cadillac ats forums cadillac ats forums
Results 1 to 3 of 3
Thread: Extra Power outlet in trunk
    sdm100 is offline Cadillac Owners Member
    Automobile(s): ATS
    Apr 2013
    19
    Now that the V1 is installed (thank you board members for your assistance), I want to install a power outlet in the trunk. Can tap one of the fuses in the trunk but my question is there are many unused fuse locations in there are they hot and can they be tapped? Want to avoid some of the systems but there are 3 trailler (dont have that option) fuses locations so thought if any of them or the blank locations are powered could insert a fuse and tap of that. Appreciate any input
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Re: Extra Power outlet in trunk
    you need an FSM, you don't need to be go digging to try to find any fuse that'll work and then start blowing fuses left and right (in the best case scenario) because you've tapped a 2 amp lighting rail and are trying to suck 10 amps out of it.
    If the location is blank. It's not Live.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Throwing Copper. Such a great album...
  • You may not post replies
