cadillac ats forums cadillac ats forums
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: cts 2.0 T faster than 3.6 0-60 .
    transam00 is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0 T
    Oct 2013
    347
    Automotive addicts tested cts 2.0 t . 0-60 6.0 and 3.6 was 6.2 . The 2.0 in the cts has 272 hp and 295 lb. Ft.
    RxNotec's Avatar
    RxNotec is offline Cadillac Owners Member
    Automobile(s): 2013 ATS4 3.6
    Apr 2014
    Saint Paul, MN
    81
    Re: cts 2.0 T faster than 3.6 0-60 .
    AWD acceleration vs RWD acceleration is my guess. Motor Trend found the same result.
    http://www.motortrend.com/roadtests/...ts_first_test/
    Not the same story though in the ATS v6 vs I4T.
    ChevyRules is offline Cadillac Owners Member
    Automobile(s): 2014 Cadillac ATS Premium 3.6 AWD
    Mar 2014
    83
    The higher torque at the lower RPM also probably helps as well.
  5. #4
    carpenter is offline Cadillac Owners Connoisseur
    Automobile(s): '14 ATS 4 Black Raven 3.6 Premium
    Jan 2014
    WI
    41
    1,111
    They didn't test the 3.6 so they are just going off numbers that Motor Trend had for their 3.6 car. Pretty hard to actually compare that way. Really need to see a comparison between the same cars with just different engines unlike the AWD/RWD comparison Motor Trend did on the 2.0T AWD and 3.6 RWD. I drove the 2.0T CTS for a few weeks and am now driving one again and it's a damn nice engine though. At first I thought it was a bit underpowered in the CTS but that I think that was because I was coming from the 3.6 in the ATS and trying to compare. It definitely moves the car really well.
  6. #5
    Feb 2014
    490
    Quote Originally Posted by RxNotec View Post
    Because cadillac limited our torque with 13 and 14's.
  7. #6
    Nov 2013
    Florida
    232
    One more variable to throw out there is temperature and altitude. A 235i (320hp) would out accelarte an IS-F(400hp) a mile above sea level because of the turbo.
  8. #7
    exbagboy's Avatar
    exbagboy is offline Cadillac Owners Fanatic
    Automobile(s): ATS
    Nov 2013
    449
    ^Which is why I got the turbo in Colorado. Plus potential tune gains.
  9. #8
    donavo's Avatar
    donavo is offline Cadillac Owners Connoisseur
    Automobile(s): ATS-V Coupe MT
    Feb 2011
    Los Angeles, California, Unite
    27
    1,532
    Quote Originally Posted by exbagboy View Post
    isnt colorado at a very high altitude?
  10. #9
    ben.gators is offline Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,232
    Quote Originally Posted by donavo View Post
    One mile above the sea. How I know: I watch "the fast lane car"
    http://www.tflcar.com/
    They are located in Denver and they always talk about the altitude of Denver and its effect on 0-60 time.
  11. #10
    Nov 2013
    Florida
    232
    Quote Originally Posted by ben.gators View Post
    lol Yea that where I saw the 235i vs IS-F
    https://www.youtube.com/watch?v=xiT4aaEXN5o
  12. #11
    donavo's Avatar
    Feb 2011
    27
    1,532
    well in that case the 2.0T would really suffer because of turbo. and the 3.6 would do better. am i wrong? turbo relies more on air density than NA. does it not?
  13. #12
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    That was my impression.
    Also, I'm willing to bet that on say a 70-150 run, the 3.6 would walk away from the 2.0 stock.
  14. #13
    Nov 2013
    Florida
    232
    Other way around. At altitude the air is less dense and a turbo pressurizes air and makes it more dense again. although both suffer the turbo takes less of a hit. specially new turbos like ours that are torque managed which means the car will do anything including raising boost pressure to get the power and in the case of high altitude the turbo will work harder achieve power. While the NA has no way of compensating.
  15. #14
    donavo's Avatar
    Feb 2011
    27
    1,532
    Quote Originally Posted by Johnm05 View Post
    Other way around. At altitude the air is less dense and a turbo pressurizes air and makes it more dense again. although both suffer the turbo takes less of a hit. specially new turbos like ours that are torque managed which means the car will do anything including raising boost pressure to get the power and in the case of high altitude it will pump more air to achieve power. While the NA has no way of compensating.
    if that was true, y do i always hear about cold weather being boost weather or good for the turbo weather or "more horsepower" weather? colder air is dencer so that leads me to believe that dencer air has a bigger plus on a turbo engine....
  16. #15
    Nov 2013
    Florida
    232
    Denser air is good for both Turbos and N/A however when the air is thinner a turbo car can compensate by working the turbos harder and the N/A has no way to compensate. Also say the Ambient psi is 2 less than at sea level (made up number) the turbo can also compensate the 2psi while the N/A can't.
  • You may not post replies
