Rear Sway Bar Link Install
cadillac ats forums cadillac ats forums
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By sqkid89
  • 1 Post By mikesblueats
Cadillac ATS Performance Forum Discussion, Rear Sway Bar Link Install in Cadillac ATS Discussion Forums; I think I may have had a few dollars burning a hole in my pocket, but who cares! Here's how ...
    sqkid89 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0L Performance RWD
    Oct 2012
    Lowell, MA
    403
    I think I may have had a few dollars burning a hole in my pocket, but who cares! Here's how to replace a set of rear sway bar links (and upgrade to something bigger if you wanted)
    You can go at this a couple ways, so I'll leave it up to you. You can opt to jack up the car and remove the wheel if you want, this would give you a little more room to work and require a little bit less flexibility and tool creativity. Or you can use a set of ramps (I love my rhino ramps, especially if your car is a bit on the lower side) and get creative.
    So, the links:
    You've seem them around before, they're pretty beefy, seem to be well built.
    On the ramps!
    A little washed out, but here's what you're going to be attacking
    The nuts and bolts are 15mm. Ratcheting wrenches are going to be your friends here. They'll get the job done. If they're not too corroded, the upper link stud has a 5mm allen head relief to hold it in place while you loosen the nut. If you opted for the ramps, you'll need an L-shaped allen for the job since there not much clearance available due to the shock dust cover. Chances are, you're not going to be that lucky. However, a pair of vice grips will come in service here. There's a good hunk of metal you can lock down on to stop the stud from spinning when you're loosening the nut. My photo may not do it justice, but should help give you an idea of where to look
    Once you've got this out, the hard part's done (or at least it should be). Here's old vs new - you can also see at the base of the threaded stud where I used the vice grips on.
    So the issues I ran into regarding this upgraded style link - the hardware was too big for my sway bar. I've seen mixed results from members on here; some had the same issue, others didn't. I had 2 ways to handle it: 1. come off the ramps, jack the car up, remove the wheel, drill out the bar, and the hardware works. 2. get slightly smaller hardware, run a sleeve over the bolt to make up the slack in the link bushing. I opted for route #2.
    Again, I had to be creative with installing the upper bolt because the wheel was still on. A stubby wrench solved my issue of clearance. This issue will not occur with stock style links, as the upper is a ball socket style setup.
    (meant to toss this in the pictures forum, whoops. any nice moderator that wants to help me with that, that would be great! sorry!)
    Ragtop 99 likes this.
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,043
    Re: Rear Sway Bar Link Install
    Quote Originally Posted by sqkid89 View Post
    I think its also a good candidate for the technical forum so tossed a coin and moved it there.
    Oct 2012
    Lowell, MA
    403
    Quote Originally Posted by Hoosier Daddy View Post
    Thanks Hoosier! I had been tossing all my other installs into photos, but tech does seem to make more sense...
    Feb 2013
    67
    6,043
    Thanks for the how to posts with pics.
    exbagboy's Avatar
    exbagboy is offline Cadillac Owners Fanatic
    Automobile(s): ATS
    Nov 2013
    443
    Driving impression with these on?
    I am waiting for a good time to install these.
    nyinstaller's Avatar
    nyinstaller is offline Cadillac Owners Fanatic
    Automobile(s): ATS_V _vector Blue Sedan
    Sep 2013
    Central Florida
    34
    329
    ive had mine for quite sometime and I cant say I have felt anything. Once better sway bars come out then I'm sure the difference will be felt. But with the oem sway I don't see much of a difference.
    exbagboy's Avatar
    Automobile(s): ATS
    Nov 2013
    443
    Thanks for your input, the first guy that reviewed these raved how much the rear is more planted but everyone perceives things differently.
    I wonder if RSB from CTS-Vsport would work on ours.
    n2o-3.6-ATS's Avatar
    n2o-3.6-ATS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 3.6L
    Jun 2014
    Largo, FL
    35
    174
    Looks like Eibach offers sway bars for the ATS
    exbagboy's Avatar
    Automobile(s): ATS
    Nov 2013
    443
    Yes, just checked and they do. Thanks.
    http://eibach.com/america/en/perform...ion/buy-online
    328$ for the RSB.
    Sep 2013
    Central Florida
    34
    329
    328 for RSB??
    exbagboy's Avatar
    Automobile(s): ATS
    Nov 2013
    443
    yeah, that's way too much for a 19mm bar.
    Also I was surprised our OEM RSB is only 14mm thick.
    I am also a little vary of modifying any suspension parts since the MRC is programmed to work in unison with the OEM parts, and having less body-roll doesn't mean you're going through that corner faster.
    Oct 2012
    Lowell, MA
    403
    I've not felt much of a difference, if at all, but I haven't pushed the car much either. I wasn't expecting much to be honest. I think I had a momentary laps of judgement and just bought on a whim. I do however prefer this design over the OE, as the ball joint style setup will fail over time and are a pain to remove once they've been on for high miles. Is it something pretty on the car? Yeah.
    mikesblueats's Avatar
    mikesblueats is offline Cadillac Owners Member
    Oct 2013
    Pittsburgh, Pa
    35
    21
    Tire rack has the front and rear kit for $378
    exbagboy likes this.
  16. #14
    louie1487 is offline Cadillac Owners Fanatic
    Jun 2013
    461
    Quote Originally Posted by mikesblueats View Post
    And Eibach has a 10% rebate.
  17. #15
    transam00 is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0 T
    Oct 2013
    347
    The base ats sure could use some fatter bars . The front and rear are 2 way adjustable , sweet .
  18. Remove Advertisements
