cadillac ats forums cadillac ats forums
Results 1 to 12 of 12
Thread: run flat tire replacement
    myronf is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0 turbo black/black
    Oct 2007
    WI
    32
    Looking at buying a luxury ads, but I am leery of the run flats.
    Question: When I am ready for new tires, can I put regular tires on? I assume the wheels and tps's are the same for either type of tire?
    Thanks
    Myron
    zr1mom's Avatar
    zr1mom is offline Cadillac Owners Fanatic
    Automobile(s): ATS Prem 2.0T AWD Black Raven Red
    Nov 2012
    177
    Re: run flat tire replacement
    You can put regular tires on the tps should work but note you will not have a spare if you get a flat.
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    810
    Make sure you match the TPS's to the same location they were, RF, LF, etc. Then you won't have to resync them.
  5. #4
    Oct 2007
    WI
    32
    good advise. By the way, does that mean that you can't rotate without synching?
  6. #5
    Bertha D Blues Guest
    Quote Originally Posted by myronf View Post
    If your dealer rotates tires for you they will resync the TPS's. If you rotate them you'll need to resync yourself or have a shop with the sync tool do it for you. Bert
  7. #6
    bungee91 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Opulent ATS 2.0T Premium Manual
    Sep 2012
    North Aurora, IL
    334
    My dealer reprograms my TPMS sensors for me for free when switching between my winter and stock wheel sets. They both are complete sets with sensors installed. I swap them myself and then just bring it in. They said they'd do this at anytime needed, free of charge.
  8. #7
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,085
    Quote Originally Posted by Bertha D Blues View Post
    Where can I find the procedure?
  9. #8
    SLA is offline Cadillac Owners Fanatic
    Automobile(s): '13 ATS 2.0T 6MT, 05 LGT, 97 M3
    Feb 2013
    35
    390
    Quote Originally Posted by Hoosier Daddy View Post
    It's very easy. On your steering wheel d-pad you just press up up down down left right left right engine start.
  10. #9
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (red), 2009 CTS Premium Sedan (red), 2016 ELR (Radiant Silver Metallic)
    Jan 2005
    California
    341
    Cute, SLA!
    From page 10-55 of the manual:
    1. Set the parking brake.
    2. Place the vehicle power mode in ON/RUN/START.
    3. Make sure the Tire Pressure info display option is turned on. The info displays on the DIC can be turned on and off through the Settings menu.
    4. Use the five-way DIC control on the right side of the steering wheel to scroll to the Tire Pressure screen under the DIC info page.
    5. Press and hold the SEL button located in the center of the five-way DIC control. The horn sounds twice to signal the receiver is in relearn mode and the TIRE LEARNING ACTIVE message displays on the DIC screen.
    6. Start with the driver side front tire.
    7. Place the relearn tool against the tire sidewall, near the valve stem. Then press the button to activate the TPMS sensor. A horn chirp confirms that the sensor identification code has been matched to this tire and wheel position.
    8. Proceed to the passenger side front tire, and repeat the procedure in Step 7.
    9. Proceed to the passenger side rear tire, and repeat the procedure in Step 7.
    10. Proceed to the driver side rear tire, and repeat the procedure in Step 7. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
    11. Press STOP to turn the ignition off.
    12. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
    Others may be able to chime in to confirm whether letting air out of the tires in this sequence allows you to accomplish this without an expensive relearn tool like past Cadillacs allow. It's interesting that nothing is mentioned about this in the manual if it's still possible.
  11. #10
    IBMike's Avatar
    IBMike is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS-V Black Diamond Coupe
    Oct 2012
    Falcon CO
    200
    Why are you leery of run flats?
    Made me think of all the people who swore they could brake better than ABS and would never buy a car with it.
  12. #11
    Oct 2007
    WI
    32
    Hard riding, noisy, short life, and if you get a flat there is a good chance that you will be replacing the tire or tires. If you need a tire you may be out of business for 3 days while it is being shipped.
  13. #12
    IBMike's Avatar
    Oct 2012
    Falcon CO
    200
    well when you put it that way...
    Once you get the car, I'd offer up the wheels here in the classified section; maybe you could get someone to take them off your hands for a decent price. Once you get a buyer you could put new ones on and send off the old ones and be happier sooner. If they don't sell, then just let it ride.
  • You may not post replies
