cadillac ats forums cadillac ats forums
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: ATS and No-Lift Shift
  1. #16
    BNRacing is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    Feb 2012
    260
    Re: ATS and No-Lift Shift
    You've got to understand what NLS actually does...
    Most cars when they hit the rev-limiter will close the throttle body a certain amount to keep the revs at that RPM. GM's NLS algorithm keeps the throttle body wide open and uses a combination of timing and fuel mixture as a rev-limiter. This keeps the turbocharger fully spooled so there is no turbo lag when you hit the next gear. I am sure we could make this work on the caddy but it may require some development time. I'll see what we can do and report back. I think it would be great if we could do it.
  2. #17
    pacoflyer is offline Cadillac Owners Member
    Automobile(s): NONE
    May 2009
    30
    8
    Thats great! Since I know some tuners are able to do this on the FR-S and BRZ and a couple other cars I hope you can get good results!
    http://www.ft86club.com/forums/showthread.php?t=14769
  3. #18
    gmesam is offline Cadillac Owners Member
    Automobile(s): ATS 2.0t; manual, black on black
    Nov 2012
    SE Michigan
    27
    I know the Regal GS has it (1-2, 2-3), but it would be great to know if the ATS has it too.
  • You may not post replies
