What do you use for your jacking solutions?
cadillac ats forums cadillac ats forums
Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By Bertha D Blues
  • 1 Post By 73JPS
  • 1 Post By Felton10
Cadillac ATS Technical Discussion Forum Discussion, What do you use for your jacking solutions? in Cadillac ATS Discussion Forums; It looks like what you have to do is lift(using a floor jack) from the pinch welds as indicated from ...
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    It looks like what you have to do is lift(using a floor jack) from the pinch welds as indicated from the rocker panels and then slot the jacks under the circular points on the unibody.
    Corvette pucks might be a suitable replacement for the stands, just wondering if anyone here has found a better solution. for the stands and what you use to jack on the pinchwelds.
    thinking about picking up some of the corvette pucks form amazon and these
    http://www.purems.com/Products/PROTE...-Lift-Jack-Pad
    need to measure the pinch area to make sure they'll fit through.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    49,827
    Why are you asking?
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Re: What do you use for your jacking solutions?
    the area of the jacking point is odd in this car, it's at a slight angle, so you can't plant it on a level surface.
    I ended up cutting up some wood, but it certainly didn't look safe.
  5. #4
    Automobile(s): ZIP
    49,827
    I meant this was the first post I saw where you may have bought an ATS...
  6. #5
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by thebigjimsho View Post
    oh well.. get with the program!
  7. #6
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    65
    4,429
    Glad you cleared that up. I was wondering why you were asking why he was asking.
  8. #7
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,348
    I put span a 2X6 under the car where those two holes are, the ones near the front pinch point(factory hoist holes) and put a jack under the wood, have lifted the car numerous times with no issue
  9. #8
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by Stevo Supremo View Post
    Sure, but where do you place your stand after that?
    I had to lift from the pinch and put the stand where the holes are supported by a block of wood.
  10. #9
    Bertha D Blues is offline Cadillac Owners Fanatic
    Nov 2012
    409
    This was my crude prototype to fit the seam/pocket area. I'm planning to build an aluminum version when my machinist gets back from vacation. I left the seam groove a little wider than needed because I plan to lay tooling urethane into it to protect the seam from localized damage. Bert
    M5eater likes this.
  11. #10
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by Bertha D Blues View Post
    Attachment 122298Attachment 122306
    question.
    How much bribe money do you need to do 2?
  12. #11
    Nov 2012
    409
    Ooooh! I smell a group buy coming.
    Kidding. Bert
    I asked Cadillac Customer Assistance for jacking point info. This was their response, poor grammar and all.
    "Front of vehicle:
    Place service jack pad on the lift pad located right next behind the left and right wheels or on the front center jack pad which is located at the front-center of the vehicle where two arms are connected.
    Rear of vehicle:
    Place the service jack pad on the lift pad located right next front the right and left wheel."
    Huh? Well, that's what they wrote. Cheers. Bert
  13. #12
    73JPS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance 6MT
    Mar 2013
    Ontario, Canada
    270
    Kidding. Bert
    "Front of vehicle:
    Rear of vehicle:
    They almost certainly hired the guy who writes the manuals for Chinese products.
    Bertha D Blues likes this.
  14. #13
    Felton10 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.5 luxury, 2014 ATS 2.0 luxury
    Jun 2013
    114
    Isn't that sort of a personal question?
  15. #14
    wongluk is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T 6spd
    Mar 2013
    Ontario, Canada
    34
    Meiki or onaholes or torchlight and lube... Lots of it....
    Sent from AutoGuide.com Free App
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
