cadillac ats forums cadillac ats forums
Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 16 to 30 of 170
Thread: Finally intalled the OEM DRL and HID on a luxury ATS
  1. #16
    nyinstaller's Avatar
    nyinstaller is offline Cadillac Owners Fanatic
    Automobile(s): ATS_V _vector Blue Sedan
    Sep 2013
    Central Florida
    34
    329
    Re: Finally intalled the OEM DRL and HID on a luxury ATS
    believe it or not , some oem brand new parts are not bad. it all depends on what your doing and where you get it from. If you search and have part numbers (a plus) you can find there is plenty of sites that sell the parts and lower than any dealer.
    here is an example I hated the orange turn signals in the mirrors so I ordered new parts to modify and replace the orange with white. Which looks 1000 times better
  2. #17
    Sep 2013
    38
    the fog lights cost 120 each side. The trim bezels and that small inserts cost 100 each side.
    Quote Originally Posted by Vernon Cooke View Post
    Thanks for clarifying my inquiry.
    Just wanted to know cost on an absolute basis.
  3. #18
    Chrispy's Avatar
    Chrispy is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS Luxury
    Apr 2012
    Ontario, Canada
    553
    Question...did you replace the headlight assembly for HIDs or just put in HID bulbs?
  4. #19
    mechevar is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0T RWD
    Feb 2013
    105
    Do you have the part numbers? Just to verify, you need the LED daytime running lamps, the trim bezel and the horizontal insert.
    Quote Originally Posted by yohaishi View Post
    LED daytime running lamps Trim bezel (w/hid) ,and insert
  5. #20
    Jun 2013
    4
    Just wondering if its possible could you kind of explain what you used to wire all this up. Do the actual lights come with some sort of wiring harness that you tap into whatever you want them to come on with, or did you have to get wires seperate?
  6. #21
    Sep 2013
    27
    198
    there's a bunch of these on car-part, which basically just parts out crashed cars and displays a nationwide database of them
    specifically the upper headlight assembly, including the DRLs, except it's like $650 for each side at the cheapest...
  7. #22
    Feb 2013
    105
    I was able to find the lower led drl on car-part, but what search param should I use to try and find the brake duct cover and horizontal trim piece?
  8. #23
    jsehlms's Avatar
    jsehlms is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T LUX 6MT
    Jan 2014
    Cleveland, OH
    101
    Quote Originally Posted by mechevar View Post
    If you found a yard that has the LED DRL, then they should have the other parts you need. Just call them and ask. Sometimes, that whole unit of parts will be the 'fog light assembly'. They may also tell you the cover and trim are part of the bumper cover and you need to purchase the whole thing.
    Good luck.
  9. #24
    Feb 2013
    105
    Just picked up the OEM lights, brake duct cover and trim piece. Now...just gotta figure out how to get them installed. My main question is how to do the wiring, what did you use (splitter?) to get down to the plug on the back of the LEDs?
  10. #25
    jsehlms's Avatar
    Jan 2014
    Cleveland, OH
    101
    Could someone please turn this thread around and put together a nice writeup of the process including parts needed and steps required to complete this swap. I'm sure many will want to do this swap and so far we know you used the stock parts, but no idea if the harnesses were already there, or if splicing was required or how you even did it.
  11. #26
    carpenter is offline Cadillac Owners Connoisseur
    Automobile(s): '14 ATS 4 Black Raven 3.6 Premium
    Jan 2014
    WI
    41
    1,113
    Quote Originally Posted by jsehlms View Post
    This would be really nice. It would actually be nice to have a subforum for this exact thing. Strictly for How-To write ups.
  12. #27
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    920
    Quote Originally Posted by carpenter View Post
    Been suggested a while ago, but nothing has happened to establish a DIY sub-forum.
  13. #28
    ikireland's Avatar
    ikireland is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0T AWD
    Jan 2014
    Calgary, AB
    30
    340
    Quote Originally Posted by nyinstaller
    believe it or not , some oem brand new parts are not bad. it all depends on what your doing and where you get it from. If you search and have part numbers (a plus) you can find there is plenty of sites that sell the parts and lower than any dealer. here is an example I hated the orange turn signals in the mirrors so I ordered new parts to modify and replace the orange with white. Which looks 1000 times better <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=172001"/>
    How's you make them white?? I have been wanting to do the same...
  14. #29
    Sep 2013
    38
    Just go to a custom shop, and let them do it.
    You will have to remove the front bumper off in order to install the fog light.
    in terms of the led fog light, the wiring has already been there, and you just need to order the part. then let the custom shop do it. As for the HID, you will need a relay harness.
    Could someone please turn this thread around and put together a nice writeup of the process includingin parts needed and steps required to complete this swap. I'm sure many will want to do this swap and so far we know you used the stock parts, but no idea if the harnesses were already there, or if splicing was required or how you even did it.
  15. #30
    jsehlms's Avatar
    Jan 2014
    Cleveland, OH
    101
    I don't need a shop to install anything. The point of a DIY thread is to help others 'DO IT YOURSELF'.
    If the wiring is already there, then why would you need a shop to install anything? You'd only need a shop if you had to splice wires and wanted to make it look professional.
    So from this cryptic thread, we can deduct the following:
    Stock HID headlamps, LED driving lights, Premium/Performance Brake covers will be required.
    Wiring is already there for the LED driving lights.
    A relay harness (OEM or aftermarket.. we don't know) will be required in order to fire the HIDs
    Everything should mount up without issue.
    The only variable is this harness which is required. Is this an OEM part? Or is this something needed to splice in? Do the stock headlights come with the ballast for the OEM HID light or do we get an aftermarket HID kit with harness for our Halogens? If the latter, than we would effectively only be upgrading to the proper projector housing for HID vs a halogen projector housing.
  • You may not post replies
