Can't turn-off TCS Traction control - is it defective? - Page 2
cadillac ats forums cadillac ats forums
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Like Tree3Likes
Cadillac ATS General Discussion Forum Discussion, Can't turn-off TCS Traction control - is it defective? in Cadillac ATS Discussion Forums; What issues for idling do you have? Does it stumble once in a great while when the engine is not ...
  1. #16
    oachalon is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS Peformance 3.6 AWD
    Jul 2013
    Cleveland Ohio
    31
    100
    Re: Can't turn-off TCS Traction control - is it defective?
    What issues for idling do you have? Does it stumble once in a great while when the engine is not up to temp? I get an idle stumble once in a while, but that is normal. My old Saturn aura had the 3.6L (non DI) in it and it did that as well. My 3.6 in my ATS idles 10 times smoother than the 3.0T engine in an audi s4 a guy I work with has.
  2. #17
    stlbigboy is offline Cadillac Owners Member
    Automobile(s): ATS
    Nov 2013
    4
    Just thought I would give an update - noticed that the TPMS system was reporting a slightly lower than normal air pressure in one of my tires and it occurs to me. It's not letting me turn off the TCS because of the low pressure. Turns out my theory was correct. Got the tires to the 32/35 and all is good on the Traction Control issue. Interesting though that the dealer didn't check tire pressure when they rotated the tires and did the oil change. I would have just that that would have been checked. Even though, I have to say that thanks to our GM friends here, I have a meeting on Tuesday with the local GM rep and Cadillac Service Manager. Will keep you posted about the lights issue and the idle issue.
  3. #18
    JavaGirl is offline Cadillac Owners Fanatic
    Jun 2013
    288
    Wow, now there is some information which is useful for everyone to know! Traction control will not disengage if the air pressure is low in a tire. Wow.
  5. #19
    GJB's Avatar
    GJB
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,608
    Pretty damn smart since low tire pressure may lead to a blow out where traction and stability are needed.
  6. #20
    Jun 2013
    288
    Yeah, that is smart. Wow.
  7. #21
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    67
    6,042
    Quote Originally Posted by GJB View Post
    Quote Originally Posted by JavaGirl View Post
    Is there more to this story?
    I mean why didn't the car notify the OP that the tire(s) had too low of pressure if they were low enough to prevent TC being turned off? If it didn't, its not that smart.
  8. #22
    Automobile(s): ATS
    Nov 2013
    4
    Not really anything more. Yes I was running a little low in air but it never occurred to me that that might be the reason why the TCS wouldn't turn off. If this is indeed the case i tend to agree, this is a great safety measure. It was literally like a light bulb moment. Just wanted to pass on the info. I have been having other issues but I don't think they were related.
  9. #23
    Ragtop 99's Avatar
    Ragtop 99 is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD, DP, Intake, HPT, CC
    Oct 2013
    Bethesda MD
    1,845
    Quote Originally Posted by stlbigboy
    same in the vette. Limits the ability to drop the pressure at the drag strip without using a pressure canister.
  10. #24
    Feb 2013
    67
    6,042
    Quote Originally Posted by Ragtop 99 View Post
    I wonder if you lowered the pressure AFTER starting the car and turning TC off if it would leave it off. Would be a hassle to pump them back up and go thru that every pass but better than wasting the day if you discovered this at the track.
  11. #25
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    Quote Originally Posted by stlbigboy View Post
    So what is a little low and/or do you know what TP the TC will not cancel? Reason I ask is when in snow sometimes you need to turn the TC off and if your tires are low you might not get anywhere in heavy snow especially up a hill.
  12. #26
    Yplus is offline Cadillac Owners Fanatic
    Automobile(s): ATS4 Turbo
    Oct 2012
    Long Island, NY
    197
    This could explain why sometimes I see "Traction Control Enabled" for brief periods of time once in a while after I have turned it off. I did just adjust the pressures since it's gotten pretty cold lately. They're 32/35 at 32F now, so should be no problems.
  13. #27
    paz
    paz is offline Cadillac Owners Member
    Dec 2013
    9
    Problem solved. Sorry to get back to this late. As some have mentioned, if the TPMS registers low pressure, the traction control cannot be turned off. One rear tire was down to 23 psi due to a small screw. While some think not allowing TC to be turned off is brilliant, I do not. It WOULD be brilliant if the computer were programmed to allow TC to be turned off at low speeds so in the event that your car is on ice you can get it moving. Looks like the GM programmers have not thought this the whole way through.
  14. #28
    Matt M is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS
    Oct 2013
    125
    I ran into this as well. Took a bit to figure out that a couple tires at 32psi was enough of a concern to disable the TC button.
  15. Remove Advertisements
