2013 ATS is it possible to install fog lights if my car does not have any?
cadillac ats forums cadillac ats forums
Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Like Tree5Likes
Cadillac ATS Picture and Appearance Forum Discussion, 2013 ATS is it possible to install fog lights if my car does not have any? in Cadillac ATS Discussion Forums; My 2013 ATS has no fog lights and I wanted to get some installed, but I like the way the ...
    Exclusiveink is offline Cadillac Owners Member
    Automobile(s): 2013 ATS
    Sep 2013
    8
    My 2013 ATS has no fog lights and I wanted to get some installed, but I like the way the stock fog lights look. Is it possible to have them installed through the dealer? I do not want to get some cheap after market ones. And I rather have them installed right. Any advice is appreciated.
    Thanks this is my first post and I'm enjoying my car so far.
    Renovatis is offline Cadillac Owners Member
    Automobile(s): 2016 ATS
    Jul 2013
    Ann Arbor, MI
    30
    27
    Re: 2013 ATS is it possible to install fog lights if my car does not have any?
    The simple answer is yes it is possible.
    You would have to order the "Performance" model fog light bezel and fog light for both sides from the dealer. They looked as though they were interchangeable between models via GM diagrams. Because the Standard and Luxury models use a different front end wiring harness, you would have to wire them up yourself. Something that is relatively simply if you know what you're doing.
    I have thought about doing this, but because the parts seem like they are only available through the dealership and because I am only leasing my ATS, I have decided against it.
    Hope this helps.
    romanats is offline Cadillac Owners Fanatic
    Automobile(s): ats
    Apr 2013
    427
    the other option you have is installing aftermarket LED lights like some of us did
    http://www.cadillacforums.com/forums...obsession.html
    take a look at this it might be healpefull
    matthewmugar likes this.
    Sep 2013
    8
    Thanks for the replies I really appreciate it
    Sep 2013
    8
    I called the dealer today to inquire about the fog lights and they said it would be too much of a hassle to install the fog lights in my car since it did not come with any. And that my car is not wired for them. They said I would have to get the lights from a wrecked car and then go from there. I don't know if they were just brushing me off cause I waited on hold for a while and the parts person had a rude attitude. I really like the way the stock fog lights look that's why I wanted to go through the dealer. I figured they would know what they are doing.
    Sep 2013
    8
    This is a picture of the fog lights I was looking for
    Elle likes this.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    the dealer you talked with was half correct
    yes, it is hard because the wiring is not there - it becomes a custom job and dealers don't like custom jobs
    no, you don't need get them from a wrecked car you can buy new parts
    so if you want to get it done order the parts and have a local custom shop do the install for you
    just beware that it's not going to be cheap and you may (or rather, probably will) run into complications either initially, down the road, or both
    that's just the cost of customizing
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    4,141
    Try another dealer, some are staffed with great folks that are enthusiasts themselves and like helping people some are not, unfortunately a lot of Cadillac stores have been around a long time and are stuck in their ways... anything beyond adding a simulated convertible top and you're speaking martian to them.
    EDIT....and what RIPPY said
    Sep 2007
    Wilmington, NC
    13,969
    i also agree with pissedoffwookiee's comment ... another dealer may be willing to be the aforementioned 'custom shop' ... most won't ... we sublet out that work ourselves to a local custom shop
    more importantly ... find a dealer that is willing to satisfy you as a customer (at whatever lengths it may take)
    Sep 2013
    8
    Thanks for the replies.
    I do not know much about wiring or mechanical stuff. If I get the lights would I need to get a switch to turn them of and on or is it possible to use the existing switch on my car? I would like to have the lights look and function as close as stock as possible.
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    Honestly, for ME, this would be a straightforward job as I've been heavily modifying cars for a few years now, but if you really aren't that familiar with cars this MIGHT not be something you'd want to screw around with.
    Oh and to answer, yes, you can wire them up to the lights to have them function like the factory ones. I dont have those lights, but I've seen them and seen the harness so I know its possible, but I have a lease (which I dont know if I'm buying out) and at this point they've just not worth the HUGE expense, such money could be spent on more go fast bits
    Automobile(s): ats
    Apr 2013
    427
    there is one fog light for sale on ebay for $250 can you imagine what the dealer will ask for them plus labor? it will be close to $1k. I think its insane to pay for something like that.
    Sep 2007
    Wilmington, NC
    13,969
    list price is about $141 for each "daytime running lamp" in the lower bumper
    i'm not really sure these cars actually have proper fog lights
  16. #14
    Feb 2013
    1,347
    Yeah they're more like auxillary lamps... I wish we could take those panels out and have air ducts made there for the brakes or engine bay.
  17. #15
    Jul 2013
    Ann Arbor, MI
    30
    27
    Quote Originally Posted by Stevo Supremo View Post
    D3's bumper did that for their CAI. Technically you could do that same but you would be able to see the tabs...
  18. Remove Advertisements
