driveline thump deceleration
cadillac ats forums cadillac ats forums
Results 1 to 8 of 8
Cadillac ATS General Discussion Forum Discussion, driveline thump deceleration in Cadillac ATS Discussion Forums; Hello. Tried searching but for some reason nothing is coming up. Anyway, I have started to feel a very strong ...
    tahawk69 is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0t awd premium
    Feb 2014
    richmond mi
    37
    412
    Hello.
    Tried searching but for some reason nothing is coming up. Anyway, I have started to feel a very strong driveline thump when decelerating under 30mph. When it happens passengers have thought we got bumped or rearended. This is with the auto trans and in factory tour mode and under normal driving conditions. Almost feels like torque converter lock up issues. Any ideas? Thanks
    Ragtop 99's Avatar
    Ragtop 99 is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD, DP, Intake, HPT, CC
    Oct 2013
    Bethesda MD
    1,843
    Re: driveline thump deceleration
    Is the thump when the car is downshifting?
    Feb 2014
    richmond mi
    37
    412
    I originally thought the auto trans was trying to hold the gear longer and the thump was a result, but I noticed it happens when coasting to a stop as well right before applying the brakes. So not sure 100% that it's not during a downshift, I will have to watch rpms and pay closer attention.
    rsingl's Avatar
    rsingl is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS 3.6 Premium RWD, 2016 Corvette Z06
    Sep 2007
    791
    I don't know how the driveshaft in the AWD ATS is configured but thumps/clunks like this are often due to a dry slip joint if there is one in the drive line. This was an issue with many of the configurations of GMC/Chevrolet pickups for many years and owners that experienced the problem often described it as feeling like they were hit from behind. The simple cure was properly lubricating this joint. Again I have no idea if your configuration has one and crawling under my ATS wouldn't help since I have a 3.6 RWD.
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,014
    Quote Originally Posted by rsingl View Post
    I never paid attention when changing oil but since these have independent rear suspension I'm pretty sure the diff would be in a fixed location and no need for a slip joint.
    Feb 2014
    richmond mi
    37
    412
    When it happens It sure does feel like the car gets hit or bumped from behind. Surprised no one else has experienced or noticed this.
    nissanite is offline Cadillac Owners Member
    Apr 2014
    18
    Just noticed you have all wheel drive. This may be the center differential. Your tires need to be the same size and tread depth. The difference in rolling diameter puts major stress in this part. Had this happen in a shop I worked at. Had worn S rated no name tires in front and new H rated on the rear.
    Make the tire match and this should cease.
    btmasta is offline Cadillac Owners Member
    Automobile(s): ATS
    Nov 2013
    63
    Maybe the front CV joints going bad.
    Hope my company doesn't make them :/
  11. Remove Advertisements
