Aeroforce OBDII Dash Gauge
cadillac ats forums cadillac ats forums
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Like Tree3Likes
Cadillac ATS Performance Forum Discussion, Aeroforce OBDII Dash Gauge in Cadillac ATS Discussion Forums; Been looking for a good device that can both scan all of the parameters our cars use and also display ...
    frankc5r is offline Cadillac Owners Fanatic
    Automobile(s): 2.0 ATS Premium
    Aug 2007
    SE Michigan
    226
    Been looking for a good device that can both scan all of the parameters our cars use and also display them without using
    a laptop. Have used a MSD Dashawk for a number of years but MSD stopped support and it now sets off a code if I plug it into
    the OBDII port. Still works and displays and logs data but I was looking for a modern version.
    Jerry at BNR refered me to Interceptor gauge by Aeroforce.
    See:
    http://aeroforcetech.com/products_interceptor.html
    Mounted one in my ATS 2.0 today and it works great. You can pick practically any sensor or parameter and display up to 8 at a time. tho with 8
    the text is small. CAn also have display cycle between sets of parameters. Can also log data and play back later.
    Quick trip out and I saw 16 psi boost and 0-1 deg of early knock retard.
    Here is a picture:
    PS: Car is idleing. With variable cams u get very high idle vac. Gauge reads 13.5 in Hg with if u
    multiply by 2.03 in vac per in Hg gives 27 in of vac like most people are used to seeing
    donavo's Avatar
    donavo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS-V Coupe MT
    Feb 2011
    Los Angeles, California, Unite
    26
    1,525
    Re: Aeroforce OBDII Dash Gauge
    Quote Originally Posted by frankc5r View Post
    See:
    Here is a picture:
    Attachment 109457
    maan.....no offence at all but dont u think that looks rly bad on a beautiful and classy dash? is there an option for a less visible type of deal? maybe some technologically inclined person can figure out how to include a boost gauge on the information screens on the dash?
    Aug 2007
    SE Michigan
    226
    Quote Originally Posted by donavo View Post
    It comes out in 2 sec if wanted . And again no offense- but I would rather have a little ugly than a burnt piston if I had a tune.
    The fake carbon is kinda ugly. Plan on scanning the dash cover with a colorimeter and painted the gauge hsn with ATS specific color
    for a better blend
    donavo's Avatar
    Feb 2011
    26
    1,525
    for a better blend
    no offense but no offense. . i agree about the burned piston though. i dont know much in that area, but what would you be looking for to prevent damage with the tune? keep an eye on the boost make sure its not too high? if so, what would be too high?
    Aug 2007
    SE Michigan
    226
    That is why it is always good to know what is going on even if u do not have a tune. I have had 2 of the GM turbos with older LNF engine and
    the max boost was about 24 psi vs 13-17 stock. It varies cause of the ecm GM uses which controls torque stock to 260 ft# and uses whatever
    boost it needs to make the target. But even that varies with octane, altitude( takes more boost at higher altitudes).
    What I always monitored before and will again with ATS is boost ( to makesure wg rod not misadjusted) and ignition retard from knock.
    Knock will kill turbos especially highly boosted ones like the ATS, STi etc etc. If I see more than a little knock, I find out why--bad gas? or
    some other problem. Stock GM makes a very safe piece with boost reduction if it sees a bad knock problem. A reduced power message
    will come up on dash.
    frank
    gfxbt is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T MT
    Dec 2012
    29
    131
    Very cool, although I agree it's not the nicest looking thing. But, better to have the information than not have it at all. Does it record the data so you can view it later (e.g., maybe dump it into excel)?
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    808
    What vehicle did you use in ordering, GM 2.0T ? Notice no Cadillac listed.
    Aug 2007
    SE Michigan
    226
    Quote Originally Posted by mikesul View Post
    Yes Mike, you order by maker, in this case GM. 2008 and later GM use CAN bus so order CN series gauge.
    I order red display-mistake. Want white background for best daylight display. Sending mine to be reflashed to black on white background
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I'd rather mount a phone(doesn't even need to be activated, just Bluetooth enabled) to the dash or windshield and have a more normal, more useable display...
    donavo and donavo like this.
    Stevo Supremo's Avatar
    Stevo Supremo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS RWD 2.0 Manual
    Feb 2013
    1,347
    yikes thats ugly, but I do realize it can be removed so no flak to you
    Aeroforce interceptors are the shit man, had one on my cobalt and would LOVE one for the ATS
    what about painting that carbon stuff flat black and mounting it to the steering column like the ion redlines have? kinda like this
    Dec 2012
    29
    131
    I like the steering column idea. The whole idea of being able to see the data and monitor it is extremely appealing. On that note, does anyone know of a good iPhone app to do this? Would be cool if there were a decent app and you could just use a Bluetooth OBDII dongle.
    Feb 2013
    1,347
    Quote Originally Posted by gfxbt View Post
    only thing like that I'm aware of is for the android
    YoshiFD3S's Avatar
    YoshiFD3S is offline Cadillac Owners Member
    Automobile(s): '13 ATS 2.0T Manual, '11 Sonata 2.0T, '94 Mazda RX-7 w/ 2JZ
    Apr 2013
    Canton, GA
    31
    61
    iPhone has the "Rev" app (I think it's like $40, though...I bought it a while ago)
    Android's have the "Torque" app.
    Here's an example of a screenshot from the iPhone "Rev" app:
    Red/Orange = HP/TQ
    Green = Boost
    Blue = RPM's
    Grey = Speed (MPH)
    You can customize the graph to show different things. Here's the main display that you customize:
    You get the idea. :P
    I personally like the iPhone rev app better, and the graphing is easier to comprehend versus the Android "Torque" app.
    Doing 0-60MPH runs with the "Rev" app is kind of a pain in the butt though. Takes a couple tries for it to record it properly.
  16. #14
    Siren05's Avatar
    Siren05 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T RWD. 2011 STI Hatchback.
    Mar 2013
    42
    293
    I run a fully built Subaru 2011 STI
    I have a full Defi set up gauges and controller.
    IMO EGT,OIL PRESSURE AND AFR ARE THE IMPORTANT MONITORS ON HIGH BOOST CARS.
    BOOST GAUGE MEH.I DATA LOG WEEKLY FOR KNOCK AND TARGET BOOST
  17. #15
    Feb 2013
    1,347
    Quote Originally Posted by Siren05 View Post
    this guy... this guy knows whats up^
    but lets be honest, boost gauges are just fun
    Siren05 and Siren05 like this.
  18. Remove Advertisements
