ATS Rear Sway Bar End Links - INSTALLED - WOW
cadillac ats forums cadillac ats forums
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Cadillac ATS Technical Discussion Forum Discussion, ATS Rear Sway Bar End Links - INSTALLED - WOW in Cadillac ATS Discussion Forums; Hello Folks, As I previously posted, I had my rear sway bar end links installed this past Friday by BWoody ...
    FDNY-L107's Avatar
    FDNY-L107 is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T Auto RWD
    Feb 2013
    Maryland
    55
    Cool ATS Rear Sway Bar End Links - INSTALLED - WOW
    Hello Folks,
    As I previously posted, I had my rear sway bar end links installed this past Friday by BWoody Performance. Please note the below installation pictures. All I can say is WOW!! These links firmed up the rear sway bar WITHOUT affecting ride quality. Easy install, less than 1 hour and the comparison pics of the stock vs BWoody links, speak for them selves. This is an easy mod, does not affect warranty and really helps firm up the rear end. I believe you can even get these on eBay with a FREE choice in color (these links are powdercoated). I would HIGHLY recommend getting these on - you will be pleased. No clearance issues and these come with all required hardware. Any questions, just give them a call and ask for Mike.
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): '13 ATS 2.0T manual Thunder Gray
    Aug 2010
    711
    Re: ATS Rear Sway Bar End Links - INSTALLED - WOW
    Did you put in new bolts or reuse the old ones?
    FDNY-L107's Avatar
    Feb 2013
    Maryland
    55
    The kit comes with all new Grade 8 bolts and washers. We reused the lower ones.
  5. #4
    Fraggy's Avatar
    Fraggy is offline Cadillac Owners Enthusiast
    Aug 2012
    912
    The rear end can use a little work. Wiggles around a little. I'll have to try this. My first real mod. I SO don't wanna go down the modding road again......
  6. #5
    cztrammell is offline Cadillac Owners Member
    Automobile(s): none
    Mar 2013
    13
    Quote Originally Posted by Fraggy View Post
    I agree. I haven't had the car for a month yet, and parts like these make the mod bug come knocking. I wanted to wait at least a few months..
  7. #6
    Aug 2010
    711
    I'm in agreement, but I can't stop.
  8. #7
    FDNY-L107's Avatar
    Feb 2013
    Maryland
    55
    Remember, order on ebay and get these in almost any powder coated color for free.
  9. #8
    louie1487 is offline Cadillac Owners Fanatic
    Jun 2013
    168
    Just installed these and one thing Bwoody did not mention was that the sway bar bolt hole has to be drilled a little larger, in order for the bolt to fit. Want to make everyone aware. I have the 2.5L. Not sure if FDNY-L107 has the magnetic ride control, but for the standard sport suspension its not exactly direct bolt on.
  10. #9
    Fraggy's Avatar
    Aug 2012
    912
    Can u describe the improvement in handling a bit?
  11. #10
    Aug 2010
    711
    Didn't have to drill mine with the performance suspension. Much tighter feel in the corners and a more planted car.
  12. #11
    FDNY-L107's Avatar
    Feb 2013
    Maryland
    55
    Quote Originally Posted by louie1487 View Post
    Humm....we took the measurements and specs off my 2.0T sport suspension wo/MRC with no drilling required. Interesting that you had to drill - there must a different sway bar used with MRC. Thanks.
    Quote Originally Posted by mikesul View Post
    That is exactly what you can expect! These help take the slop out of the rear end.
  13. #12
    Thunder Gray STS's Avatar
    Thunder Gray STS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Premium
    Jun 2009
    Memphis TN
    48
    236
    Quote Originally Posted by cztrammell
    I wanted to mod the first day. Came out of a CTS V to a 2.0 turbo.
  14. #13
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2005 Z4 2.5i
    Mar 2013
    Boynton Beach, FL
    76
    735
    I'm always into a little modding as long as I have good enough instructions to give me the courage to do it. Could I get a brief description of how to do the install?
  15. #14
    FDNY-L107's Avatar
    Feb 2013
    Maryland
    55
    Quote Originally Posted by flycaster View Post
    Sure thing. Just give Mike a call at BWoody Performance. He can step you through this easy install.
  16. #15
    netring is offline Cadillac Owners Member
    Apr 2013
    23
    Has anyone else tried this mod? is it fairly simple?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
