Dashboard Dimmer Switch
cadillac ats forums cadillac ats forums
Results 1 to 14 of 14
Cadillac ATS Technical Discussion Forum Discussion, Dashboard Dimmer Switch in Cadillac ATS Discussion Forums; Folks, At night, my dimmer switch is set to maximum and I can not control how dim or bright to ...
    h3rmes is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    Pasadena CA
    13
    Folks,
    At night, my dimmer switch is set to maximum and I can not control how dim or bright to make the dashboard lights. Is there a quick fix for this problem I can do on my own. Seems like an easy fix or I might be over looking a configuration in Cue?
    Thanks,
    H3rmes
    GJB's Avatar
    GJB
    GJB is online now Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,260
    Re: Dashboard Dimmer Switch
    Have you tried the wheel switch on the dash to the left of the steering wheel directly below the vent? I do not believe there are any cue settings for this function.
    Jul 2007
    Pasadena CA
    13
    Quote Originally Posted by GJB View Post
    Yeah that is one that does not work. I move it the wheel up and down but the brightness remains the same.
  5. #4
    romanats is offline Cadillac Owners Fanatic
    Automobile(s): ats
    Apr 2013
    351
    take it to the dealer
  6. #5
    Rozay619 is offline Cadillac Owners Member
    Automobile(s): 94 Honda Accord / bye bye ATS LEMON
    Jan 2013
    San Diego, Ca
    30
    96
    ^^^^ What Roman said, take the caddy to the dealer.... But, the wheel will dim the display, i had to lower mine all the way down due to a reflection from my window tint.
  7. #6
    73JPS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance 6MT
    Mar 2013
    Ontario, Canada
    270
    You might check CUE under Settings - Display - Mode. Under Mode the display can be set to "Auto", "Day", or "Night". Perhaps if it is set to "Day" it affects the dimming of the entire dash? Dunno, but worth a shot to check, anyway.
  8. #7
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): 14 ATS Premium 2.0T Phantom Gray/Morello Red, 13 SRX Carbon
    Mar 2013
    Carlsbad, CA
    1,543
    Quote Originally Posted by 73JPS View Post
    this is missing on mine
  9. #8
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,260
    Good thinking. The turn signal on my car were loud when I picked it up and I finaly figured our CUE,Settings,Chimes. Chimes would only go down to 21 but what a diffrence from what it was set at.
  10. #9
    Jul 2007
    Pasadena CA
    13
    Thanks! I will check this out later tonight.
  11. #10
    Mar 2013
    Ontario, Canada
    270
    It just occurred to me that it's possible your headlight switch may also not be in the "auto" position: if so the headlights aren't coming on at night, and hence the dashboard dimmer will have no effect. If all your driving is in town, you might not notice that the headlights aren't on. 'Cuz, you know... I've never done that
  12. #11
    Jul 2007
    Pasadena CA
    13
    Actually, I keep the headlights on AUTO. When I move the dimmer switch up and down, nothing happens. I think this is a trip to the dealer.
  13. #12
    Mar 2013
    Ontario, Canada
    270
    Quote Originally Posted by h3rmes View Post
    Well, glad you've checked the (not so) obvious... Let us know how it goes and what the problem is (was). Good luck!
  14. #13
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,260
    I have been trying different settings and I did notice that my dimmer switch is inop during daylight regardless of lights being on or on auto. It appears to be tied into the light sensor on the top center dash. At night or when I pull into the garage the dimmer switch works and that’s the only veritable I've changed.
  15. #14
    Trailblazer's Avatar
    Trailblazer is offline Cadillac Owners Member
    Automobile(s): 2014 ATS AWD 2.0T Premium
    Sep 2013
    Rochester, NY
    43
    I know this thread is stale, but I want to state what I have found. In the 2014 ATS, the dimmer control has no effect during daylight. It works as intended after dark. My guess is that the Cadillac engineers did not think dimming is needed during the day.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
