a friendly FYI.
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    65
    4,435
    Re: Baffle in ATS Intake
    Uh oh. I predict a bunch of aftermarket "funnels" each claiming to add 10 HP.
    kyle f is offline Cadillac Owners Member
    Automobile(s): Escalade
    Mar 2010
    Norris Lake TN
    16
    Couple of simple explanations for this could be:
    It change from laminar to turbulant flow making the turbo work harder to get air into it.
    The change in flow caused you to run lean because of air not hitting the maf correctly.
    But I do not have a 2.0T and can not go see the location, nor know if the car is even a MAP or MAf system. Both of these ideas could be crap, but I have seen it happen on other cars where a tune is needed to correct the vales the MAF is giving. 3000GT's were a perfect example of this.
  5. #4
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,348
    I took mine out when I got my intake made, didn't make a difference so I just stuck it back in lol.
  6. #5
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): '13 ATS 2.0T manual Thunder Gray
    Aug 2010
    712
    I doubt if there is one in Pfadt's CAI.
  7. #6
    Feb 2013
    1,348
    Quote Originally Posted by mikesul View Post
    probably not, but like I said, didn't feel/hear a difference with it out so I just stuck it back in lol.
  8. #7
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    There isn't.
    I wonder what effect Pfdat's intake will have on the car.
  9. #8
    Feb 2013
    1,348
    Quote Originally Posted by M5eater View Post
    There isn't.
    more noise on a stock tune lol.
    oh and if you look at the diameter of the inner portion of that "Baffle" its the same as the diameter of the rubber tube. I'd imagine removing it would create quite a bit of turbulence in that wide "Chamber" just before the tubo. The baffle acts like a tunnel, streaming the air, and removing it suddenly exposes the intake to a wide sudden hollow then crammed back into the bottle neck of the turbo.
  10. #9
    Pfadt Engineering is offline Authorized Vendor PLATINUM
    Automobile(s): The Pfadt ATS
    Jan 2013
    79
    Quote Originally Posted by General Lee 01 View Post
    Hey there, just saw this thread and figured we would chime in. We were surprised to see this too when we started developing our intake late last year. We dyno'd with and without this piece, no performance in this at all, it is just a "noise suppressor" for the intake. If anything, you create potential to lose power with the piece installed. If you perceived a power loss it without it it must be attributed to something else in the mix.
    We will for sure reccommend that everyone keeps these baffles installed in the OEM intakes. No reason to take them out. As for our intake however, we do not need anything inserted to make power!
    Aaron Pfadt
    Pfadt Race Engineering
    888-972-2464
    www.pfadtracing.com
    info@pfadtracing.com
  11. #10
    Aug 2010
    712
    I didn't think it would be there. Sort of like the baffle they had starting with the 2008 Corvettes for harmonics reduction. What harm would a little turbulence be if the air is then sucked through the turbo, pushed through the intercooler, then through the throttle body?
  12. #11
    Feb 2013
    1,348
    well take it out if you want, nobody's stopping you, but I'm saying, I took mine out and didn't notice any power gain/loss and relatively NO extra engine sound, so why would you remove it then? its clearly there for a reason.
  13. #12
    roadpie4u is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0 M6 FE3
    Apr 2013
    343
    You know what it looks like?
    An anti-surge compressor inlet molded into a piece of plastic instead of into the aluminum.
    Makes sense, too.
  14. #13
    Aug 2010
    712
    Quote Originally Posted by Stevo Supremo View Post
    My new Pfadt intake is on the way, no need to play with the stock intake.
    Hoosier Daddy likes this.
  15. #14
    Jan 2013
    79
    Aaron Pfadt
    888-972-2464
    www.pfadtracing.com
  16. #15
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by roadpie4u View Post
    Makes sense, too.
    damnit, this is an intelligent guess at it's purpose. I should have thought of this first.
    Siren05 likes this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
