Dimming LED DRL when headlights on?
cadillac ats forums cadillac ats forums
Results 1 to 10 of 10
Cadillac ATS Picture and Appearance Forum Discussion, Dimming LED DRL when headlights on? in Cadillac ATS Discussion Forums; I'd like to have LED DRLs installed. Also I'd like them to dim when the headlights are on. Is this ...
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    916
    I'd like to have LED DRLs installed. Also I'd like them to dim when the headlights are on. Is this possible with the Luxury model; and if so, how? I plan to turn the headlights off during the daytime and thus negate the headlight automatic DRL function.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    916
    Re: Dimming LED DRL when headlights on?
    Found these LRD DRLs that not only dim at night, but also blink yellow on turns...http://www.carid.com/universal-headl...-10791032.html. However, they are 800-900 lumens, each duriing the day and about 400 lumens when dimmed at night. BTW, during the day. I plan to turn off my headlights so they don't act as DRLs. I'm thinking that this would be way too bright during the day. And, as I still have halogen headlights, the 400 lumens at night would probably be a bad contrast with the halogens. What do you guys think?
    romanats is offline Cadillac Owners Fanatic
    Automobile(s): ats
    Apr 2013
    427
    they will stick out pritty bad because of the moubting brackets
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    916
    Quote Originally Posted by romanats View Post
    Can't have that. Whatever DRLs I get, I will have them custom installed. Do you think that they will still stick out?
    Automobile(s): ats
    Apr 2013
    427
    well if you have them cut the plastic then probably not but if they smack them on top pretty sure they will bulge out.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    916
    I'm fairly certain that they will cut the plastic to recess the DRLs...custom, ya' know.
    Automobile(s): ats
    Apr 2013
    427
    go for it
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    916
    go for it
    Don't you think that 800 lumens is too bright?
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,043
    Quote Originally Posted by flycaster View Post
    It doesn't sound like a lot when spread out. I don't know about when focused. I know when we switched over to all LED in the home we put in 6000 lumens total in the kitchen not counting task lighting.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    916
    That's 800 lumen on each LED. The DOT specification for LED DRLs is no more than 400 lumens. I don't mind the legality of it all, but do mind that the DRLs may look ridiculously bright. The other set of LED DRLs (Eurolight 1065-smoked lens so when off, they don't "bug-out") I'm considering put out 130 lumens each and here I'm wondering if they will be bright enough. Actually, they probably will be (or should be) bright enough during the day as they are called accent DRLs and I take this to mean that they may not be as bright as others, but they should do the job of DRLs??? BTW, these lights were suggested by the custom shop that will do the job and I assume they should know what they are doing.
  13. Remove Advertisements
