Regular vs. Premium Gas - Page 3
cadillac ats forums cadillac ats forums
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 55
Like Tree13Likes
Cadillac ATS Performance Forum Discussion, Regular vs. Premium Gas in Cadillac ATS Discussion Forums; There is an off the line difference. Even with winter blend, regular does not have the same throttle response. Experimented ...
  1. #31
    Dave3283's Avatar
    Dave3283 is offline Cadillac Owners Fanatic
    Automobile(s): ATS, 2.0t - Performance
    Jan 2013
    Ontario, Canada
    232
    There is an off the line difference. Even with winter blend, regular does not have the same throttle response. Experimented last month.
    celmem likes this.
  2. #32
    Ragtop 99's Avatar
    Ragtop 99 is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD, DP, Intake, HPT, CC
    Oct 2013
    Bethesda MD
    1,845
    Re: Regular vs. Premium Gas
    Quote Originally Posted by Hoosier Daddy View Post
    Someone posted lower power on a dyno. And that make sense since boost increases cylinder pressures to generate power. The higher the pressure, the more octane is needed to avoid detonation/knock. Regular can only be used because the car can sense the knock and reduce timing which reduces power.
    Exactly. That's why there are two primary main spark tables in the engine computer, the high octane table and the low octane. Just eyeballing it at WOT, the timing in the low octane table is 4* - 7* less than the high octane table.
    So if you find the car isn't fast enough on regular, put premium in it.
    Conversely, if your car is too fast on regular, Hoosier Daddy will arrange to have your keys taken away and replaced by a set from a Prius.
    But since no car can ever be fast enough, I have no first hand experience.
    The quest continues...
    celmem likes this.
  3. #33
    celmem is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 2.0T
    Feb 2012
    SE Lake Michigan
    115
    Once the roads clear I will experiment. In the meantime, premium for me. That little engine is impressive! Heck it's only slightly larger than my XR1200 lol
  5. #34
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    It's really not worth experimenting I mean, an engine retards boost and timing in times of lower octane this is a very certain thing and those two things will lower the output of the engine. I mean if you'd like to experiment than go for it but it's going to be hard to tell with a butt dyno, we'd need some proper measuring tools.
    Yeah GM's LNF/LTG line is pretty impressive I just wish they'd get that stick outta there asses and offer a warranty approved stage kit like they did with the cobalt/sky/HHR/Solstice. They should have known that a large percentage of buyers would be getting that engine FOR the stage kit. Theirs no reason this engine cant be bumped to 300HP under warranty, the coupe/malibooboo already 290Tq
  6. #35
    Feb 2012
    SE Lake Michigan
    115
    Well interestingly enough I sorta drive like the old man that I am. Of course, I will like to "step on" it occasionally. It's got to be more of a thrill than the 3.6 CTS. This is why I was asking for experiences here.
    What about mid-grade? That's another one to throw into the mix here...
  7. #36
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,039
    Quote Originally Posted by celmem View Post
    I would have said the effect would be midway between premium (91) and regular (87) until Ragtop seemed to imply there are two tables (high and low octane) the computer uses. If so, that would almost certainly make the effects of octane non-linear. If the computer did use the low octane table for mid range (and I have no idea how it decides which to use, possibly by recent knock sensor readings), then you might not get any benefit at all.
    But it doesn't sound like it would make sense for you anyway if you rarely use WOT and are trying to save money. If you would be satisfied without premium you would almost 100% be just as satisfied without mid-grade.
  8. #37
    Ragtop 99's Avatar
    Oct 2013
    Bethesda MD
    1,845
    GM has had two tables for main spark going back to at least the late 1990s and the LS1 motor. I believe it is a knock learn function as they were not equipped with a dual fuel sensor.
    It will also default to the low octane table if detects certain problems. For example, if you unplug/disable the MAF, the car will switch to the low octane table.
    The challenge with experimenting with different gas in your car is that it takes a little time once you reduce octane for the engine to react and switch to low octane. Once switched to low octane, it takes a while for the computer to check to see if it can switch back. I've seen corvette guys say it took 50 - 60 miles for it to reset. Others said several short trips, implying start & run cycles control. I have had no desire to do any more scientific testing on that issue.
  9. #38
    Feb 2012
    SE Lake Michigan
    115
    Thanks for all the feedback fellas. Thought you might get a kick out of this thing. This is were I get a real thrill (XR1200). But make no mistake, I didn't opt for the turbo to putt around. When I do, it's just babying the car is all...
  10. #39
    Feb 2013
    67
    6,039
    Nice Harley. Did it come from the factory with external reservoir shocks?
  11. #40
    Feb 2012
    SE Lake Michigan
    115
    Thanks. The shocks are not stock. Sorry to get of topic here but I've had many bikes in my life. This one is the most impressive.
  12. #41
    Feb 2013
    67
    6,039
    Since you've had many, you might want to post in the motorcycle lovers thread. Here are mine: http://www.cadillacforums.com/forums...ml#post3269267
  13. #42
    -STS- is offline Cadillac Owners Member
    Nov 2014
    57
    I was wondering about this on my newly acquired 2005 STS 3.6 V6 - 87, 89 or 91?
    The closest gas station (across the street) is Shell, where 91 is called "V-Power" and has up to 10% ethanol in it. (E10?)
    The manual says regular 87, don't use lower octane. Atm. I filled with 89, as I was a bit unsure. But what could happen if I fill with 91 V-Power?
    Could it ruin the engine?
    Could it run better?
    Could it clean the engine?
    Would the MPG increase?
    Are there any benefits at all of using Premium 91 V-Power? The price is one $0.20, I don't care about that, I want what's best for the engine.
  14. #43
    Chrispy's Avatar
    Chrispy is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS Luxury
    Apr 2012
    Ontario, Canada
    553
    Shell 91 should have NO ethanol in it. It's the only top tier gas that doesn't.
    Personally I'd run 91 or higher in the 3.6 as well unless cost is a huge concern.
    Your car will only benefit from 91 versus 87. (High octane spark table will be used, less detonation, better fuel economy, better cleaning agents in the gas)
    Cheers
    Chris
  15. #44
    donavo's Avatar
    donavo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS-V Coupe MT
    Feb 2011
    Los Angeles, California, Unite
    26
    1,526
    Quote Originally Posted by Chrispy View Post
    Cheers
    Chris
    is that "no ethanol" thing only true in canada? or CA as well?
  16. #45
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    553
    Quote Originally Posted by donavo View Post
    Not sure. it says right on the pump though...(87 has up to 10%, 89 up to 5% and 91 no ethanol)
    donavo likes this.
  17. Remove Advertisements
