ATS Rear Sway Bar End Links - INSTALLED - WOW - Page 2
cadillac ats forums cadillac ats forums
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac ATS Technical Discussion Forum Discussion, ATS Rear Sway Bar End Links - INSTALLED - WOW in Cadillac ATS Discussion Forums; Definitely tempting....Gotta fight the mod temptation. Any special equipment needed for the install?...
  1. #16
    mechevar is offline Cadillac Owners Member
    Automobile(s): ATS 2.0T RWD
    Feb 2013
    94
    Re: ATS Rear Sway Bar End Links - INSTALLED - WOW
  2. #17
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): '13 ATS 2.0T manual Thunder Gray
    Aug 2010
    711
    No special equipment needed, although a lift makes it much easier.
  3. #18
    Atswatcher is offline Cadillac Owners Fanatic
    Mar 2012
    226
    Can this be done at the front?
  4. #19
    Aug 2010
    711
    Not yet.
  5. #20
    netring is offline Cadillac Owners Member
    Apr 2013
    23
    I recieved the sway bar links today, plan on installing them over the weekend. I know polyurethane bushings need greasing, but im inexperienced in this sort of thing, starting out my mods small. Does the whole bushing need to be taken apart to be greased inside where the outer edge of the polyurethane makes contact with the inner part of the metal that holds it? Or is it just the faces that need lubrication? Also, i noticed the metal sleeve extends out past the bushing, does it need to be shaved down so the washer is laying flat on the bushing?
    Thanks for answering my questions if you have time!
  6. #21
    Apr 2013
    23
    Anyone else get these?
  7. #22
    thebucky84's Avatar
    thebucky84 is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac ATS 2.0T
    Oct 2013
    Florida
    26
    29
    This may be put on my list of mods to do. I've experienced BWoody end links in past vehicles and was always impressed.
  8. #23
    FDNY-L107's Avatar
    FDNY-L107 is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T Auto RWD
    Feb 2013
    Maryland
    55
    Just give Mike @ BWoody a call and he will gladly walk you through his recommended lub and installation tips. Those are mine in the initial post pics - and now with almost 20K miles on them, not one squeak, rattle or hummmm......
    FYI, for those who are interested, I did go ahead and replace both my front and rear sway bar bushings with Energy Suspension universals. Nice upgrade and does not make a harsh ride - again, just firms things up a bit more. Note though, the front bushings are actually impregnated onto the bar itself and was a bitch to remove. The rears took 15 mins to change out.
  9. #24
    Aug 2010
    711
    Great info FDNY. I think I will wait until the ATS-V comes out and see what they have done for the "V" setup. I do like my BWoody rear links, they are worth the price.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
