cadillac ats forums cadillac ats forums
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Fuel Nozzle Won't Stay in Fuel Neck
    ATSigma's Avatar
    ATSigma is offline Cadillac Owners Fanatic
    Automobile(s): ATS 2.0L Turbo Performance
    Aug 2013
    San Jose, CA
    33
    100
    Please see the attached image:
    Using this fuel pump type which seem to be abundant all over CA gas stations, every one of these will not stay in the fuel neck. It constantly pops out! My first time fueling the car, it was hard to get it in place and then while it started fueling, a second or two in, it popped out and fell on the ground. If it had scratched my car on the way down I would have been pissed. It seems this fuel nozzle in general is not compatible with the way the fuel neck is designed in the ATS. I'm the only person at the gas station who has to hold the fuel pump which kind of makes me feel ridiculous.
    The dealership tell me it is the design of the fuel neck and it is not a manufacturer defect. While they are able to duplicate this issue in my car and with other ATS's on the lot, the car is designed like this so until GM issue a fix, it seems nothing can be done and it will continue to be an inconvenience. They instruct me to drive around and find different gas stations to use that do not have this style of pump nozzle which is even more absurd than sucking it up and standing there fueling it myself.
    I like to clean my front and rear windows while I refuel so it seriously sucks that I cannot do that if I pick the "wrong" gas station and have to spend even more time there than I would like to.
    Has anyone else experienced this problem?
    CTSCHICK Guest
    Re: Fuel Nozzle Won't Stay in Fuel Neck
    That sucks seeing you are trying to use a top tier fuel brand to.
    I think it might have to do with California having regulations that requires a different fuel pump nozzle design than the rest of the country
    JLGT is offline Cadillac Owners Fanatic
    Automobile(s): 2.0T 6MT
    Sep 2013
    172
    I've noticed this issue also at one shell station, but at another it was not an issue. I have only fueled up twice since I bought it.
  5. #4
    ben.gators is offline Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,232
    Quote Originally Posted by CTSCHICK View Post
    This!
    Cailfornia has mandated "clean air" nozzles. These nozzles have different design and size, and you are not the only person who has problem with these nozzles. There are other cars that have similar problems.
  6. #5
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    810
    That nozzle design is to keep "gas vapors" from the air. CA is big on air quality issues dealing with motor vehicles. They want you to stand there and keep pressure on the spring loaded nozzle for a tight fit to catch all those "vapors".
  7. #6
    DiabloMike's Avatar
    DiabloMike is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T gone, 17 Charger Scat Pack current
    Mar 2012
    South Florida
    43
    1,073
    I've noticed that I have to insert the nozzle at an odd/low angle to get it to go in, certainly different from any other vehicle I have fueled up in the past few years...
    Mike Litsch
    DiabloSport Inc.
    Diablosport.com
  8. #7
    cadaddio's Avatar
    cadaddio is offline Cadillac Owners Fanatic
    Automobile(s): Raven Black ATS 2.0T/ auto
    Jun 2013
    Antelope Valley, CA
    130
    I live in SoCal and have had to fight with these nozzles for years on several different vehicles, the ATS is not one of them. Although I only have 4k on the odo, I have filled up several times at a few different locations, and I have not had this problem with the ATS
  9. #8
    73JPS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance 6MT
    Mar 2013
    Ontario, Canada
    270
    Quote Originally Posted by DiabloMike View Post
    ^^ Yes, I have noticed exactly the same thing. Like the top of the gas nozzle catches on something, and you just have to angle it toward the ground slightly but not too much or it doesn't go in then either so then you pullthewholethingoutandyouhavetostartoveragainitca nbeprettyirritating...
  10. #9
    bluztoo is offline Cadillac Owners Fanatic
    Automobile(s): 2013 AST, 2.0T, Prem. AT, RWD
    Aug 2013
    Maryland
    120
    Have gassed up 3 times and did indeed have this problem at one station (so not the other two).
  11. #10
    ewired's Avatar
    ewired is offline Cadillac Owners Fanatic
    Automobile(s): '13 Cadillac ATS 2.0T
    Dec 2012
    42
    131
    Not to mention the actual body of the pump handle can actually rest against the paint under the fuel door. I have only found one station that had a pump that didn't interfere going in or wanting to rest on the body. 10k miles. I just deal with it.
    The funniest part was the first tank of gas. The salesman went with us and he couldn't get it to go in!
  12. #11
    sd vidiot is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T Premium RWD 6M
    Mar 2013
    55
    23
    I live in California and have the same problem with "vapor recapture" pumps. However, I also had the same problem with my E90 BMW 328.
  13. #12
    RocketDawg is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Cadillac ATS 3.6 Performance, White Diamond Tricoat
    Jul 2013
    Madison, Alabama
    497
    Before I retired, I used to travel to California quite often and I remember that I hated the "clean air" nozzles. You had to push in pretty hard to compress the rubber part that's supposed to keep fumes from escaping. I kinda doubt they do a lot of good though. There's not much nozzle protruding beyond the rubber piece so I can see how it wouldn't stay in the fuel neck. Don't have that problem in Alabama, thankfully, or any other state I've driven in lately. Only California. Of course, California usually sets the standards for the nation on most everything. But this is one thing I hope doesn't catch on.
  14. #13
    Fraggy's Avatar
    Fraggy is offline Cadillac Owners Enthusiast
    Aug 2012
    914
    Ha ha, I thought everybody had those nozzles, LOL. I've gotten a bit used to it now with the ATS, I never had this issue with my BMWs. But it's not a big deal, it just took a little while to get used.
  15. #14
    thebucky84's Avatar
    thebucky84 is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac ATS 2.0T
    Oct 2013
    Florida
    28
    29
    Never really thought holding the pump was an inconvenience..
  16. #15
    Sep 2013
    172
    Those dirty nasty pumps.
  • You may not post replies
