I went to Atco Friday night and ran the car 13.7 @100 was the best time on the 2.0T
cadillac ats forums cadillac ats forums
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac ATS Performance Forum Discussion, I went to Atco Friday night and ran the car 13.7 @100 was the best time on the 2.0T in Cadillac ATS Discussion Forums; I have an Automatic 2.0T performance. I left the line brake boosting @ 2k RPMs. I cut a 1.9 60' ...
    BLitzkrieg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V
    Aug 2010
    42
    304
    I have an Automatic 2.0T performance. I left the line brake boosting @ 2k RPMs. I cut a 1.9 60' and ran a 13.7 @ 100mph. Mods are Trifecta (engine tune only) and the MAF housing I am working on with a 6" filter on a temporary short ram with no heat baffle.
    I built a mandrel to have silicone made which would place the MAF/filter behind the fog light area. After the intake I am going to build a FMIC. Between those 2 things and HP Tuners allowing me to tune, I should be able to get the car well into the 12s before the end of summer.
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    Re: I went to Atco Friday night and ran the car 13.7 @100 was the best time on the 2.
    cool! 13.7 is a damn good time, so you're going to extend that pipe from the maf housing and put a filter down in the fender?
    Aug 2010
    42
    304
    That is incorrect. Placing the MAF mid tube hurts performance and accuracy. I'm relocating the MAF into bumper in front of the driver's side front tire.
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    808
    I'm sure you will post pictures when you are finished. Sounds interesting.
    CTSCHICK Guest
    Awesome congrat's on getting some of that Atco magic
    Ancient Mariner's Avatar
    Ancient Mariner is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS4 3.6 Performance
    Jul 2013
    NL, Canada
    346
    Nice results, congrats!
    AirBusPilot is offline Cadillac Owners Member
    Automobile(s): None
    Jul 2013
    Austin, Texas
    75
    DAwas 800 ft at around 9p. Great run.
    What do these cars run stock?
    Aug 2010
    42
    304
    Around 14.4 @ 95mph.
    Hoosier Daddy's Avatar
    Hoosier Daddy is online now Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,012
    Tire pressures? And type.
    BNRacing is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    Feb 2012
    259
    What car went 13.4?
    Aug 2010
    42
    304
    Quote Originally Posted by Hoosier Daddy View Post
    Stock Michelin Primacy MXM4 225/40/x18 M&S tires (on factory lightweight 18") @ approximately 35psi. I didn't adjust anything. I just drove up, did a 2nd gear burnout for 5 seconds, brake boosted @ 2k RPMs, 3rd yellow came on, I left. The result was 1.9 60'. If I had some drag radials, I could have left at a higher RPM. As you can seen in the first slip, the 2.4 60' was a result of a 3k brake boost launch. I blew the tires off the car, then shifted into 2nd too early, and caused a bog.
    Feb 2013
    67
    6,012
    Siren05's Avatar
    Siren05 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T RWD. 2011 STI Hatchback.
    Mar 2013
    42
    293
    Seems a tad low on trap mph
    My 2006 is350 bone stock would due 13.3 -13.6 between 103-105mph all day every run.
    306 hp 277 tq
    It weighed 3500+ lbs
    Just seems like it should trap faster and be faster?
  16. #14
    Aug 2010
    42
    304
    Ah I forgot to mention the best run is also the run that I sprayed the intercooler with water right after the first run. It may be due to a better intake air temp. There was also 1.5hrs between the 1st and 2nd run. I didn't spray down the grill for the other 2 runs.
    Quote Originally Posted by BNRacing View Post
    What car went 13.4?
    On the first run it was a Nismo 370Z.
  17. #15
    Automobile(s): NONE
    Feb 2012
    259
    No, it was with his best 60 foot. Besides, you aren't going to gain .7 ET with a better 60 foot.
    I changed my post after rereading his, I thought the first slip was his also.
  18. Remove Advertisements
