center hub bore size? is it 70.3 mm like other cadillac models?
cadillac ats forums cadillac ats forums
Results 1 to 3 of 3
Cadillac ATS Performance Forum Discussion, center hub bore size? is it 70.3 mm like other cadillac models? in Cadillac ATS Discussion Forums; trying to get some aftermarket wheels for weekend events. found lug pattern and offset informations, but not sure about hub ...
    hueyh is offline Cadillac Owners Member
    Jan 2013
    19
    found lug pattern and offset informations, but not sure about hub center size.
    Anyone has tried aftermarket wheels, and what size center ring did you use?
    Thanks!
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,020
    Re: center hub bore size? is it 70.3 mm like other cadillac models?
    Quote Originally Posted by hueyh View Post
    Thanks!
    If you don't get an answer here, someone at TireRack should know. The hard part is finding those people if it hasn't been added to their databases yet. You might have to call numerous times before you get someone who knows answers.
    Jan 2013
    19
    measured the hub center bore today when I was trying to put a used BBS wheel on to my ATS
    didn't have caliper, so I used my iphone app.
    it shows around 70 millimeters. Though I can't accurately find the diameter line.
    I believe it should be 70.3 just like other Caddys
