ATS License Plate LED Lights... problem.
cadillac ats forums cadillac ats forums
Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By duneless
Cadillac ATS Picture and Appearance Forum Discussion, ATS License Plate LED Lights... problem. in Cadillac ATS Discussion Forums; Okay, I ordered the LEDS from ebay for the license plate and reverse light.. I replaced the reverse light a ...
    doobs2 is offline Cadillac Owners Member
    Automobile(s): ATS
    Jun 2014
    1
    LightbulbATS License Plate LED Lights... problem.
    Okay, I ordered the LEDS from ebay for the license plate and reverse light.. I replaced the reverse light a week ago and tested it that night and looks great, no issue. 2 days ago I replaced the license plate lights, turned on the lights and nothing, flipped the LEDS around and they work. (What are the chances of getting both bulbs backwards? lol) Anyways, they worked fine. I meant to test the license plate lights that night when it got dark but didn't get to. So now, 2 days later, I went to test the lights and the reverse lights still work, but the license plate ones do not. I popped 1 of the license plate lights out, flipped it to see and still nothing. I grabbed the stock bulb and popped it in for the license plate and nothing.
    Is there a chance since I didn't remove the other license plate LED and tested with the stock bulb it would cause the stock bulb to not light up? Is it some error code throwing issue possibly? I haven't checked the fuses or anything, it was a quick test tonight and it is pouring the rain. I wanted to see what you all thought in the mean time.
    Thanks everyone!
    off1c3r is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 2.0T Performance AWD
    Jun 2010
    NYC
    227
    Re: ATS License Plate LED Lights... problem.
    Check the fuses. There's no reason you can't mix and match and both don't light. If you replace the LED's with the stock and it still doesn't light, the fuse is the first place to check (assuming all bulbs are blown). If still nothing, check to see if the wiring is OK and that its not damaged or loose.
    Terrybill is offline Cadillac Owners Member
    Automobile(s): 14 ATS Premium 3.6L AWD
    Mar 2014
    MN
    11
    At least yours were apparently on one piece. Mine worked when tested but after the first three mile trip at night I came back to no lights and found the pieces in the housing. Put the originals back in and those are working fine. Now playing twenty questions with the ebay (gotta love it) vendor asking one per day at around 0400. To their credit it doesn't make much sense to send out the same thing if it ends in the same result.
    First pic compares old and new, second shows both were working (and looking good I thought) prior to their premature death, third is the detritus remaining
    rustybear3's Avatar
    rustybear3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS White Pearl Turbo
    Feb 2012
    Ohio
    65
    1,659
    ^^^^^^Hopefully you two get your problems straightened out....I've equipped my car with LED's all around and I must say, it is a 100% improvement in looks!
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,020
    Quote Originally Posted by rustybear3 View Post
    What a bunch of choir boys persons! I want DIMMER license plate lights, preferably in the 1-2 candlepower range,
    duneless's Avatar
    duneless is offline Cadillac Owners Connoisseur
    Automobile(s): Current 2014 red CTS Vsport/ Black Raven 2013 3.6 ATS4 gone
    Jul 2013
    Connecticut
    42
    2,765
    Yes, No bright lights on my plate. I want to just shut mine off. LEDS look good though. I want hide away plates.
    Quote Originally Posted by Hoosier Daddy View Post
    Hoosier Daddy and louie1487 like this.
    Dad-illac is offline Cadillac Owners Member
    Automobile(s): 2000 DeVille
    Jul 2014
    Which fuse is for the license plate bulbs. I removed the fuse box cover and it's all in abbreviation, none of which appear to be for the license plate bulbs
    rnr4mula's Avatar
    rnr4mula is offline Cadillac Owners Member
    Automobile(s): Had 1995 Eldorado, Had 2001 DHS, Had 2005 STS, Have 2013 ATS
    Aug 2014
    Illinois
    23
    There is a reason those bulbs are so much cheaper on eBay. "Because they are CHEAP". I went through the same issues with eBay Led bulbs, after spending real money for "real" bulbs I have a much purer white light and "NO" issues. Do yourself a favor and just buy quality bulbs the first time around. I spent considerably more money for my Putco bulbs but they are worth every penny!!!
    jdastas is offline Cadillac Owners Member
    Automobile(s): ATS Base 2.5
    Jan 2015
    Chandler, AZ
    33
    36
    What size bulbs are the interiors bulbs, like the dome lights and the ones located at your feet? I replaced my reverse light and license plate light and they work fine.
    dpelow07 is offline Cadillac Owners Fanatic
    Automobile(s): none
    Oct 2014
    27
    138
    194 bulb
  13. Remove Advertisements
