cadillac ats forums cadillac ats forums
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: What's up withe the tires on this car?
    Audioi's Avatar
    Audioi is offline Cadillac Owners Member
    Automobile(s): 2013 ATS4 AWD 2.0 Premium
    Apr 2011
    UpState NY
    89
    I just got a 2013 AWD Premium with 18's and when you look at the side profile the tires seem to be lost in the wheel wells! It appears this car needs a larger overall tire?? And why the staggered air pressure? 35 front, 40 rear???
    Call me inquisitive but...
    SLA is offline Cadillac Owners Fanatic
    Automobile(s): '13 ATS 2.0T 6MT, 05 LGT, 97 M3
    Feb 2013
    35
    390
    Re: What's up withe the tires on this car?
    For one thing, they try to keep the speedo accurate by not using huge tires. Putting tires with bigger sidewalls will also make the car more floaty and less grounded to the ground.
    Tire inflation recommendations are based upon the weight distribution of the car. The car with no passengers may have a 50/50 weight balance, but not when passengers are in it. BMW recommends less pressure in the front than the back for my M3, so Caddy is not crazy.
    Audioi's Avatar
    Apr 2011
    UpState NY
    89
    Sounds good to me. Is the appearance just me or does it still look a bit odd?
  5. #4
    David is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS Premium 3.6; 1992 Cadillac Allanté
    Oct 2003
    Iowa
    76
    198
    My Allanté, which is FWD, has 28 psi front and 24 psi rear.
  6. #5
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Higher inflation is used to reduce sidewall deflection on the tires powering the car= better handling characteristics and more contact patch on the roadway.
    Because you have a Premium AWD, I'm fairly certain you have the wider profile rims on standard 235 tires all around, so it might look a bit stretched(or not, just a guess).
    IE, Premium FE3 trim RWD ats's have staggered tire sizes of 235 front/255 rear.
    You still have the pressure differences because this is a largely RWD biased AWD system.
  7. #6
    huna is offline Cadillac Owners Fanatic
    Automobile(s): ATS 3.6 AWD Premium Thunder Gray, Caramel, with peanuts
    Dec 2006
    107
    Quote Originally Posted by Audioi View Post
    Indeed the appearance is a little odd. This was discussed a couple times back in the fall. I'm used to it by now, but I still don't like it.
  8. #7
    Audioi's Avatar
    Apr 2011
    UpState NY
    89
    OK so its not just me, i feel better (sort of).
  9. #8
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by huna View Post
    excuse me Mr. 2,147,483,722 posts. Could I have an autograph?
  10. #9
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Super Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    68
    6,085
    Quote Originally Posted by M5eater View Post
    You're easily impressed. That's not quite even a million posts per day although flood control may have kept the count down.
  11. #10
    pissedoffwookiee's Avatar
    pissedoffwookiee is online now Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    4,144
    According to my onstar report, the car is supposed to have 32 psi front and 35 psi rear, i believe this to be a safety liability thing from GM to promote understeer which is the safer condition for less experienced drivers, 35 psi all around should be more fun, and possibly quicker, i've seen in some BMW places that BMW does the same thing, but people who play harder with their BMW's go 35 all around. and as a side note i've had the car in the dealer for paint buffing (hood scratched from dealer they got car from), steering wheel replaced (stitches unraveled 2 to 3 inches and growing), HVAC tapping calibration, oil change, and HVAC update TSB, so in 6 visits each time my invoice had a line stating tire pressures checked and set to 35 all around.
  12. #11
    rustybear3's Avatar
    rustybear3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS White Pearl Turbo
    Feb 2012
    Ohio
    65
    1,688
    My premium AWD ATS is both 40 psi front and rear...
  13. #12
    Audioi's Avatar
    Apr 2011
    UpState NY
    89
    40 all around rides firm to say the least!
  14. #13
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by Hoosier Daddy View Post
    Indeed, a paultry 890K PPD, but still, it's something.
    I didn't know 2.1 billion could be condensed down into 75 (his actual post count) I need to work on my quantum mechanics.
  15. #14
    Feb 2013
    68
    6,085
    Maybe they ran the 2.1 billion thru the document analyzer from the Foundation Trilogy.
    Or if it IS a quantum thing maybe he had 75 UNTIL people like you looked at them.
  16. #15
    Dec 2006
    107
    75 posts in THIS FORUM alone. My 2004 CTS-V must've generated a billion just right there.
  • You may not post replies
