[Deliberate Misinformation] The Cadillac ATS is probably going to weigh about... - Page 4
cadillac ats forums cadillac ats forums
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 78
Like Tree14Likes
Cadillac ATS Technical Discussion Forum Discussion, [Deliberate Misinformation] The Cadillac ATS is probably going to weigh about... in Cadillac ATS Discussion Forums; Originally Posted by thebigjimsho That's impressive, if true. How can it weigh so little when the Regal is a relative ...
  1. #46
    Cadillac Tony's Avatar
    Cadillac Tony is offline Cadillac Owners Connoisseur
    Dec 2004
    Leesburg, Florida
    2,190
    Quote Originally Posted by thebigjimsho
    That's impressive, if true. How can it weigh so little when the Regal is a relative porker?
    That's why I've had a hard time with 3,400...
    Eliminating traditional assembly materials like molded plastic door panels, steel motor mounts and carefully selecting items like type of insulation, seat motors, batteries, etc.
    Mazda has done something similar with the Miata since its inception, fussing over the weight of everything from the muffler to the shift knob (which went through over 100 variations to find the lightest one possible that still gave good shift feel)
    Quote Originally Posted by Cadillac
    “Low weight gives the ATS a more nimble and controllable feel, while also optimizing the performance and efficiency of the powertrains,” said David Masch, ATS chief engineer. “But we were careful to manage the weight while maintaining Cadillac’s signature levels of refinement.”
    Optimizing the ATS’s mass was the result of a four-pronged philosophy that included strict adherence to original architectural goals, measured load management throughout the vehicle, benchmarking components to see if lighter solutions were available and an overall culture that “weighed” the mass of every component in the car against all aspects of its development.
    An aluminum hood, magnesium engine mount brackets and even lightweight, natural-fiber door trim panels contribute to the ATS’s low overall mass – and reflect the systematic approach of evaluating every gram that went into the car. But some weight was deemed not only beneficial, but essential to the ATS’s driving experience. An example is the cast iron differential: Engineers found they could improve fuel economy with a cast iron differential rather than a lighter aluminum version.
    And while the rear suspension is mostly steel, the focus on load management and straight links enabled significant weight savings without using alternate materials. This helps offset the weight of the engine and transmission at the front of the vehicle, helping the ATS deliver its 50/50 weight balance, while also contributing to lower noise and vibration. A similar approach was taken on the wheels, where extra structural aluminum was strategically added to further reduce vibration.
    “We approached development by counting all the grams in the ATS,” said Masch. “We minimized them where we could and put them to the best use where they were needed.”
    Tony Pagano
    Sales Manager
    Plaza Cadillac
    Leesburg, FL
    (352)787-1323
    www.cadillactony.com
    The views and opinions of this poster are solely his own and do not represent those of Plaza Cadillac
  2. #47
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    Re: The Cadillac ATS is probably going to weigh about...
    natural fiber door panels? Interesting..
  3. #48
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    49,844
    I need a four-pronged philosophy...
  4. #49
    Lord Cadillac is offline Cadillac Maniac
    Automobile(s): Cadillac Escalade
    Dec 2002
    Royal Palm Beach, Florida
    43
    13,617
    I'm pretty confident the ATS will be very competitive in it's class. I do think they've got the weight right where it needs to be.
    Have an iPhone or Android? Than you can be connected with everything automotive in your area.
    Download the app for your iPhone or Android devicetoday!
  5. #50
    Automobile(s): ZIP
    49,844
    Look who's late to the party...
  6. #51
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    40
    37,474
    What kind of party we talkinbout here?
  7. #52
    Automobile(s): ZIP
    49,844
    lemon?
  8. #53
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by thebigjimsho View Post
    lemon?
    I'm out. Lemon's don't sit well with me.
  9. #54
    MikeTerp is offline Cadillac Owners Member
    Automobile(s): None
    May 2010
    Maryland
    15
    Re: [Deliberate Misinformation] The Cadillac ATS is probably going to weigh about...
    Well, early returns and some car mag articles look good for the ATS. There are also some "analyses" out on the new 3 which have some bimmerphiles wringing their hands (plastic oil pan to save on weight, but what about heat, etc). I have been impressed that Cadillac did so well with the Alpha platform ATS coming in at 3400 lbs, even if this is some stripper model. Figure 3600 on most of those actually delivered and that is still not too bad. Looks like the ATS loses already to the 3 on interior room and trunk space, but we will have to see if that is much of a factor. My one significant dissapointment is that Caddy has opted to go to runflats for any model above the non-turbo 4. Go to any BMW message board and read all the wailing and moaning about runflats. On the new 3 the single biggest request for change was to get rid of the runflats (ride, noise, cost, handling, availability, etc, etc). Let's hope that Cadillac at least has them as a "delete" option. Can't wait for some actual car mag evaluations and some comparos with the 3, A4, etc.
  10. #55
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,644
    Quote Originally Posted by The Tony Show View Post
    IIRC, the LS series engines weigh the same or less as the high feature V6s thanks to fewer internal parts (single camshaft, 16V vs 24V, no variable cam phasers, etc etc...
    Thats what I suspected. A TTV6 should weight awfully close to the LS V8's...
  11. #56
    Automobile(s): ZIP
    49,844
    Quote Originally Posted by concorso
    I would say a TTV6 would be heavier...
  12. #57
    Dec 2006
    40
    37,474
    Looking at the first gen CTS vs the V, the V was a couple hundred pounds heavier and had more front weight bias.
  13. #58
    rand49er's Avatar
    rand49er is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2005 CTS-V, 2011 Cruze 1.4T 6MT
    Jan 2005
    South Lyon, MI
    66
    13,424
    Quote Originally Posted by JimmyH View Post
    Flywheel.
    '05 CTS-V, Maggie, Kooks, Hotchkis, Ground Control, Corsa, B&M, DSS/Hendrix, Full 3M Clear Bra, Autovation, V Headrests, CTS Console, STS-V 55w Fogs, Black Vette FRCs, Specter Werkes, Katech LS9 Clutch, SS Brake Lines, Heavymetals U-Turn Fuel Line Eliminator, Momo Combat Evo Shift Knob, Wldwhl Clear Sidemarkers, Linea Corse LC855 Wheels or OEM wheels w/'06-'07 Center Caps, plus a couple more. 472 RWHP/411 RWTQ (Mustang Dyno).
  14. #59
    Dec 2006
    40
    37,474
    I know that was part of it, but I don't think even that was enough.
  15. #60
    Automobile(s): ZIP
    49,844
    Well, since an LS6 and T56 weigh about 450lbs, I think you need to look elsewhere for the additonal weight.
    Again, a V6, with DOHC running gear AND 2 turbos hanging off of it, with the additional coolers and accessories, will be heavier than an LS engine...
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
