Is “Sport Mode” a placebo? Marketing tool? - Page 2
cadillac ats forums cadillac ats forums
Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Like Tree1Likes
Cadillac ATS Technical Discussion Forum Discussion, Is “Sport Mode” a placebo? Marketing tool? in Cadillac ATS Discussion Forums; Sounds like something is not adding up. I find it hard to believe that if your hard on the gas ...
  1. #16
    ewired's Avatar
    ewired is offline Cadillac Owners Fanatic
    Automobile(s): '13 Cadillac ATS 2.0T
    Dec 2012
    39
    131
    Sounds like something is not adding up. I find it hard to believe that if your hard on the gas at 70mph, that the tranny would be in sixth gear in any mode.
    I know pal works in my ATS. However I have never tried it in auto. I usually go to Sport mode, manual shift and use the paddle shifters. Sure enough while turning, braking and my hands are away from the shifters, the car downshifts like it should.
  2. #17
    Bertha D Blues is offline Cadillac Owners Fanatic
    Nov 2012
    409
    Re: Is “Sport Mode” a placebo? Marketing tool?
    [QUOTE=ewired;3194525]Sounds like something is not adding up. I find it hard to believe that if your hard on the gas at 70mph, that the tranny would be in sixth gear in any mode. QUOTE]
    It upshifted when I got off the gas and on the brake. The rpm at exit was under 2,000. Do I need to be in manual shift mode for PAL to work?
  3. #18
    sagang227 is offline Cadillac Owners Member
    Oct 2012
    PAL is only for sport mode, and won't work in manual mode. You probably just enabled the PAL with that one corner. Try braking after you exit the corner, it should downshift and hold you at a lower gear as long as you are driving aggressively. I think it's designed for a series of corners such as tracks and moutain roads.
    I noticed the difference between normal mode and sport mode upshifts at a higher pedal. I think they are both smooth at a lower pedal, which makes sense. But once you start driving aggressively, the upshifts are firmer and quicker.
  4. #19
    ewired's Avatar
    Dec 2012
    39
    131
    Bertha, I'm not positive if you need to be in manual mode on the shifter, as I'm always in that mode when running the corners. I could try it D to see but we've been pretty wet here this last week but the roads are clearing as of today.
    I'm pretty sure you need to be in Sport Mode for PAL to take over.
    Quote Originally Posted by sagang227
    I'm referring to manual mode as placing the shifter to the left to use the paddle shifters and not Tour or Snow mode. I can confirm that PAL has downshifted automatically while using the paddle shifters in Sport Mode.
  5. #20
    kevinr is offline Cadillac Owners Member
    Automobile(s): ATS
    Dec 2012
    So Cal
    42
    I have 3.6 and there's definitely a difference. The steering is heavier, most noticeable on high speed sweepers. Not a lot, but noticeable. On launch in sport mode I can get a small amount of wheel spin. The transmission shifts more frequently -- relatively smaller throttle position changes will cause a one gear down shift. It also tolerates a bit of throttle-induced oversteer when accelerating through slow speed corners .
    All of that said, these differences are most pronounced when your misbehaving on public roads. Driving normally, there's very little difference (except the MRC, as others have noted -- that one can feel regardless of driving style).
    I've had two Audi A4s (one with S-Line sport suspension), an Acura TL and a MB C350 (2011 sport model). This by far the best handling car I've driven in this segment. My other car is a 1st gen Porsche Cayman S (generally considered a benchmark in chassis dynamics), and my MRC-equipped ATS comes close to the Porsche in cornering confidence.
    I can notice the throttle mapping, but that seems pretty subtle. On my Cayman, the difference between sport mode throttle mapping and 'normal' is huge. It's a manual, and rev matching and throttle/clutch modulation at launch is so different you would think it a different engine. The ATS by comparison (speaking now only of throttle mapping) is much more subtle.
    CUE, on the other hand, needs some work.
    Sorry you are unhappy with yours.
  6. #21
    Nov 2012
    409
    You guys have convinced me that my Sport Mode isn't functioning. I've tried driving irresponsibly as described in the posts above, switching between Sport and Touring, I get nothing. I'll have my dealer check it out. Maybe it's just a programming problem. By the way, Snow Mode definitely works as described in the owners manual.
    Thanks, Bert
  7. #22
    rustybear3's Avatar
    rustybear3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS White Pearl Turbo
    Feb 2012
    Ohio
    63
    1,297
    Quote Originally Posted by Bertha D Blues View Post
    Thanks, Bert
    Sports mode is a joke...and agree that snow mode is effective....get rid of sport mode and save money on MY ATS 2014 Cadillac...
  8. #23
    Livid is offline Cadillac Owners Member
    Automobile(s): ATS 3.6 Premium
    Jul 2012
    Silicon Valley
    18
    I'd actually like a "grandpa" mode that is softer than touring mode. Maybe I've been driving my XTS loaner too long...
  9. #24
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    14,013
    Quote Originally Posted by Livid View Post
    ----------------------------- ^^^ That ^^^
    [SIZE=3Rippy Automotive[/SIZE]
    Rippy is a Cadillac, Hummer, Saturn & Saab dealership & Official Saab Service Center
    ~~ Family owned and operated in Wilmington, NC since 1946 ~~
    We offer all forum members discounts on parts and freight
    phone: 800-RIPPY-22
    <-- insert standard boilerplate about posts not necessarily representing my employer, etc -->
  10. #25
    Jercat is offline Cadillac Owners Member
    Automobile(s): 09 G8 GXP
    Jun 2011
    SC USA
    58
    55
    The sport mode on my G8 works just like the ATS is suppose to. When I'm running 80mph and brake for a turn , it blips the throttle and down shifts thru the gears. I would not give up on the ATS, just take it in and have them look at it. I know your other problem is a pita, just need to hang in there.
  11. #26
    Its an ATS is offline Cadillac Owners Fanatic
    Automobile(s): ATS Premium 3.6 AWD
    Oct 2012
    29
    235
    Thanks, Bert
    I tried PMing you and my phone is being goofy. Would you mind enlightening me on your "other" issue? I'm working with cust service right now to hopefully fix my issue and in wondering if we have the same thing going on.
    Thanks, Cody
  12. #27
    Nov 2012
    409
    Cody, for my other issue see the thread I stareted entitled "Tapping noise in HVAC system"
    Thanks for your concern. Bert
  13. #28
    hueyh is offline Cadillac Owners Member
    Jan 2013
    19
    to sum up , is it true that, "sports mode" only adds steering firmness, for models with manual transmission and without MRC?
  14. #29
    Automobile(s): ATS
    Dec 2012
    So Cal
    42
    Quote Originally Posted by hueyh
    I would expect there would be some engine mapping changes as well.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
