Tire Pressure Monitoring System
cadillac ats forums cadillac ats forums
Results 1 to 9 of 9
Cadillac ATS General Discussion Forum Discussion, Tire Pressure Monitoring System in Cadillac ATS Discussion Forums; I am having an issue with keeping my tire pressure on my car. Today it started showing both back tires ...
    ATSlady is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 3.6
    Sep 2013
    I am having an issue with keeping my tire pressure on my car. Today it started showing both back tires were at 31, so I pulled over and put air in them and checked the pressure - well, the car still showed the tires low and the system was alternating from one rear tire to the other indicating 31 and 32 pounds then the low tire pressure light came on. I exited the freeway again and checked the pressure and they were still at 40! What gives? Do the sensors go out? I HATE warning lights showing up on my dashboard!
    Thanks!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Are you trying to use the system as a gauge when filling the tires?
    ONLY inflate the tires COLD, using a real pressure gauge.
    Sep 2013
    Quote Originally Posted by MoistCabbage
    Are you trying to use the system as a gauge when filling the tires? ONLY inflate the tires COLD, using a real pressure gauge.
    No. I uses tire gauge to check the pressure but wondering why the system indicates both tires are low.
    GJB's Avatar
    GJB
    GJB is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS4 3.6 Premium Build Date 12/21/2012
    May 2013
    Northern VA
    1,608
    Re: Tire Pressure Monitoring System
    Quote Originally Posted by ATSlady View Post
    Did you have them rotated recently? If you did the dealer may not have reset the TPMS so that it thinks the front are on the rear and your actually inflating the front as far as the TPMS is concerned.
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    910
    I routinely check (tire gauge) my tires and fill (portable air pump) them as needed. I do 35 psi all around. OnStar notified me that the psi was below 32 psi on two tires (also showing low in the DIC), but when I checked them they were at 35 psi. So to be sure that I maintained the psi I wanted, I filled them to 36 psi all around. Now the DIC reads 37-38 psi. So, who's more accurate, my gauge or the DIC?
    David is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS Premium 3.6; 1992 Cadillac Allanté
    Oct 2003
    Iowa
    75
    198
    I think that there is probably a 'margin for error' in both the tire pressure sensors on the car, as well as a tire pressure gauge; I find that the sensor read-outs are pretty much in line with my own tire pressure gauge. Both are
    approximate readings.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    Quote Originally Posted by David View Post
    Agreed.
    GJB's Avatar
    GJB
    May 2013
    Northern VA
    1,608
    But the 8 lb diffrence ATSlady was getting is outside the margine which is usualy less than .5 lb.
    Fraggy's Avatar
    Fraggy is offline Cadillac Owners Enthusiast
    Aug 2012
    914
    I've tested mine a few times... Always no more than a half a pound difference from gauge.
  12. Remove Advertisements
