HID & LED Headlights - Page 10
cadillac ats forums cadillac ats forums
Page 10 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 136 to 150 of 265
Like Tree33Likes
Cadillac ATS Picture and Appearance Forum Discussion, HID & LED Headlights in Cadillac ATS Discussion Forums; Link not working...
  1. #136
    romanats is offline Cadillac Owners Fanatic
    Automobile(s): ats
    Apr 2013
    427
    Re: HID & LED Headlights
    Link not working
  2. #137
    Hoosier Daddy's Avatar
    Hoosier Daddy is online now Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    5,994
    Quote Originally Posted by romanats View Post
    Link not working
    The original one is. Maybe he will post a link to his post with the link. Or..... you could just scroll up.
  3. #138
    MikeATS is offline Cadillac Owners Member
    Automobile(s): ATS 2.0T RWD
    Jun 2013
    Los Angeles
    24
    Quote Originally Posted by blue_skies View Post
    Yes, having been able to compare the two now, the converted HID light pattern is more pleasing at night: the road just lights up brighter. Note that this is not light-color related, but light-pattern related.
    Also, I expected more from the adaptive HID system - the factory HID rotate with the steering wheel, but only slightly, and the difference is marginal in comparison to the normal pattern (not like the STS which had side-light illuminating the left or right side of the road).
    I have a friend who has a very dark driveway entrance, and with either HID system, the entrance remains unlit. With the STS the entrance was fully illuminated.
    As to normal street driving - the 'forward' pattern of both the HID and Halogen appear closer to each other than I would have expected: as you can see from the light pattern, the Halogen light beam is concentrated in front of the car, whereas the factory HID is more dispersed. Converting the Halogen to HID gives you a concentrated HID pattern, which brightens up the road surface more. The factory HID brightens up more 'besides' the road.
    I should put up a picture of my other car's (factory) HID pattern - it fits somewhere in between these two patterns, meaning it is brighter than the factory HID and less bright than the converted HID (for illuminating the road surface in front of you).
    What is the bulb size fitment (aftermarket size) for the ATS? Also, it seems like the stock halogens are dual beam bulbs functioning as low and high beams. Did you get the dual beam HID's? Any info would be greatly appreciated!
  4. #139
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    3,695
    Quote Originally Posted by MikeATS View Post
    not a dual beam, it's one bulb with a shutter in the lamp housing that that raises and lowers the beam depending on position.
    http://cnettv.cnet.com/car-tech-101-...-50145422.html
    VicATS likes this.
  5. #140
    Automobile(s): ats
    Apr 2013
    427
    very good link
  6. #141
    Mar 2013
    Carlsbad, CA
    3,695
    very good link
    thanks
  7. #142
    Jun 2013
    Los Angeles
    24
    Quote Originally Posted by pissedoffwookiee View Post
    Thanks! Any chance you know what size bulb?
  8. #143
    namarow is offline Cadillac Owners Member
    Automobile(s): ATS Lux AWD 2l turbo
    Jun 2013
    49
    5
    Great site! I went through this whole thread and I just wanted to make sure I got it. There is no way to add the LED strip up the head light area, and fog lights at this point? My dealer says nothing with them yet. I got the Lux addition as the options made more sense. However, like someone mentioned here, I was actually suprised when I saw that it did not have the LED strip going up the long vertical headlight area etc. I could care less about the other HID stuff, but I really want the strips.
  9. #144
    Automobile(s): ats
    Apr 2013
    427
    Its a 9006 bulb
  10. #145
    kennyjd6 is offline Cadillac Owners Member
    Sep 2012
    13
    Just installed the original LED headlights on my standard ats... and It works.... somewhat... haha. Got new connectors to rewire the headlights and LED's to work, then also added a capacitor in hopes of solving the flickering problem with it. Right now it seems to work, headlights, LED's and all, as long as i turn the lights on before I start the engine.... Not really what I wanted and I'm still looking for a solution, but wanted to share and also see if anyone else had any ideas?
    Heard sometimes the dealer can re-flash the computer to solve these sorts of problems but i'm not sure on that. But just thought i'd share since no one else seems to have done it yet.
  11. #146
    donavo's Avatar
    donavo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS-V Coupe MT
    Feb 2011
    Los Angeles, California, Unite
    26
    1,524
    Quote Originally Posted by kennyjd6 View Post
    have u tried disconnecting the headlights from the DRL? standard uses the headlights as DRL and the LED trims use the LEDs as DRL. i would suggest disconeecting the DRL from the headlights so it looks more proper. that might even solve ur issue.
  12. #147
    Sep 2012
    13
    Quote Originally Posted by donavo View Post
    Yeah I would've preferred to do that, but the DRL and regular headlights on the standard model get power from the same wires at the light. I haven't found a way to turn off the DRL. Other cars have had a fuse you could pull, but i cant find any. Or figure out where the relay is that switches between DRL and nighttime lights.
  13. #148
    donavo's Avatar
    Feb 2011
    26
    1,524
    hmm so it only has 2 wires going to the headlights, and the DRL / night time lights are all controlled internally? if thats the case then it really cant be modded easily. i was hoping it would have 3 wires going in. ne for ground, one for DRL and one for night time running lights. the u could just get rid of the drl and hook it up to the LEDs instead.
  14. #149
    Sep 2012
    13
    Yeah just the two wires, would've made it much easier if it had 3. Thats why I put in the anti-flicker capacitor, in the hopes it would fix the issue. Then just have lights on full power during the day, like how people are adding the aftermarket HID's to the headlights. Just weird that it will work if the engine is off before, but not if they turn on with the car.
  15. #150
    donavo's Avatar
    Feb 2011
    26
    1,524
    u mean if u turn ur headlights on and then turn the car on, the DRL works properly? headlights are off and LEDs are on? and then when its dark, headlights come on?
  16. Remove Advertisements
