Cadillac ATS How To: H.I.D Conversion - Page 8
cadillac ats forums cadillac ats forums
Page 8 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 106 to 120 of 127
Like Tree10Likes
Cadillac ATS Technical Discussion Forum Discussion, Cadillac ATS How To: H.I.D Conversion in Cadillac ATS Discussion Forums; New to the forum but I'm an big DIY kinda guy. HID's will definitely be going in soon. I was ...
  1. #106
    trimtab81's Avatar
    trimtab81 is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.5 Luxury
    Mar 2014
    10
    Re: Cadillac ATS How To: H.I.D Conversion
    New to the forum but I'm an big DIY kinda guy. HID's will definitely be going in soon. I was just wanting to see what the general consensus was for the best HID kit. I know a lot of people recommend the kit from TRS but I'm not too impressed with there service so far. The tech on chat recommended a MOPAR low beam kit for my car. It may be the right one, but seems a little sketchy. Thanks guys!
  2. #107
    mechevar is offline Cadillac Owners Member
    Automobile(s): ATS 2.0T RWD
    Feb 2013
    94
    Its buried in this thread, but I ended up using the iJDMTOY kit
    http://store.ijdmtoy.com/Slim-Digita...ersion_kit.htm
    You will need the CAN-bus decoders as well.
  3. #108
    JTS2.0 is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac ATS4 2.0T
    Dec 2013
    20
    For those interested, the torx bit to remove the wheel well is a T15 (definitely the best method). I'm using the Opt7 Canbus Premium AC kit, works 100% so far.
  4. #109
    deedle is offline Cadillac Owners Member
    Automobile(s): 2014 ATS 2.0T RWD
    Sep 2013
    Huntsville AL
    32
    49
    Quote Originally Posted by JTS2.0 View Post
    Finally got around to installing mine last night. Also went with OPT7 kit, but the 35 AC (non canbus) kit. Everything working great so far!! I did install capacitors but no relay at this time. I do however need to adjust the bulb in the socket. Some earlier comments of the small bar on the bulb is causing an odd cutoff at the bottom of the light pattern.
  5. #110
    Dec 2013
    20
    I heard of that issue in another thread, they recommended to trim the tabs accordingly so that it will fit with that bar (the electrode) in the 4 to 5 o'clock position (looking straight on at the car). I didn't really reduce the height of the tabs, just trimmed the corners off a few of them, using my old 9006's as a template.
  6. #111
    donavo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0T MANUAL
    Feb 2011
    Los Angeles, California, Unite
    24
    1,296
    i just installed my HIDs and my beam pattern is really screwed. i checked to see if the bulbs are properly inside. still screwed up beam pattern. any ideas anyone? ive seen that all of you have pretty perfect beam patterns so far.
  7. #112
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): 14 ATS Premium 2.0T Phantom Gray/Morello Red, 13 SRX Carbon
    Mar 2013
    Carlsbad, CA
    1,542
    Quote Originally Posted by donavo View Post
    hey bro how is it screwed?, what kit did you use?
  8. #113
    Feb 2011
    24
    1,296
    Quote Originally Posted by pissedoffwookiee View Post
    Used the ddm kit. The beam patten is not even on both sides. There's a hot spot. Cutoff is still okay but there is a shadow on the side and a Hotspot on the front of the passenger side
  9. #114
    Mar 2013
    Carlsbad, CA
    1,542
    Can't really say anything about the hotspot the hotspot should be in the middle and the same for both sides as for the shadow what position was the electrode in when you installed the bulbs
  10. #115
    transam00 is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0 T
    Oct 2013
    341
    Just ordered the opti 7 kit . It looks like you can unscrew the aluminum piece and spin it up side down instead of trimming the tabs . Any thoughts would be nice .
  11. #116
    ZPrime is offline Cadillac Owners Member
    Automobile(s): Dad: 2014 ATS AWD / Me: 2008 VW R32
    May 2014
    33
    3
    Is it possible to retrofit the HIDs from the higher trim cars (the ones that include the LED DRL strips)?
    My dad was forced to buy a lower trim package than he wanted (long story, dealer didn't order the car quick enough and missed the cut-off for the 2014s). The dealer is telling him that they regularly retrofit HIDs to lower package cars, and are claiming it's a $600 process. At that price, I'm hoping they are retrofitting the entire assembly from the higher package, which would include the LED strips... does this sound likely, or are they just planning to charge him $600 for a $100-$200 drop-in HID kit like everyone is using here?
    I always thought that using HIDs in projectors meant for halogens was bad juju because the beam pattern and cutoff would be wrong.
  12. #117
    carpenter is offline Cadillac Owners Enthusiast
    Automobile(s): '14 ATS 4 Black Raven 3.6 Premium
    Jan 2014
    39
    760
    Quote Originally Posted by ZPrime View Post
    Have you checked into this any further? I'd be interested to see what they have to say. At $600 though I'd be more inclined to say that they are putting in an HID kit, not swapping for the HID/LED headlights, but not sure I guess.
  13. #118
    evanj21 is offline Cadillac Owners Member
    Automobile(s): 2014 Cadillac CTS 2.0t
    Oct 2013
    82
    Guys I need some help please, I have a 2014 CTS sedan 2.0t base, the base CTS does come with the LED strip, it just does NOT come with the HID head light like the premium model, I know this is an ATS forum but since there is already a thread about HID I'll just post it here...does anyone know the bulb type my car takes? I called like 5 dealers a few didn't know, others said its the D3S, then I went online and talked to some people and they said its the H11?? I have no idea, I just want to make sure before making the purchase, if anyone has experience please let me know, thanks a lot
  14. #119
    andrewv is offline Cadillac Owners Member
    Automobile(s): 2014 ats 2.0t awd standard trim
    Mar 2014
    Calgary alberta
    17
    I have a question for whoever used the ijdmtoy kit, is it working well? And also did you order the canbus adapters and the relay harness? Or did you just get the adapters? I'm in canada so I need the drl's to work
  15. #120
    Dec 2013
    20
    As an update, i'm not really sure I can recommend the Opt7 kit. I'm on my 3rd ballast. Their customer service has been issue-free and fast, but it's a pain having to replace it so many times.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
