HID & LED Headlights - Page 14
cadillac ats forums cadillac ats forums
Page 14 of 16 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 196 to 210 of 240
Like Tree23Likes
Cadillac ATS Technical Discussion Forum Discussion, HID & LED Headlights in Cadillac ATS Discussion Forums; Originally Posted by JoeyCts If anyone knows if you can retro fit the HID for the standard lights I would ...
  1. #196
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    65
    4,433
    Re: HID & LED Headlights
    Quote Originally Posted by JoeyCts View Post
    If anyone knows if you can retro fit the HID for the standard lights I would greatly appreciate it .. My body shop wants to order than but not sure if the wiring harness will work!! I call my Cadillac dealer and they didn't even know .. I would really appreciate the help..
    It's a very simple DIY project. Probably under $100. You already have projector housings. You just replace the halogen bulb with HIDs. May be better than factory since you can choose the color temperature and power.
    If you also want the factory LED accent lights, that's another story. I think the housings with those are around $1,000 per side and will require some custom wiring to get them working right.
  2. #197
    jrusso0102 is offline Cadillac Owners Member
    Aug 2013
    1
    hey when you ordered the hid kit what bulb number did they sent u?
  3. #198
    Caddyats82 is offline Cadillac Owners Member
    Automobile(s): Ats
    Aug 2013
    3
    Is it possible to use oem cadillac escalde hid bulb and ballast on the cadillac ats would the bulb fit?
  4. #199
    MikeATS is offline Cadillac Owners Member
    Automobile(s): ATS 2.0T RWD
    Jun 2013
    Los Angeles
    24
    Quote Originally Posted by Caddyats82 View Post
    My guess is that it would be a different size considering everything about the 2 vehicles is different, including the headlight casing... However, it may be possible to strip the the bulb and rubber cement it to the casing? <--I wouldn't recommend it, but if you're desperate!
  5. #200
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,348
    why mess with that? HID kits can be had for <100, thats almost as much as some people spend on there phones each month...do it right
  6. #201
    Jun 2013
    Los Angeles
    24
    Quote Originally Posted by Stevo Supremo View Post
    agreed... I got my kit from DDM tuning with anti-flicker for under $50 w/ shipping. Some people are obsessed with OEM parts though...
  7. #202
    Feb 2013
    1,348
    cant see why^ half the time they're overpriced and real quality aftermarket parts usually do the job better
  8. #203
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): 14 ATS Premium 2.0T Phantom Gray/Morello Red, 13 SRX Carbon
    Mar 2013
    Carlsbad, CA
    1,543
    cant wait to see the HID kit from TRS when it arrives friday
  9. #204
    Automobile(s): Ats
    Aug 2013
    3
    Re: Which HID is the best for Cadillac ATS 2.0T Standard
    Reason i asked about oem escalade hid cause i have 2 spare sets oem tend to last longer but can someone refer me where to buy the hid for the ats and what do i need to get, and is it true can access through wheel housing and no need to remove bumper?
  10. #205
    Feb 2013
    1,348
    you know its funny, a mod PM'd me about that sticky and laughed he said
    "once I make this a sticky... nobody will read it anymore"
    http://www.cadillacforums.com/forums...how-h-i-d.html
    thats every step how to do it without taking the front bumper off.....
    you can buy HIDS from Amazon, eBay etc... just get the right Bulb type. I've always been fond of Lumens brand, a bit pricey but work well.
  11. #206
    Bryce2.0T is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0T Standard
    Mar 2013
    26
    313
    TRS (The Retrofit Source) has some amazing stuff. I used their Morimotto kit: Incredible
  12. #207
    Mar 2013
    Carlsbad, CA
    1,543
    Quote Originally Posted by Bryce2.0T View Post
    give a quick impression/review my morimoto kit arrived yesterday build quality is pretty amazing, I got the can bus adapters and upgraded to the xb35 bulbs after speaking with TRS, they also talked me into 5000k instead of the 4300k I was going to get. the gentleman said the xb35 at 5000k is the set of choice among their employees and makes a color i'll love
  13. #208
    mechevar is offline Cadillac Owners Member
    Feb 2013
    94
    I'm looking to put an LED strip on the outside like your garage pic. Which LED strip did you buy and how do you get it along the outside edge of the housing? What you have looks really smooth and I think it will look great with the HID upgrade I just did.
    Quote Originally Posted by kennyjd6 View Post
    No its pretty simple, vertically just make sure they look level then you can adjust them with a allen wrench once they're mounted. then horizontally you do have to take the cover off the back to slide the light back and forth, so i adjusted them on the car before then mounted them after.
    Heres some pics of light and ballast, not gorgeous, but it works and i wanted it to be waterproof.
    Attachment 122818Attachment 122834
    And a terrible photo in my messy garage all working. haha. I actually think the aftermarket HID's look a little better than the stock, they look like they match the LED's a little better.
    Attachment 122842
  14. #209
    tbodker is offline Cadillac Owners Member
    Dec 2013
    1
    Where did you find the after market hid
    When I purchased this car it had to be brought in from another dealer, I was told the car would be exactly the same one I saw but different interior and exterior colors. After I got the car home i noticed it had no led lights. they told me I could upgrade for $1000 per headlamp. The LED lights were very important to me and the dealer will be upgrading the headlamps or I'm going to return the car..
  15. #210
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    28
    3,537
    Quote Originally Posted by tbodker View Post
    If they told you it was the same except the colors then that is what it should be. Make them take it back.
    You need to compare the RPO code list to see if it really is "exactly the same".
    Sent from AutoGuide.com App
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
